[blockquote]
Inhalt des Sammelthreads
Spezifikationen Spezifikationen
CPU
Erste OC ErgebnisseErste OC Ergebnisse
Ersten eigenen OC Ergebnisse mit einem Retail Core i7-920 & Geforce 8800GTS G92 SLI
Voltage ModsVoltage Mods & read Points
*Jede Modifikation geschieht auf eigene Gefahr und führt zum erlöschen der Garantie!
DownloadsDownloads
Das Flashen geschieht wie immer auf eigene Gefahr!
Bios Downloads EX58-UD5
Wichtige InformationenWichtige Informationen
Wichtige LinksWichtige Links
[/blockquote]
CPU
- LGA 1366 socket for:
- Intel® Core i7 920/940 & 965XE
- Northbridge:
- Intel® X58 Express chipset - Southbridge:
- Intel® ICH10R
- 6 x DIMM, Max. 24 GB, DDR3 2130(*)/1860(*)/1600(*)/1333/1066/800
- Triple Channel memory architecture
*Overclock speed
- Supports Intel® Extreme Memory Profile (XMP)
- 3 x PCIe 2.0 x16 (support x16/x16 or x16/x8/x8)
- 1 x PCIe x4
- 1 x PCIe x1
- 2 x PCI 2.2
- Dual-Bios
- HD Audio, 8-channel
- South Bridge:
- 6 x SATA 3Gb/s connectors (SATA2_0, SATA2_1, SATA2_2, SATA2_3, SATA2_4, SATA2_5) supporting up to 6 SATA 3Gb/s devices
- Support for SATA RAID 0, RAID 1, RAID 5, and RAID 10 - GIGABYTE SATA2 chip:
- 1 x IDE connector supporting ATA-133/100/66/33 and up to 2 IDE devices
- 2 x JMB322 chips (Smart Backup):
- 4 x SATA 3Gb/s connectors (GSATA2_0, GSATA2_1, GSATA2_2, GSATA2_3) supporting up to 4 SATA 3Gb/s devices (Note 5)
- Support for SATA RAID 0, RAID 1 and JBOD - iTE IT8720 chip:
- 1 x floppy disk drive connector supporting up to 1 floppy disk drive
- 1 x 24-pin ATX main power connector
- 1 x 8-pin ATX 12V power connector
- 1 x IDE connector
- 10 x SATA 3Gb/s connectors
- 1 x CPU fan header
- 3 x system fan headers
- 1 x power fan header
- 1 x North Bridge fan header
- 1 x front panel header
- 1 x front panel audio header
- 1 x CD In connector
- 1 x S/PDIF In header
- 1 x S/PDIF Out header
- 2 x USB 2.0/1.1 headers
- 2 x IEEE 1394a headers
- 1 x power LED header
- 1 x chassis intrusion header
- 1 x power switch
- 1 x reset switch
- 1 x PS/2 keyboard port
- 1 x PS/2 mouse port
- 1 x coaxial S/PDIF Out connector
- 1 x optical S/PDIF Out connector
- 1 x IEEE 1394a port
- 1 x clearing CMOS switch
- 8 x USB 2.0/1.1 ports
- 2 x RJ-45 ports
- 6 x audio jacks (Center/Subwoofer Speaker Out/Rear Speaker Out/Side Speaker Out/Line In/Line Out/Microphone
- Dynamic Energy Saver Advanced
- Ultra Durable 3
- Dynamic 6-Gear Swithching
- 45nm CPU Optimized
- 3 way CrossFireX
- 3 way SLI support
- Debug LED
- Dolby Home Theater
- Blu-ray Support
- OV-Alert LED, OC-Alert LED, TMP-Alert LED
- Hybrid Silent-Pipe 2 (nur das Extreme!)
DownloadsDownloads
- Bios F2
- Auslieferungsbios - Bios F3
- Fix CPU compatibility issues - Bios F4
- Fix S3 resume turbo mode issue
- Fix DualBIOS recovery issue
- improve System Stability - Bios F5
- Improve VGA card compatibility
- Improve S3 resume compatibility
- Intel®Core™ i7 processor D-0 stepping support - Bios F6a (beta / Testversion)
- keine Changelog - Bios F6b (beta / Testversion)
- Fix: QPI/Vtt Kaltstart Bug größer 1.280V
- Bug: S3 fehlerhaft (E1) bei OC - Bios F6c (beta / Testversion)
- Info: Neue Intel® AHCI ROM Version 1.20E... keine Wartezeit mehr !!!
- Bug: S3 bei OC teilweise immer noch fehlerhaft (E1)... er wird daran gearbeitet !
- Bios F3
- Intel®Core™ i7 processor D-0 stepping support - Bios F6c (beta / Testversion)
- Bug: S3 fehlerhaft (E1) bei OC - Bios F6d (beta / Testversion)
- Info: Erfolgreich geflasht...
- Bug: S3 bei OC teilweise immer noch fehlerhaft (E1)... er wird daran gearbeitet ! - Bios F6e (beta / Testversion)
- keine Changelog
- Achtet auf die Speicheranordnung, wenn die Riegel in den falschen Slots sind bootet das Mainboard nicht (hat mit dem IMC der CPU zu tun!)
- Dazu bitte Seite 16 im Handbuch nachschlagen.
- Gigabyte GA-EX58-UD5 Review @ OCWorkBench
- Gigabyte X58 Overview
- Link zur Gigabyte Homepage
- Gigabyte GA-EX58-UD5 bei Geizhals
- 5 Jahre Garantie fürs Gigabyte GA-EX58-UD5 (PDF / Formular)
- 6 Jahre Garantie fürs Gigabyte GA-EX58-Extreme (PDF / Formular)
. Ich bin kein Fachmann doch habe Ich eine Vermutung, was diese nervigen Geräusche verursachen könnte. Zumindest war es bei Mir so.
