[Sammelthread] Gigabyte GA-EX58-UD5 / Extreme (Intel X58) [4]
Chrisch
Legende
Münsterland
[blockquote]
Spezifikationen Spezifikationen
CPU
  • LGA 1366 socket for:
    - Intel® Core i7 920/940 & 965XE
Intel® chipset
  • Northbridge:
    - Intel® X58 Express chipset
  • Southbridge:
    - Intel® ICH10R
Memory
  • 6 x DIMM, Max. 24 GB, DDR3 2130(*)/1860(*)/1600(*)/1333/1066/800
  • Triple Channel memory architecture
    *Overclock speed
    - Supports Intel® Extreme Memory Profile (XMP)
Expansion Slots
  • 3 x PCIe 2.0 x16 (support x16/x16 or x16/x8/x8)
  • 1 x PCIe x4
  • 1 x PCIe x1
  • 2 x PCI 2.2
BIOS
  • Dual-Bios
Audio
  • HD Audio, 8-channel
Storage Interface
  • South Bridge:
    - 6 x SATA 3Gb/s connectors (SATA2_0, SATA2_1, SATA2_2, SATA2_3, SATA2_4, SATA2_5) supporting up to 6 SATA 3Gb/s devices
    - Support for SATA RAID 0, RAID 1, RAID 5, and RAID 10
  • GIGABYTE SATA2 chip:
    - 1 x IDE connector supporting ATA-133/100/66/33 and up to 2 IDE devices
    - 2 x JMB322 chips (Smart Backup):
    - 4 x SATA 3Gb/s connectors (GSATA2_0, GSATA2_1, GSATA2_2, GSATA2_3) supporting up to 4 SATA 3Gb/s devices (Note 5)
    - Support for SATA RAID 0, RAID 1 and JBOD
  • iTE IT8720 chip:
    - 1 x floppy disk drive connector supporting up to 1 floppy disk drive
Internal I/O Connectors
  • 1 x 24-pin ATX main power connector
  • 1 x 8-pin ATX 12V power connector
  • 1 x floppy disk drive connector
  • 1 x IDE connector
  • 10 x SATA 3Gb/s connectors
  • 1 x CPU fan header
  • 3 x system fan headers
  • 1 x power fan header
  • 1 x North Bridge fan header
  • 1 x front panel header
  • 1 x front panel audio header
  • 1 x CD In connector
  • 1 x S/PDIF In header
  • 1 x S/PDIF Out header
  • 2 x USB 2.0/1.1 headers
  • 2 x IEEE 1394a headers
  • 1 x power LED header
  • 1 x chassis intrusion header
  • 1 x power switch
  • 1 x reset switch
Rear Panel I/O Connectors
  • 1 x PS/2 keyboard port
  • 1 x PS/2 mouse port
  • 1 x coaxial S/PDIF Out connector
  • 1 x optical S/PDIF Out connector
  • 1 x IEEE 1394a port
  • 1 x clearing CMOS switch
  • 8 x USB 2.0/1.1 ports
  • 2 x RJ-45 ports
  • 6 x audio jacks (Center/Subwoofer Speaker Out/Rear Speaker Out/Side Speaker Out/Line In/Line Out/Microphone
Features
  • Dynamic Energy Saver Advanced
  • Ultra Durable 3
  • Dynamic 6-Gear Swithching
  • 45nm CPU Optimized
  • 3 way CrossFireX
  • 3 way SLI support
  • Debug LED
  • Dolby Home Theater
  • Blu-ray Support
  • OV-Alert LED, OC-Alert LED, TMP-Alert LED
  • Hybrid Silent-Pipe 2 (nur das Extreme!)
BilderBilder
Bilder vom EX58-UD5
Die Verpackung und das Zubehör
Das BiosDas Bios (bei UD5 sowie Extreme identisch!)
Erste OC ErgebnisseErste OC Ergebnisse
Ersten eigenen OC Ergebnisse mit einem Retail Core i7-920 & Geforce 8800GTS G92 SLI
Voltage ModsVoltage Mods & read Points
*Jede Modifikation geschieht auf eigene Gefahr und führt zum erlöschen der Garantie!
DownloadsDownloads
Das Flashen geschieht wie immer auf eigene Gefahr!
Bios Downloads EX58-UD5
  • Bios F2
    - Auslieferungsbios
  • Bios F3
    - Fix CPU compatibility issues
  • Bios F4
    - Fix S3 resume turbo mode issue
    - Fix DualBIOS recovery issue
    - improve System Stability
  • Bios F5
    - Improve VGA card compatibility
    - Improve S3 resume compatibility
    - Intel®Core™ i7 processor D-0 stepping support
  • Bios F6a (beta / Testversion)
    - keine Changelog
  • Bios F6b (beta / Testversion)
    - Fix: QPI/Vtt Kaltstart Bug größer 1.280V
    - Bug: S3 fehlerhaft (E1) bei OC
  • Bios F6c (beta / Testversion)
    - Info: Neue Intel® AHCI ROM Version 1.20E... keine Wartezeit mehr !!!
    - Bug: S3 bei OC teilweise immer noch fehlerhaft (E1)... er wird daran gearbeitet !
Bios Downloads EX58-Extreme
  • Bios F3
  • Bios F4
  • Bios F5
  • Bios F6d (beta / Testversion)
    - Info: Erfolgreich geflasht...
  • Bios F6e (beta / Testversion)
    - keine Changelog
Thx @ JZElectronic für die aktuellen Bios Versionen :)
Wichtige InformationenWichtige Informationen
  • Achtet auf die Speicheranordnung, wenn die Riegel in den falschen Slots sind bootet das Mainboard nicht (hat mit dem IMC der CPU zu tun!)
    - Dazu bitte Seite 16 im Handbuch nachschlagen.
Wichtige LinksWichtige Links
Garantieverlängerung für in D, A, CH gekaufte Mainboards
Bedingung hierfür ist die vorangegangene Registrierung des Produktes innerhalb von 12 Wochen nach Kauf.
[/blockquote]
wo kann ich denn bei http://www.jzelectronic.de meine bios-settings hinterlegen?
meine cpu (schaffte bereits 200er blck) scheint auf dem u3dr bei 200 zu scheitern (qpi selbst auf 1,45v). gibs sowas wie ne "blck"-wall bei den meisten q2d-mobos?
ich hatte deine settings auch mal probiert, dass damals auch zu nicht-booten führte. aber irgendwie muss ich dem brett nen stoss gegeben haben, bootet nun brav und ich muss nimmer untern tisch zum cmos clearen kriechen ;)
@black ich erspars mir mal... :rolleyes:
selbst mit dem ud3r sind die 200 bclock drin.
Ein Kumpel von mir hat das ud3 mit Xeon und die config macht Auch locker und leicht
4200 .
Gruß Benny
hi ,
so laeuft das system von nenn kumpel
http://www.jzelectronic.de/bios/x58...011017112012000007011x01010101010101010101#w1
ach ich muss aber dazu sagen das er vor dem xeon einen 920 d0 hatte. und die cpu zum beispiel wollte keinen hohen uncore takt, und somit konnte er nur die speicher auf 1200 mhz laufen lassen.
test doch mal die speicher runter auf 1200 uncore auf 2400 bclock auf 200 .
gruss benny
---------- Beitrag hinzugefügt um 16:03 ---------- Vorheriger Beitrag war um 15:46 ----------
jetzt mal ich , hat jemand den pencil vCore Droop Mod durchgefuehrt.
und wenn ja , wie muss ich mir das vorstellen???
beispiel. ich stelle 1,25 ein , liegen dann auch 1,25 an???
@xxxAMD64Bitxxx & scampy hab alles probiert, 200er blck will einfach net :( dank euch trotzdem
das mobo taktet idle brav runter. allerdings hängt die vcore immer noch brav bei voller vcore, dass mein netzteil ständig aufdrehen lässt, kann man das fixen?
200 wollte bei mir auch net mitm f9l bios geht es nun
Das mit der VCore ist normal und ist sicher nicht der Grund dafür, dass Dein NT aufdreht. Besorg Dir mal ein Strommeßgerät (10,- im Baumarkt) und Du kannst es nachmessen. Jetzt kennst Du aber auch den Grund, warum ich von 450 erst auf 525, dann auf 650 W aufgerüstet habe beim NT. Bis das aufdreht, muss schon richtig Last kommen :d
Das mit dem Biosupdate ist vielleicht keine schlechte Idee ...
joar...das kommt noch hinzu...
CPU Clock Drive [ 800mV]
PCI Express Clock Drive [ 900mV]
warum zieht ihr die werte immer so hoch? korrespondiert des mit niedrigerer qpi-voltage?
@scamps hab ja auchn 650w. der selbstverbaute 140er lüffi dreht max 800. aber selbst idle, nt kalt (temp+lastgeregelt) stehen schon ~600rpm aufm tacho..schon merkwürdig...
btw meine powerleuchte vom case blinkt langsam im windoof-betrieb. ist des normal?
Du wilderst hier halt im UD5/Extreme-Thread, da sind
voreingestellt. Hab auch keinen Anlass, die auf Deine Werte zu reduzieren. Aber da die Stromversorgung zu Deinem Board schon ne andere ist, ist das vielleicht auch nicht zu vergleichen.
Wenn Du viel Glück hast, kann und will JZ dazu mal was sagen. Blinken vom Power-LED: ? kA Handbuch? ;)
---------- Beitrag hinzugefügt um 16:55 ---------- Vorheriger Beitrag war um 16:52 ----------
Neustes Biosupdate:
Bios vom UD3R Rev. 1.0 sollte sein F8g
Bios vom UD3R Rev. 1.6 sollte sein FD7
bekommst Du beim JZ :d
http://www.jzelectronic.de/jz2/index.php
gibt halt leider keinen sammler zu meiner kastrierten version ;)
hatte schon die letzte bios-beta installiert...
@jz, zu hülf! :wink:
Ich habe jetzt ein paar Seiten gelesen. Würdet ihr EX58-UD5 weiterempfehlen?
Oder findet ihr hier eine bessere Mobo? www.digitec.ch (unter 300Fr.)
Möchte es morgen abholen.
Danke
bekomme aber 3,60GHZ netmal Stabil.... ka finde net die richtigen settings kommen immer sporadische game freezes.. aber am ram liegts net, weil ram ist immer 1600, auf standart mhz cpu keine freezes.
Habe gerade mal das F9i-Bios für das GA-EX58-UD5 aufgespielt ... und ich muss sagen, es war ein einziges Fiasko. Nichts funktionierte mehr. Das Board hängte sich immer gleich beim Start auf .. außer dem Startbildschirm vom Bios war nichts zu sehen. Keine Reaktion auf Tastatureingaben. Schuld scheint mein Logitech Illuminated Keyboard zu sein, denn wenn ich es abstöpsele und eine andere Tastatur (PS2) anschließe, funktioniert alles einwandfrei. Hab keine Lösung für das Problem gefunden und das funktionierende F9e-Bios wieder aufgespielt. Never change a running system!
hanutiii
Wer hat Erfahrung mit 12GB RAM auf den Gigabytes und woran kann es liegen, dass die 19 x 200 stabil sind und die 20 x 200 nicht ? Wo kann man noch feilen ?
Erfahrungen nach brauchen ungerade multis oft weniger Vcore ...
D.h. 19 x 211 probieren ? Was muss ich dann einstellen um alle anderen Komponenten außer der CPU als "Fehlerquelle" auszuschließen ?
hat schon jemand das UD7 ? finde keinen Sammelthread obwohl das board schon verkauft wird
Hallo!
Habe nun seit heute das UD3R und hoffe bin hier richtig. Kann es sein, das es die Runtertaktung der CPU beim OC nicht unterstützt?
Habe im BIOS alles enabled, aber der Prozzi rennt immer mit 3.6GHz :( .
GA-EX58-UD5 - BIOS F9j
1. Update RAID Rom 8.9.1.1002
