emissary42
Kapitän zur See
- Ort
 - Nehr'esham
- Desktop System
 - Endlos-Baustelle
 - AMD & Intel
 - alle Hersteller
 - Luft
 - G.SKILL, Corsair & Co
 - 8K, 5K, 4K
 - 80plus Platinum
	G.Skill Sniper Series
F3-17000CL9Q-16GBSR - DDR3-2133 PC3 17000 16GB(4GBx4) CL 9-11-10-28-2N 1.65V XMP Ready (for Intel LGA1155)
F3-17000CL11Q-16GBSR - DDR3-2133 PC3 17000 16GB(4GBx4) CL 11-11-11-30-2N 1.6V XMP Ready (for Intel LGA1155)
F3-17000CL9D-8GBSR - DDR3-2133 PC3 17000 8GB(4GBx2) CL 9-11-10-28-2N 1.65V XMP Ready (for Intel LGA1155)
F3-17000CL11D-8GBSR - DDR3-2133 PC3 17000 8GB(4GBx2) CL 11-11-11-30-2N 1.6V XMP Ready (for Intel LGA1155)
F3-14900CL9Q-16GBSR - DDR3-1866 PC3 14900 16GB(4GBx4) CL 9-10-9-28-2N 1.5V XMP (for Intel & AMD)
F3-14900CL9D-8GBSR - DDR3-1866 PC3 14900 8GB(4GBx2) CL 9-10-9-28-2N 1.5V XMP Ready (for Intel & AMD)
F3-1866C10D-16GSR - DDR3-1866 PC3 14900 16GB(8GBx2) CL 10-11-10-30-2N 1.5V XMP Ready (for Intel & AMD)
F3-1866C10Q-32GSR - DDR3-1866 PC3 14900 32GB(8GBx4) CL 10-11-10-30-2N 1.5V XMP Ready (for Intel & AMD)
F3-1866C9D-16GSR - DDR3-1866 PC3 14900 16GB(8GBx2) CL 9-10-9-28-2N 1.5V XMP Ready (for Intel & AMD)
F3-12800CL7T2-24GBSRD - DDR3-1600 PC3 12800 24GB(4GBx6) CL 7-8-7-24 1.6V XMP Ready
F3-12800CL7Q-16GBSR - DDR3-1600 PC3 12800 16GB(4GBx4) CL 7-8-7-24 1.6V XMP Ready
F3-12800CL7T-12GBSR - DDR3-1600 PC3 12800 12GB(4GBx3) CL 7-8-7-24 1.6V XMP Ready
F3-12800CL7D-8GBSR - DDR3-1600 PC3 12800 8GB(4GBx2) CL 7-8-7-24 1.6V XMP Ready
F3-12800CL9S-4GBSR - DDR3-1600 PC3 12800 4GB(4GBx1) CL 9-9-9-24-2N 1.5V XMP Ready (for Intel & AMD)
F3-12800CL9D-8GBSR - DDR3-1600 PC3 12800 8GB(4GBx2) CL 9-9-9-24-2N 1.5V XMP Ready (for Intel & AMD)
F3-12800CL9D-8GBSR1 - DDR3-1600 PC3 12800 8GB(4GBx2) CL 9-9-9-24-2N 1.35 Volts
F3-12800CL9T-12GBSR - DDR3-1600 PC3 12800 12GB(4GBx3) CL 9-9-9-24 1.5 Volts
F3-12800CL9D-8GBSR2 - DDR3-1600 PC3 12800 8GB(4GBx2) CL 9-9-9-24-2N 1.25 Volts
F3-12800CL9T-12GBSR2 - DDR3-1600 PC3 12800 12GB(4GBx3) CL 9-9-9-24 1.25 Volts
F3-12800CL9Q-16GBSR - DDR3-1600 PC3 12800 16GB(4GBx4) CL 9-9-9-24-2N 1.5V XMP Ready (for Intel & AMD)
F3-1600C9D-16GSR - DDR3-1600 PC3 12800 16GB(8GBx2) CL 9-9-9-24-2N 1.5 Volts XMP Ready (for Intel & AMD)
F3-1600C9Q-32GSR - DDR3-1600 PC3 12800 32GB(8GBx4) CL 9-9-9-24-2N 1.5 Volts XMP Ready (for Intel & AMD)
F3-10666CL9D-8GBSR - DDR3-1333 PC3 10666 8GB(4GBx2) CL 9-9-9-24-2N 1.5 Volts
F3-10666CL9D-4GBSR - DDR3-1333 PC3 10666 4GB(4GBx1) CL 9-9-9-24-2N 1.5 Volts
(( Preisvergleich ))
G.Skill Sniper F3-12800CL9D-8GBSR2
8GB (2x4GB) DDR3 PC3-12800 CL9-9-9-24 1.25v
Spezifikationen
Produktseite: G.Skill F3-12800CL9D-8GBSR2
Preisvergleich: F3-12800CL9D-8GBSR2
Das SPD
News, Reviews & OC/UV-Werte
Bilder
		Type: DDR3
Voltage: 1.25V
Speed Spec: PC3-12800
Frequency: 1600MHz
Kapazität
Kit Type: Dual Kit
Kit Size: 8GB
Module Size: 4GB
Timings
tCL: 9
tRCD: 9
tRP: 9
tRAS: 24
Bauhöhe der Module: 42mm (zum Vergleich Module ohne HS 30mm)
Kompatibilität
- Intel LGA1156 (offiziell, Spezifikationen)
 - Intel LGA1155 (offiziell, Spezifikationen)
 - Intel LGA1366 (offiziell, laut Press Release)
 - AMD AM3 (getestet: Big Bruin Review)
QML / CML (Stand 14.04.2011)
ASUS Maximus IV Extreme
ASUS SABERTOOTH P67
ASUS P8P67 DELUXE
ASUS P8P67 EVO
ASUS P8P67 PRO
ASUS P8P67-M PRO
ASUS P8P67-M
ASUS P8P67 LE
ASUS P8P67
Gigabyte GA-P67A-UD7
Gigabyte GA-P67A-UD5
Gigabyte GA-P67A-UD4
Gigabyte GA-P67A-UD3P
Gigabyte GA-P67A-UD3R
ASRock Fatal1ty P67 Professional
ASRock P67 Extreme 6
ASRock P67 Extreme 4
ASUS Maximus III Formula
ASUS Maximus III Gene
ASUS P7P55D-E Premium
ASUS P7P55D-E Deluxe
ASUS P7P55D-E EVO
ASUS P7P55D-E Pro
ASUS P7P55D-E
ASUS P7P55D Premium
ASUS P7P55D Deluxe
ASUS P7P55D EVO
ASUS P7P55D Pro
ASUS P7P55D
EVGA P55 Classified 200
EVGA P55 FTW 200
MSI P55-GD65
MSI P55-GD80
Gigabyte GA-P55A UD3P
Gigabyte GA-P55A UD3R
Gigabyte GA-P55A UD4
Gigabyte GA-P55A UD4P
Gigabyte GA-P55A UD5
Gigabyte GA-P55A UD6
Gigabyte GA-P55 UD3P
Gigabyte GA-P55 UD3R
Gigabyte GA-P55 UD4
Gigabyte GA-P55 UD4P
Gigabyte GA-P55 UD5
Gigabyte GA-P55 UD6
Features
- Dual Channel Kit
 - Pitch Black Sniper Heatsink
 - Black PCB
 - Lifetime Warranty
Das SPD
Standard Profile
JEDEC Profil 1: 622 MHz 7-7-7-22 / 29-100-4-10-5-5 (CAS-RCD-RP-tRAS / RC-RFC-RRD-WR-WTR-RTP)
JEDEC Profil 2: 711 MHz 8-8-8-25 / 33-114-5-11-6-6 (CAS-RCD-RP-tRAS / RC-RFC-RRD-WR-WTR-RTP)
JEDEC Profil 3: 800 MHz 9-9-9-28 / 37-128-5-12-6-6 (CAS-RCD-RP-tRAS / RC-RFC-RRD-WR-WTR-RTP)
XMP Revision: 1.2
JEDEC XMP-1600 Profil: 800 MHz 9-9-9-25 / 40-130-5-12-6-6 2T @ 1.25v (CAS-RCD-RP-tRAS / RC-RFC-RRD-WR-WTR-RTP)
CPUz Screen:
CPU Tweaker Screen:
Für diese Angaben übernehme ich keine Gewähr.
Hardwareluxx News: G.Skill mit neuen Speichermodulen und Sandforce 2000 (LINK)
WWW Reviews
OC Ergebnisse aus dem Pak Review:
Ergebnisse aus dem Sammelthread
1) ataridelta9 :: DDR3-1950 CL9 1.5v :: SandyBridge :: Screen
2) ataridelta9 :: DDR3-2133 CL9 1.65v :: SandyBridge :: Screen
3) User :: Takt / Timings / Spannung :: Plattform :: Screen
Bilder
