Controller ID: 0 Unexpected sense: PD
= 0:3 - Power on, reset, or bus device reset occurred, CDB = 0x2a 0x00 0x2b 0x57 0x72 0x00 0x00 0x01 0x00 0x00 , Sense = 0x70 0x00 0x06 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x29 0x00 0x00 0x00 0x00 0x00
ID = 2771
SEQUENCE NUMBER = 4643
TIME = 15-04-2010 17:29:20
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = 0:3 - Invalid field in CDB, CDB = 0x4d 0x00 0x4d 0x00 0x00 0x00 0x00 0x00 0x20 0x00 , Sense = 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x24 0x00 0x00 0x00 0x00 0x00
ID = 2770
SEQUENCE NUMBER = 4642
TIME = 15-04-2010 17:29:03
LOCALIZED MESSAGE = Controller ID: 0 Patrol Read complete
ID = 2769
SEQUENCE NUMBER = 4641
TIME = 15-04-2010 17:29:02
LOCALIZED MESSAGE = Controller ID: 0 State change: PD = 0:3 Previous = Offline Current = Rebuild
ID = 2768
SEQUENCE NUMBER = 4640
LOCALIZED MESSAGE = Controller ID: 0 Rebuild automatically started: PD 0:3
ID = 2767
SEQUENCE NUMBER = 4639
LOCALIZED MESSAGE = Controller ID: 0 State change: PD = 0:3 Previous = Unconfigured Good Current = Offline
ID = 2766
SEQUENCE NUMBER = 4638
TIME = 15-04-2010 17:29:01
LOCALIZED MESSAGE = Controller ID: 0 State change: PD = 0:3 Previous = Unconfigured Bad Current = Unconfigured Good
ID = 2765
SEQUENCE NUMBER = 4637
LOCALIZED MESSAGE = Controller ID: 0 Drive is not certified: 0:3
ID = 2764
SEQUENCE NUMBER = 4636
LOCALIZED MESSAGE = Controller ID: 0 Device inserted Device Type: Disk Device Id: 0:3
ID = 2763
SEQUENCE NUMBER = 4635
LOCALIZED MESSAGE = Controller ID: 0 PD inserted: 0:3
ID = 2762
SEQUENCE NUMBER = 4634
TIME = 15-04-2010 17:28:24
LOCALIZED MESSAGE = Controller ID: 0 State change: PD = 0:3 Previous = Failed Current = Unconfigured Bad
ID = 2761
SEQUENCE NUMBER = 4633
LOCALIZED MESSAGE = Controller ID: 0 State change: PD = 0:3 Previous = Online Current = Failed
ID = 2760
SEQUENCE NUMBER = 4632
LOCALIZED MESSAGE = Controller ID: 0 VD is now DEGRADED VD 0
ID = 2759
SEQUENCE NUMBER = 4631
LOCALIZED MESSAGE = Controller ID: 0 State change on VD: 0 Previous = Optimal Current = Degraded
ID = 2758
SEQUENCE NUMBER = 4630
LOCALIZED MESSAGE = Controller ID: 0 Device removed Device Type: Disk Device Id: 0:3
ID = 2757
SEQUENCE NUMBER = 4629
LOCALIZED MESSAGE = Controller ID: 0 PD removed: 0:3
ID = 2756
SEQUENCE NUMBER = 4627
TIME = 15-04-2010 17:28:06
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = 0:3 - Invalid field in CDB, CDB = 0x15 0x11 0x00 0x00 0x10 0x00 , Sense = 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x24 0x00 0x00 0x00 0x00 0x00
ID = 2755
SEQUENCE NUMBER = 4626
ID = 2754
SEQUENCE NUMBER = 4625
TIME = 15-04-2010 17:28:03
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = 0:3 - Power on, reset, or bus device reset occurred, CDB = 0x2a 0x00 0x2b 0x57 0x72 0x00 0x00 0x01 0x00 0x00 , Sense = 0x70 0x00 0x06 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x29 0x00 0x00 0x00 0x00 0x00
Die Dauer des Rebuilds hängt nur von d. Größe d. Arrays und der Performance der HDDs/Controllers ab.
Hast du mal mit Hutil getestet, ob die Hdd einen weg hat?
.. aber so machen es alle
An der Verkabelung solltest du das erkennen können welche Platte im LSI Manager gemeint ist.Da wird jawohl eine Platte das Zeitliche gesegnet haben.....
Woher weiß ich den welche !?
ich will nedd wissen wieviele fehlerhafte HDDs immer noch als i.O angesehen werden. des weiteren würd ich bei großen kapazitäten dann vielleicht doch über TLER nachdenken... auch wenns deutlich mehr kostetso wie es aussieht sinds scheinbar die disks an anschluss 1 und 2 des controllers.
wenn nur eine disk im array fehlt (normal müsste dann da degraded und nicht offline stehen!? failed stand bei der alten version die ich nutze dort, wenn zwei disks gedroppt wurden) wäre das ne option. ich würde dir raten erstmal alle disks einzeln mit dem herstellertool im "extended test" (o.ä.), welcher auch die platten auch einmal komplett überschreibt zu überprüfen. danach die smart-werte anguggen und erst danach das R5 aufsetzen
ohne jetzt viel zu schreiben: dir ist bewusst, dass ich in deinem fall nicht ruhig schlafen könnte?![]()
Witzbold, ich werde das RAID JETZT Offline nehmen und dann Platte 0 an einem anderen Rechner Testen.......
Was bleibt mir anderes übrig !? Ich kann keine 3TB auslagern.
Wenn eine Platte Defekt ist muss ich wohl meine übrige 1TB Platte anschließen, ich weiß nur nicht ob da nicht noch mehr Defekt sind weil er immer was von "PD = 0" und "PD = 1" redet und mir hier ja keiner sagt wie aus dem Log herraus lesen kann welchen Anschluss er meint.
