NVIDIA Geforce GTX 580/480/470/465/460/450 BIOS Files (2)
ja - bitte schön:
Edge
  • EVGA GTX 460 1GB SC - BIOS 70.04.13.00.72 @ 800-1600-2200MHz @ 1.000V, unlocked, Fan 40 - 100%.zip
@ Edgecrusher86
Habe jetzt die 0,825V für 2D & 0,8375V für 3D genommen.
750/1500/1800@1V funzt prima.
Weniger habe ich nicht mehr getestet, da mir die Werte so passen.
Bleibt sogar noch Spielraum bis 800@1V :d
Nochmals vielen Dank für die umfangreiche Hilfe ;)
@ Edgecrusher86
I'm a man that come from thailand , Can u remember ? eiei
I'm come back with my new msi gtx 465 twin frozr II golden edition
i want your help to flash my bios to 470 twin frozr
@ 700-1400-1750 MHz ,unlocked voltage and 100%fan @ 80 celsius
@ 800-1600-2000 MHz ,unlocked voltage and 100%fan @ 80 celsius
thx so much , :hail::hail::hail:
  • 470G_TWINFROZRII.zip
Hello taukung - yes, I can remember -> the guy with a lots of graphics cards and who likes to say eiei. :d
In general a GTX 465 which was flashed successfuly to a GTX 470 needs a higher VCore to run stable with these default specs, so I made 5 Versions - starting from 1.000V to 1.050V ->
all at default clocks for a start. :)
Then you can test like you did before with the other cards which VCore your new card needs for your goal clocks. After that I can deliver the OC-Versions. :)
Mine (PoV GTX 465@470) needs 1.000V @ default and also 700-1400-1700 MHz run stable. To reach 800-1600-1800 MHz I have to set 1.075V.
greetings
Edge
  • MSI N465GTX Golden Edition @ N470GTX TF II @ default @ 1.000V, unlocked.zip
  • MSI N465GTX Golden Edition @ N470GTX TF II @ default @ 1.012V, unlocked.zip
  • MSI N465GTX Golden Edition @ N470GTX TF II @ default @ 1.025V, unlocked.zip
  • MSI N465GTX Golden Edition @ N470GTX TF II @ default @ 1.037V, unlocked.zip
  • MSI N465GTX Golden Edition @ N470GTX TF II @ default @ 1.050V, unlocked.zip
Hallo, bin neu hier und wollte fragen ob jemand das Bios
für meine Msi GTX460 Cyclone 1GB editieren kann.
Wär super, wenn ich den Lüfter unter 40% regeln könnte
und noch besser wenn der sich im Idle automatisch so auf sagen wir mal 30% regelt?
Ich weiß das hier schon so ein Bios für die Cyclone gepostet
wurde, aber ich denke das war eine alte Bios Version und
ich hab halt das neue F1.
Vielen Dank schonma
Sorry für Doppelpost, aber hab nicht geschnallt wie ich ne Datei anhänge. Ist direkt vom Msi Forum.
hier ist das File:
  • N460GTX_Cyclone_1GB_1F1.zip
Hi - willkommen im Forum ! :wink:
bitte schön - ja, das Release-Datum ist neuer (das erste BIOS datiert vom 01.07.), vielleicht wurde
das Verhalten der Lüftersteuerung etwas überarbeitet - zumindest die BIOS-Nr. ist noch identisch:
Edge
  • MSI N460GTX Cyclone 1GB - BIOS 70.04.13.00.00 (F1) @ default, Fanspeed 30 - 100%.zip
Das ist sehr nett von dir @Edgecrusher86.
Ich kanns jetzt nicht gleich ausprobieren,
aber eilt auch nicht die is eh schon kaum zu hören.
Mir wars halt wichtig ein passendes Bios zu haben,
falls ichs doch mal leiser haben möchte.
Hilft sicher auch anderen weiter, vor allem für das
Bios muss man sich derzeit noch im MSI forum
registrieren.
Also fettes THX!!!
Hallo zusammen,
wollte mal fragen, ob es eigentlich möglich ist, das Bios von der Gigabyte GV N470SO-13I einfach auf die GV N470D5-13I zu flashen ? Oder sollte ich die Werte vorher lieber manuell ausprobieren? Die Karte wird mit nem AquagraFX gekühlt, wenn sie dann morgen endlich bei mir ist. Der olle Hermes-Onkel hatte wohl gestern keinen Bock mehr ...
Gern geschehen, Jungs ! ;)
@ BomberPilot: Wäre sicherlich möglich, aber ich würd dann am besten gleich das BIOS deiner Karte als Grundlage nehmen (müsste wohl das NV-Referenzbios sein - also das 70.00.21.00.03er) - unter Wasser kannst du dann eh locker 800/1600/1800(+) MHz fahren, was dann nochmal so 10% vor der Werks-SOC wäre. ;)
Edge
Erstmal absolut großes Lob für Edges Userspirit :wink: .
Werde die Tage auch mal mit einem EVGA GTX460-Bios "nerven" , wenn ich die Karte ausgelotet habe.
@ Edgecrusher86
mine stable with
core-shader-mem : 700-1400-1750 Mhz @ default @ 1.087V
( with horrible voltage eiei )
if u can unlock fan speed , just set to 50-80%
thx so much ....
@ BikerKS: Danke - dann bis später ! ;)
@ taukung: What a pity, that's a very high VCore indeed. :-/
Sorry, the fanspeed range can't be edited with GF100 BIOS files (at least right now).
You may use MSI Afterburner instead and apply a custom setting at system startup for example.
greetings
Edge
  • MSI N465GTX Golden Edition @ N470GTX TF II @ 700-1400-1750MHz @ 1.087V, unlocked.zip
Gibts schon irgendwas neues an der Front zwecks gtx 470 und Lüftersteuerung per Bios?
Edge
Ah, das klingt gut, werde ich Dir dann direkt zuschicken. Allerdings ist die Karte heute nicht gekommen, der Hermes-Kutscher konnte am Samstag angeblich die Adresse nicht finden :-( .... kommt jetzt wohl am Mittwoch ... das Bios müsste dann eh noch für 2 Monitore modifiziert werden.
@Edgecrusher86
Ist echt toll, was du dir hier für Mühe gibst. Ich hätte da auch eine Frage. Ich besitze seit Samstag die MSI N460GTX Cyclone 1GD5/OC. Habe auch schon das F1 BIOS geflasht. Leider bekomme ich damit die Lüfterdrehzahl nicht unter 40%, mein Ziel wären etwa 30%. Übertakten usw. möchte ich eher nicht.
Jetzt habe ich gesehen, dass du in deinem Posting 157 eine neuere Version angegeben hast. Kann ich die so wie sie ist übernehemen?
  • MSI N460GTX Hawk - BIOS 70.04.13.00.01 @ default, unlocked (1.200V).zip
hmm, seltsam.
Hab Afterburner 2.0 drauf und kann maximal 1,090v geben, gemessen mit dem multimeter, @load sind das ~1,12v
thx, werds mal testen. :)
@Edgecrusher86
Okay, danke. Habe das BIOS geflasht, funzt einwandfrei. Lüfter kann man jetzt auf 30% runterregeln.
Hm - unter Umständen hatte nur die 2.0.0 Beta 6 bei der Hawk das höhere Limit - das weiß ich nicht genau (immerhin wurde ja die Presse auch damit beliefert :d):
Anyway, I spoke to MSI and they gave me V2.0 Beta6 which unlocked all the goodies. This let us increase the voltage on the Core, Memory and AUX; the three things we can monitor with the included cables.
It also let us go above the standard 1.087v max limit that is imposed by the normal Afterburner on other cards. Instead it let us go to +.2v. MSI actually told us that each GTX 460 has a bit of fluctuation when it comes to the default core clock. The particular one we had came at 1.062v which was on the higher side of things, so +200mv gave us 1.262v; much higher than the standard 1.087v limit that we're used to seeing.
Denn die 1.090V, die du gemessen hast, werden bestimmt die für gewöhnlich maximalen 1.087V im Tool sein.
Dann kommste nach dem Flash auf jeden Fall höher. ;)
@ donalfonso: Gern geschehen. :)
Edge
BIOS für eine MSI GeForce GTS 450 Cyclone 1024MB
Habe seit 2 Tagen eine MSI GeForce GTS 450 Cyclone 1024MB. Die läuft soweit prima. Allerdings würde ich die Fan min gerne unter 40% senken- 20% wäre schon sehr super. Geht das schon? Ich wollte das mit NiBiTor versuchen, aber das erkennt die Karte (noch) nicht. Anbei eine Kopie von dem BIOS dieser Karte. Ich wäre froh, wenn mir jemand weiterhelfen könnte.
  • GF106.zip
Fan 20-100%, Rest untouched
  • GF106mod.zip
  • EVGA.zip
hi nochmal :). an diesen beiden biosfiles würd ich gern nur um ein paar kleine nachbesserungen bitten.
ein mal die 768er: nur den fan auf 60-100 ändern
zweites mal die 786er: voltage 1.037 und 60-100% fan
die 1gb: voltage auf 0.987 ändern
danke :hail:
  • EVGA GTX 460 768 MB - BIOS 70.04.0B.00.60 @ 870-1740-2250MHz @ 1.025V, unlocked, Fan 70 - 100%.zip
@ BikerKS:
Servus,
bitte schön:
Edge
  • EVGA GTX 460 1024 MB - BIOS 70.04.13.00.76 @ 840-1680-2050 MHz @ default VCore, Fanspeed 20 - 7.zip
  • EVGA GTX 460 1024 MB - BIOS 70.04.13.00.76 @ 840-1680-2050 MHz @ default VCore, Fanspeed 25 - 7.zip
  • EVGA GTX 460 1024 MB - BIOS 70.04.13.00.76 @ 840-1680-2050 MHz @ default VCore, Fanspeed 30 - 75.zip
@ Jax47:
Bitte schön:
Edge
  • EVGA GTX 460 768 MB - BIOS 70.04.0B.00.60 @ 870-1740-2250MHz @ 1.025V, unlocked, Fan 60 - 100%.zip
  • EVGA GTX 460 768 MB - BIOS 70.04.0B.00.60 @ 870-1740-2250MHz @ 1.037V, unlocked, Fan 60 - 100%.zip
  • EVGA GTX 460 1GB SC - BIOS 70.04.13.00.72 @ 800-1600-2200MHz @ 0.987V, unlocked, Fan 40 - 100%.zip
