Windows Home Server Bericht + Frage
skagway
Hallo zusammen,
habe es nun endlich geschafft meinen Windows Home Server nach mehreren Startproblemen in den Grundsätzen zu konfigurieren.
Erstes Problem: Installation bricht am Ende mit folgendem Error (0x80070003) ab:
Code:
[02.11.2009 17:56:51  1c0] Trying to load c:\install\winntbbu.dll
[02.11.2009 17:56:52  81c] Installer initialized with parameters -continue
[02.11.2009 17:56:52  81c] Current product version 6.0.1500.6
[02.11.2009 17:56:52  81c] Setup has [re]started at mode 0 stage 1 step 0
[TRACE] Looking for template x:\files
[TRACE] Checked file C:\files, error 2
[TRACE] Checked file D:\files, error 2
[TRACE] Template x:\files NOT FOUND!
[TRACE] FindOnMedia : Exited (0x80070002)
[02.11.2009 17:56:52  81c] ERROR: WHS disk not found!
[02.11.2009 17:56:52  81c] Found system on drive C
[02.11.2009 17:56:52  81c] Fixing up path C:\WHS
[02.11.2009 17:56:52  81c] Fixing up path C:\redistr
[02.11.2009 17:56:52  81c] Fixing up path C:\install
[02.11.2009 17:56:52  81c] Fixing up path C:\DOCS
[02.11.2009 17:56:52  81c] Fixing up path C:\$OEM$
[02.11.2009 17:56:52  81c] Fixing up path C:\windows\system32\pidgen.dll
[02.11.2009 17:56:52  81c] Fixing up path C:\install\winntbbu.dll
[02.11.2009 17:56:52  81c] Fixing up path C:\install\q-1024x768_24bit.bmp
[02.11.2009 17:56:52  81c] Fixing up path C:\install\qs.ini
[02.11.2009 17:56:52  81c] Fixing up path C:\install\winnt.sif
[02.11.2009 17:56:52  81c] Fixing up path C:\install\dcpromo.ini
[TRACE] Looking for template _:\qs.ini
[TRACE] Checked file C:\qs.ini, error 2
[TRACE] Checked file D:\qs.ini, error 2
[TRACE] Template _:\qs.ini NOT FOUND!
[TRACE] FindSetupFile : Exited (0x80070002)
[02.11.2009 17:56:52  81c] Install step is set to 5
[02.11.2009 17:56:52  81c] First boot in Windows
 Windows Home Server setup will now configure networking and
convert system drive to dynamic.
[02.11.2009 17:56:52  81c] CD Autorun OFF
[02.11.2009 17:56:52  81c] Current BitsPerPixel 0.
[02.11.2009 17:56:52  81c] Current PelsWidth 0.
[02.11.2009 17:56:52  81c] Current PelsHeight 0.
[02.11.2009 17:56:52  81c] Screen resolution changed to 1024 x 768 x 32.
[02.11.2009 17:56:53  81c] Advancing to stage 1 step 1
[02.11.2009 17:56:53  81c] ERROR: WHS disk not found!
[02.11.2009 17:56:53  81c] Found system on drive C
[02.11.2009 17:56:53  81c] Fixing up path C:\WHS
[02.11.2009 17:56:53  81c] Fixing up path C:\redistr
[02.11.2009 17:56:53  81c] Fixing up path C:\install
[02.11.2009 17:56:53  81c] Fixing up path C:\DOCS
[02.11.2009 17:56:53  81c] Fixing up path C:\$OEM$
[02.11.2009 17:56:53  81c] Fixing up path C:\windows\system32\pidgen.dll
[02.11.2009 17:56:53  81c] Fixing up path C:\install\winntbbu.dll
[02.11.2009 17:56:53  81c] Fixing up path C:\install\q-1024x768_24bit.bmp
[02.11.2009 17:56:53  81c] Fixing up path C:\install\qs.ini
[02.11.2009 17:56:53  81c] Fixing up path C:\install\winnt.sif
[02.11.2009 17:56:53  81c] Fixing up path C:\install\dcpromo.ini
[02.11.2009 17:56:53  81c] Install step is set to 5
[02.11.2009 17:56:53  81c] Mounting the cdrom
[02.11.2009 17:56:53  81c] Could not find Windows Home Server CD or USB
[02.11.2009 17:56:53  81c] Success!
[02.11.2009 17:56:53  81c] Advancing to stage 1 step 2
[02.11.2009 17:56:53  81c] Continuing to configure storage
[02.11.2009 17:56:54  81c] First available drive letter is I
[02.11.2009 17:56:54  81c] Success!
[02.11.2009 17:56:54  81c] Advancing to stage 1 step 3
[02.11.2009 17:56:54  81c] ERROR: WHS disk not found!
[02.11.2009 17:56:54  81c] Found system on drive C
[02.11.2009 17:56:54  81c] Fixing up path C:\WHS
[02.11.2009 17:56:54  81c] Fixing up path C:\redistr
[02.11.2009 17:56:54  81c] Fixing up path C:\install
[02.11.2009 17:56:54  81c] Fixing up path C:\DOCS
[02.11.2009 17:56:54  81c] Fixing up path C:\$OEM$
[02.11.2009 17:56:54  81c] Fixing up path C:\windows\system32\pidgen.dll
[02.11.2009 17:56:54  81c] Fixing up path C:\install\winntbbu.dll
[02.11.2009 17:56:54  81c] Fixing up path C:\install\q-1024x768_24bit.bmp
[02.11.2009 17:56:54  81c] Fixing up path C:\install\qs.ini
[02.11.2009 17:56:54  81c] Fixing up path C:\install\winnt.sif
[02.11.2009 17:56:54  81c] Fixing up path C:\install\dcpromo.ini
[02.11.2009 17:56:54  81c] Install step is set to 5
[02.11.2009 17:56:54  81c] Continuing to configure storage
[TRACE] Step_SetWindowsSourceCD : Exited (0x80070003)
[02.11.2009 17:56:54  81c] Continuing to configure storage failed. Error 0x80070003.
[02.11.2009 17:56:54  81c] MessageBox: Continuing to configure storage failed: The system cannot find the path specified.
 (error code 0x80070003).
[02.11.2009 17:57:05  81c] Windows Home Server setup failed. The error code is 0x80070003. Please correct the problem and reboot to restart the setup program.
[02.11.2009 17:57:05  81c] MessageBox: Windows Home Server installation failed. Do you want to view the installation log file?
[02.11.2009 17:57:07  81c] Spawning process [notepad.exe "C:\Documents and Settings\All Users\Application Data\Microsoft\Windows Home Server\logs\q_setup.log"]
Lösung bei mir: Anderes DVD Laufwerk!
Konfiguration meines Server atm:
-Intel DG43NB
-OCZ 4GB DDR2-800 RAM
-Intel E5200
-IDE 120GB Systemplatte
-1,5TB WD Caviar Green Datenplatte
-500GB HD501LJ Datenplatte
Nächstes Problem:
Erhebliche Treiberprobleme mit dem Mainboard, da Intel für ihre Desktop-Boards keine Server Treiber (also WS2003) bereitstellt. So war eine Installation des WHS OS zwar möglich allerdings waren so gut wie keine Treiber funktionsfähig.
Lösung:
Habe nach tagelangem suchen im Netz mir mein "Paket" zusammengesucht und habe nun alles installiert bekommen. Größtes Problem war es den Treiber für Intels "PCI Simple Communcation Controller" zu finden. Schlussendlich bestand die Lösung darin den Treiber für WinXP zu nehmen und die HECI.inf entsprechend zu bearbeiten. D.h. den Windows 2003 Teil in der inf dem WinXP Teil entsprechend anzupassen. Danach war die manuelle Installation kein Problem mehr.
(wer auf ähnliche Treiber Probleme mit den Intel Boards stößt und "zu faul" ist die Arbeit selbst zu machen kann sich bei mir melden an mailgoe(at)*****.com
Soweit hat also alles geklappt. Das letze noch offene Problem ist der nicht funktionierende Ruhezustand. Wäre für Plugins wie LightsOff natürlich von gutem Nutzen. Habe schon einiges probiert, allerdings erscheint der Reiter für den Ruhezustand einfach nicht in meinen "Energieoptionen". Jemand ne Idee was man da machen könnte? Bzw kann jemand bestätigen, dass es möglich ist ein Intel Desktop Board mit WS2003 zu betreiben und dabei weiterhin den Ruhezustand zu benützen?
skagway
---------- Beitrag hinzugefügt um 16:27 ---------- Vorheriger Beitrag war um 16:06 ----------
Wow! Heute ist mein Glückstag. Hab jetzt alles geschafft --> siehe hier
Das du keinen Ruhezustand - und vermutlich auch keinen Standby hast liegt daran das nicht alle Treiber richtig installiert sind - oder nur universelle von Microsoft verwendet werden.
Bei mir war das die Lösung, danach funktionierte auch der Ruhezustand. Du solltest allerdings bedenken das der Ruhezustand und aufwachen aus dem selbigen eher "experimentel" zu sehen ist.
Standby ist das zuverlässiger.
Gruss
Blue
wie willst du aufwachen aus dem ruhezustand denn haben?
im normalfalle via WOL?
dann solltest du die aktuellen LAN Treiber nehmen.
Und Graka/Chipset Treiber nicht vergessen damit alles glattläuft.
MFg
MAFRI
MFg
MAFRI
Der er von LightsOff sprach denke ich mal redet er von der Kalenderfunktion die dort verfürbar ist.
Gruss Blue
Man kann ja auch nicht alles, was nicht bei 3 auf den Bäumen ist, installieren und nutzen :d
Gruss Blue
o0
ich nutzt da lieber kein abgesätes Server OS...
a la w2k server oder w2k3 oder w2k8
das ist wesentlich umständlicher...
der WHS ist ebend nur für home...
man kann ihn in eine AD intigieren aber dann hat man im DC tausend log einträge wegen ungültiger zertifizierung etc.
mafri
Ja genau - habe mich noch nicht näher damit beschafft, war mir auch gar nicht möglich. Ich bin mir noch unschlüssig was genau ich will. Entweder den WHS zu speziellen Zeiten immer hoch- und runterfahren lassen (bzw ruhezustand oder stand-by) oder nur per WOL starten lassen. Auch von einer Funktion (wahrscheinlich mit Hilfe eines Plugins) dass der Server nur dann an ist, wenn ein Client im Netz ist. Und sich wieder ausscahltet nachdem 10min keiner mehr drin war.
Aber um mich da besser entschieden zu können zwischen den Lösungen wollte ich LightsOff installieren, was aber aufgrund der fehlenden Optionj zum Ruhzustand nicht möglich war. Installationsroutine ist immer abgebrochen.
Aber wie gestern noch ein paar Minuten später gepostet (siehe Edit erster Post) funktioniert jetzt alles.
Nachdem ich den aktuellen Grafiktreiber installiert hatte, war es mir wenigstens mal wieder möglich in den Stand-By Modus zu gehen. Allerdings erschien der Register für den Ruhzustand immer noch nicht in den Energieoptionen.
Als ich diesen dann probiert habe via cmd zu aktivieren bekam ich irgend eine Fehlermeldung zwecks PAE Modus oder so ähnlich. Nach einer minute googlen war dsa Problem dann gelöst. Lag an den verbauten 4GB Ram. Also die boot.ini so bearbeitet, dass der WHS nur noch mit maximal 3,5GB startete und alles lief perfekt.
Hoffe das hilft vielleicht auch einigen.
-skagway
@Mafri
Joa, ist doch in Ordnung - habe doch auch nie gesagt das ein WHS sogut wie ein SBS oder ein größerer ist. der WHS ist eben für die Heimnutzung gedacht und darum geht es doch auch hier ;)
@skagway
Das was du möchtest kann Lightsoff dir alles bieten. Einmal das terminierte "einschlafen" sowie auch das "aufwachen". Integriert ist ebenfalls die berücksichtigung laufender Windowsclients die das "einschlafen" verzögern bis sie selbst ausgeschaltet sind. Realisiert wird das mit einem kleinen Zusatztool das einen Dienst auf deinem Client installiert.
Gruss Blue
