[Sammelthread] Asus P6X58D Premium (Intel X58)
P6X58D Premium
Best Choice for Extreme Overclocking and Future Transfer Technology!
•Intel® LGA1366 Platform & Intel® X58/CH10R chipset
•Next Gen 32nm 6-Core Processor Ready!
•True USB3.0 and SATA 6Gb/s Support!
•ASUS True 16+2 Phase Power Design
•3-Way SLI & Quad-GPU CrossFireX Support!
•MemOK!
CPU, Chipset and Graphics features
LGA1366 Intel® Bloomfield Processor Ready
This motherboard supports the latest Intel® Core™ i7 processors in LGA1366 package with integrated memory controller to support 3-channel (6 DIMMs) DDR3 memory. Supports Intel® QuickPath Interconnect (QPI) with a system bus of up to 6.4 GT/s and a max bandwidth of up to 25.6 GB/s. Intel® Core™ i7 processor is one of the most powerful and energy efficient CPUs in the world.
3-Way SLI and Quad-GPU CrossFireX Support!
Flexible Multi-GPU solutions, Your Weapon of Choice!
The P6X58D Premium breaks the boundaries to bring you the multi-GPU choice of either SLI™ or CrossFireX. The motherboard features a dedicated graphics engine on the most powerful Intel X58 platform to optimize PCIe allocation in multiple GPU configurations. Expect a brand-new gaming style you’ve never experienced before!
Intel X58
The Intel® X58 Express Chipset is one of the most powerful chipset designed to support the Intel® Core™ i7 Processors with LGA1366 package and Intel® next generation system interconnect interface, Intel® QuickPath Interconnect (QPI), providing improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. It also supports up to 36 PCI Express 2.0 lanes providing better graphics performance.
PCIe 2.0
Double Speed; Double Bandwidth
This motherboard supports the latest PCIe 2.0 devices for double speed and bandwidth which enhances system performance.
.Future Transfer Technology
True SATA 6Gb/s Support
Experience the Future of Storage!
Supporting next-generation Serial ATA (SATA) storage interface, this motherboard delivers up to 6.0Gb/s data transfer rates. Additionally, get enhanced scalability, faster data retrieval, double the bandwidth of current bus systems.
True USB 3.0 Support
10X Faster Date Rates!
Experience ultra-fast data transfers at 4.8Gbps with USB 3.0—the latest connectivity standard. Built to connect easily with next generation components and peripherals, USB 3.0 transfers data 10X faster and is also backward compatible with USB 2.0 components.
Memory Feature
Triple-Channel DDR3 2000(O.C.) / 1333 / 1066 support
The motherboard supports DDR3 memory that features data transfer rates of 2000(O.C.) / 1333 / 1066 MHz to meet the higher bandwidth requirements of the latest 3D graphics, multimedia, and Internet applications. The triple-channel DDR3 architecture enlarges the bandwidth of your system memory to boost system performance.
ASUS Xtreme Phase
True ASUS 16+2 Phase Power Design
Unprecedented Innovation with the Best Quality Component for Best Performance
The groundbreaking 16+2 phase VRM design is brrought to the ASUS motherboards. 16+2 phase power design, 16-phase for vCore and extra 2-phase for QPI/Memory controller inside CPU, can provide the highest power efficiency, and hence generates less heat to effectively enhance the overclocking capability. With the high quality power components such as low RDS (on) MOSFETs, Ferrite core chokes with lower hysteresis loss and 100% Japan-made high quality conductive polymer capacitors, ASUS 16+2 phase VRM design also ensure longer component life and minimum power loss.
ASUS Exclusive Overclocking Feature
ASUS TurboV
New OC Records with Real-Time Super-precise Tunings
Feel the adrenaline rush of real-time OC - now a reality with the ASUS TurboV. This extreme OC tool lets you set new ambitions on the OC stage with an advanced and easy-to-use interface - allowing you to overclock without exiting or rebooting the OS. With micro adjustments of the CPU PLL, NB, NB-PCIe, and DRAM voltages in 0.02v intervals, there are no limits - only extreme results to break new OC records!
ASUS Exclusive Features
ASUS EPU
System Level Energy Saving
The new ASUS EPU - the world´s first power saving engine, has been upgraded to a new six engine version, which provides total system power savings by detecting current PC loadings and intelligently moderating power in real-time. With auto phase switching for components (which includes the CPU, VGA card, memory, chipset, drives and system fan), the EPU automatically provides the most appropriate power usage via intelligent acceleration and overclocking - helping save power and money.
ASUS Express Gate SSD
0 to Internet in Seconds!
Express Gate™ is an ASUS exclusive OS that provides you with quick access to the Internet and key applications before entering Windows®.
MemOK!
Any Memory is A-OK!
MemOK! quickly ensures memory boot compatibility. This remarkable memory rescue tool requires a mere push of a button to patch memory issues. MemOK! determines failsafe settings and dramatically improves your system boot success. Get your system up and running in no time!
.ASUS Quiet Thermal Solution
ASUS Fanless Design - Heat-pipe solution
The Heat Pipe design effectively directs the heat generated by the chipsets to the heatsink near the back IO ports, where it can be carried away by existing airflow from CPU fan or bundled optional fan. The purpose of the innovative heat pipe design on this motherboard is that the groundbreaking fanless design does not have lifetime problems as a chipset fan does. Furthermore, it provides options for users to install side-flow fan or passive cooler. The Heat Pipe design is the most reliable fanless thermal solution to date.
Fan Xpert
Active Quiet & Cool
ASUS Fan Xpert intelligently allows users to adjust both the CPU and chassis fan speed according to different ambient temperature , which is caused by different climate conditions in different geographic regions and system loading.Built-in variety of useful profiles offer flexible controls of fan speed to achieve a quiet and cool environment.
Up to 20°C(36°F) Cooler - Stack Cool 3+
Effective Fanless Heat Dissipation at 0dB
Stack Cool 3+ is a fanless cooling solution offered exclusively by ASUS. It effectively and noiselessly transfers heat generated by the critical components to the other side of the specially designed PCB (printed circuit board) for effective heat dissipation - making temperatures cooler by up to 20°C.
.ASUS Crystal Sound
DTS Surround Sensation UltraPC
DTS Surround Sensation UltraPC delivers exceptional 5.1 surround experience through the most common PC audio setups - your existing stereo speakers or headphones. In addition to virtual surround, “Bass enhancement” provides stronger low frequency bass sound, and “Voice clarification” provides clear human dialogue even with loud background sound. With these technologies, you may experience a better home-theater audio with ease.
Noise Filter
Eliminate background noise while recording
This feature detects repetitive and stationary noises like computer fans, air conditioners, and other background noises then eliminates it in the incoming audio stream while recording.
.ASUS EZ DIY
ASUS Onboard Switch
With an easy press during overclock, this exclusive onboard switch allows gamer to effortless fine-tune the performance without having to short the pins!
Q- Shield
Easy and Comfortable Installations
The specially designed ASUS Q-Shield does without the usual "fingers" - making it convenient and easy to install. With better electric conductivity, it ideally protects your motherboard against static electricity and shields it against Electronic Magnetic Interference (EMI).
EZ-Flash 2
Simply update BIOS from a USB flash disk before entering the OS
EZ Flash 2 is a user-friendly BIOS update utility. Simply launch this tool and update BIOS from a USB flash disk before entering the OS. You can update your BIOS only in a few clicks without preparing an additional floppy diskette or using an OS-based flash utility.
ASUS Q-Design
DIY quickly, DIY easily!
ASUS Q-Design enhances your DIY experience. All of Q-LED, Q-Slot and Q-DIMM design speed up and simplify the DIY process!
Q-Connector
Make connection quick and accurate!
The ASUS Q-Connector allows you to connect or disconnect chassis front panel cables in one easy step with one complete module. This unique adapter eliminates the trouble of plugging in one cable at a time, making connection quick and accurate.
O.C. Profile
Conveniently store or load multiple BIOS settings
Freely share and distribute favorite overclocking settings The motherboard features the ASUS O.C. Profile that allows users to conveniently store or load multiple BIOS settings. The BIOS settings can be stored in the CMOS or a separate file, giving users freedom to share and distribute their favorite overclocking settings.
.Industry Standard
IEEE 1394a interface
IEEE 1394a interface provides high speed digital interface for audio/video appliances such as digital television, digital video camcorders, storage peripherals & other PC portable devices.
S/PDIF-out on Back I/O Port
This motherboard provides convenient connectivity to external home theater audio systems via coaxial and optical S/PDIF-out (SONY-PHILIPS Digital Interface) jacks. It allows to transfer digital audio without converting to analog format and keeps the best signal quality.
.RoHS
GreenASUS
The motherboard and its packaging comply with the European Union´s Restriction on the use of Hazardous Substances (RoHS). This is in line with the ASUS vision of creating environment-friendly and recyclable products and packaging to safeguard consumers´ health while minimizing the impact on the environment.
Geizhals Link
http://preisvergleich.hardwareluxx.de/a495774.html
Treiber&Tools
http://support.asus.de/download/download.aspx?SLanguage=de-de
Bios Downloadlink
ftp://ftp.asus.com.tw/pub/asus/mb/lga1366/P6X58D_Premium/
Bios History
[ 0703 ]
1. Improve system stability
2. Support new CPUs. Please refer to our website at: http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
[ 0702 ]
Support new CPUs. Please refer to our website at:http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
[ 0604 ]
Fix DRAM Voltage is abnormal in TurboV
[ 0506 ]
[ 0402 ]
1.Enhance OC Profile storage space from 2 to 8 slots.
2.Enable instant display of Target CPU & DRAM Frequency under Ai Tweaker
[ 0301 ]
First release Bios
CPU Support Liste
Core i7 920(2.66G,L2:4x256KB,L3:8M, rev.C0,130W) ALL 0301
Core i7 920(2.66G,L2:4x256KB,L3:8M, rev.D0,130W) ALL 0301
Core i7 940(2.93G,L2:4x256KB,L3:8M, rev.C0,130W) ALL 0301
Core i7 950(3.06G,L2:4x256KB,L3:8M, rev.D0,130W) ALL 0301
Core i7 960(3.2G,L2:4x256KB,L3:8M, rev.D0,130W) ALL 0301
Core i7 Extreme Edition 965(3.20G,L2:4x256KB,L3:8M, rev.C0,130W) ALL 0301
Core i7 Extreme Edition 975(3.33G,L2:4x256KB,L3:8M, rev.D0,130W) ALL 0301
Bilder des Boards
also hab das mit den 4,4ghz zwar zum laufen bekommen aber nicht mit prime95 da kackt er direkt nach 10sek ab...meiner rennt absolut stabil mit 4,2ghz und einen lüfter aufm cpu kühler
dann hast du hier paar sachen im bios aktiviert wo ich mich selbst frage....für was oc wenn das an ist.... Intel Speed Step Technology.....das OS taktet doch dann dein CPU hoch und runter wie es ihn momentan benötigt oder liege ich da falsch?
Hmm,
wie kann ich das Board mit Standardspannung übertakten, ohne dass das Board die Spannung miterhöht und ohne dass ich die vCore festsetzen muss?
@timosu
das mit dem Intel Speed Step Technology hast du theoretisch Recht.
Hab das auch nur so von hier übernommen: Hardwareoverclock.com | Intel Core i7 920 Stepping C0 Overclocking Anleitung, Übertakten
Praktisch bleibt der Takt aber selbst im Idle ohne sich zu verändern.
Anders sieht das aus wenn C1E aktiviert ist, dann taktet er mir die CPU runter.
@Cumulonimbus
Das Board erhöht die Spannung beim OC immer automatisch.
Darum sollte man auch bei extremen OC auch die CPU PLL und die QPI/DRAM Voltage und auch die DRAM Bus Voltage selber einstellen, da das Board sonst übervoltet.
Ist aber in der Anleitung von hardwareoverclock gut beschrieben.
Die benützen zwar ein P6T, welches sich aber in der Hinsicht fast nicht unterscheidet.
so ich habs mal getestet.... ganz wichtig war bei mir das ich physX installiere weil unter win7 wird das wohl nicht automatisch mitinstalliert...nun hab ich ich auch gute werte.... ohne oc von ram und ohne oc von graka!
so nun mit GPU OC
Endlich hab ich das Board, erster eindruck ist Positiv jetzt gehts a´ns testen.
Wie habt ihr so Super Temperaturen?
Wasserkühlung?
Edit: Wie oder wo kann ich denn die lüfter steuern?
Ach und was ist bei euch den alles beleuchtet auf dem Board? Nur der Start und Reset Button?
ich das lian li x500 gehäuse und alle 4 verbauten 120er fans an meiner zalman lüftersteuerung!
keine wasserkühlung!!!
Sind das Load oder Idle Temps?
Was hastn du für nen CPU Kühler?
Also ich habe mit meinem i7 920 mit nem Corsair H50 Idle so um die 40 und Load bis 60 Grad.
Wenn ich takte geht es bis 80, da stimmt doch was nicht oder?
Gehäuse habe ich ein Silverstone Raven RV01.
Hab ich vllt zuwenig oder zuviel paste drauf?
...i7 920 mit nem Corsair H50 Idle so um die 40 und Load bis 60 Grad.
Ich hab im Idle 29-35° und unter Last 58-64° mit einem Noiseblocker TwinTec im Lian Li PC-60FN mit einer msi GTS250 1G OC, Lüftersteuerung im Bios vom P6X58D Prem. auf silent.
Ich denke 80° sind noch vertretbar. Regelt der Lüfter vom Kühler so weit runter im idle?
Also ich habe die Pumpe und die Lüfter an ner ext. Steurung sitzen, aber selbst wenn ich die aufdrehe is da nicht viel luft nach unten.
Paste habe ich die ARCTIC Silver 5 verwendet, die sollte doch eig. gut sein.
Obs vllt zu Viel oder zu wenig ist? (an Paste)?
also nach 10min Prime hab ich 85-90°C ....beim zoggn zb von Battlefield BC2 nach 2h so ca. 65°C....idle liegt bei mir auch so bei 38-45°C je nach kern.
kühler hab ich den noctua nh-u12p SE2 mit der standart paste was dabei war und nur einen von 2 lüfter verbaut
so nun hab ich quad sli mit 2x gtx 295 non oc und cpu auf 4ghz
nö net ganz....hab bisher eine gtx 295 auf wakü rennen bin noch auf der suche nachm zweiten wakü kühler für die zweite karte ^^
cpu folgt nächste woche auf wakü...und eben wohl ne laing ddc ultra da die wo gerade verbaut ist schon 3-4 jahre aufm buckel hat und so einige systeme durchstehen musste :-D
update:
cpu @wakü
beide gtx295 @wakü
laufe der nächste woche wird folgendes upgrade kommen:
- Austausch der Schläuche von 10/8mm auf 19/13mm
- Austausch Pumpe von Station auf Laing DDC Pro + AGB
- Einbau von Phobya G-Changer 120 Radiator
Willst Du das mit der Pumpe echt so lassen? Sieht furchtbar aus. Andere Wasserfarbe, andere Pumpe, zur Not anderes Case. Bei soviel Luxus sollte die Optik schon stimmen.;)
wenn du oben richtig lesen würdest dann würden nicht solche fragen auftauchen ;-)
werde die neue pumpe wohl extern aufm tisch mit dem shoggy hinstellen ;-)....und für was anderes case....manch anderer ist froh er hätte so ein gutes tststs
wasser hab ich hier 4l vom aquacomputer dp ultra in blau dastehen....passend zu den kühlern auf den spawa ^^
hehe.. Vorfreude ist die Schönste..
Bin gespannt, wie das Board so läuft.
@Timosu
Poste mal bitte ein Bild, wenn du deine neue Wakükonfig. fertig hast. Das Gehäuse ist wirklich gut, nur hat man da nicht so wahnsinnig viel Platz drinne.
Bin schon am überlegen meine 4 Tage alte Aquastream gegen eine Laing zu tauschen, da das Teil mir ein wenig Probleme bereiten könnte.
Laut einem review, bi nmir nicht mehr sicher welches, soll das Board eine sehr gute CPU-Performance bieten bei durchschnittlichem Speicherdurchsatz.
Könnt Ihr das bestätigen?
Hallo Leute,
ich habe mal eine Frage bezüglich des Arbeitsspeichers!
Verbaut habe ich Kingston KHX1600C8D3K3/6GX der eigentlich mit 1600 MHz laufen sollte
Zuerzeit läuft er aber nur mit 1333 Mhz, wenn ich ihn auf 1600 MHz takten möchte bekomme ich folgende Meldung vom Bios:
Select OK to use current DRAM voltage setting
Select Cancel to increase the DRAM voltage automatically if vour DTMMs require higher voltage
Jetzt zu meiner Frage, was soll ich hier einstellen?
Ich habe leider keine Ahnung was ich da machen muss
Beschreibung meines Systems, siehe unter Systeminfo!
Für euere Hilfe wäre ich dankbar
Gruss
Frengi
Hallo frengi
Vielleicht hilft dir das weiter:
Kann dir nicht sagen was dein RAM an Spannung braucht, das musst du schon selber rausfinden.
Aber normalerweise sind das ca. 1,6V. Achtung niemals mehr als 1,65V einstellen sonst raucht dir deine CPU ab!!!
Wichtig dabei ist, dass du die UCLK Freq. auf das doppelte wie die DRAM Freq. einstellst.
@noClone,
Danke für deine Hilfe!
jetzt klappts mit den 1600 MHz.
Habe ein Teil deiner Einstellungen übernommen, die Spannung habe ich vom Hersteller bekommen.
Gruss
Frengi
Wasn der Unterschied zwischen dem Board und dem P6X58D-E? Preislich ja ne ganze Menge!!
Gute Frage, denn ich ziehe momentan ebenfalls den Kauf eines der beiden Boards in Betracht.
Das P6X58D Premium ist seit November gelistet, das P6X58D-E erst seit April.
Auf der Asus Site kann man die beiden Boards miteinander vergleichen.
ASUSTeK Computer Inc.
Außer der Tatsache, dass das Premium Dual Gigabit Lan hat, sehe ich nach kurzer Betrachtung keinen Unterschied.
Dann ist das Premium ja ein Witz? Asus suggeriert bessere Overclockingfähigkeit? Aber mir fehlen da ein wenig die Argumente seitens Asus...
@ FastAnbdy
Unterschiede:
Sata6 Controller
P6X58D-E: Marvell 9128 (neuere Version + Raidunterstützung)
P6X58D Premium: Marvell 9123
Firewire Chip:
P6X58D-E: VIA VT6308P controller (ebenfalls neuer)
P6X58D Premium: VIA VT6308
LAN - Ports
P6X58D-E: 1 x Gigabit LAN
P6X58D Premium: 2 x Gigabit LAN
Physische Schalter:
P6X58D-E: POWER, MEM- OK, CMOS Reset
P6X58D Premium: POWER, MEM- OK, CMOS Reset, RESET
Ansonsten scheinen bis auf die Hetapipeverbindungen des Premiums und den oben beschriebenen leichten Unterschieden die Boardlayouts gleich zu sein. Aus meiner Sicht sind die Unterschiede nur marginal und haben keinen Einfluss auf OC
Also ich hatte beide Board hier, das Premium und das -E. Das Premium ging wieder zurück, weil es den Aufpreis nicht wert ist.
Folgende Unterschiede sind vorhanden:
- das -E hat nur einen LAN-Anschluss.
- das -E hat kein Asus Express Gate SSD Speicherchip auf dem Board, Asus Express Gate läuft beim -E nur über die Festplatte.
- das Premium und das -E haben beide den Marvell 9123 SATA3, RAID funktioniert zumindest beim -E, beim Premium habe ich es nicht ausprobiert, der Marvel ist zumindest mit SATA 2 Platten bzw. SSDs langsamer als der Intel ICH10R!
- die Kühlung der Chips ist minimal anders, auf beiden Boards aber so gut wie kein Unterschied bei den Temperaturen auszumachen.
- beim -E fehlt der Reset-Taster auf dem Board.
- auf dem -E ist, wie schon zuvor geschrieben, sogar ein neuerer Firewire-Chip dauf.
- das Layout ist bei beiden Boards 1 zu 1 identisch - somit sind beide gleich gut beim Overclocking.
- der Reset-Taster am Anschlussfeld ist auch beim -E drauf.
- dem -E liegt keine externe 2-port USB 2.0/eSATA Slotblende und keine zusätzlicher Lüfter bei.
- das Bios ist bei beiden identisch
Meine Wahl ist dann auf das -E gefallen, die Express Gate SSD brauche ich nicht, nie benutzt, diesen Quatsch - ein Lan reicht ebenfalls aus - die andere Kühlung, who cares - SATA 3 bei beiden Boards gleich, das -E macht Raid, den Lüfter und die zusätzliche Slotblende für USB/eSata brauche ich auch nicht, so was hat man rumfliegen - daher ging das Premium dann zurück. ;)
Grüße
Also meins fiept nicht.
Hatte dieses Fiepen bei meinem letzten Board, dem Abit IN9 32X.
Da kam es von den Spannungswandlern. Hatte es damals auch getauscht bekommen.
Gruss
