[Sammelthread] Seasonic X-Series [660-760-850-1050-1250 Watt]
thom_cat
Super Moderator
Hardwareluxx Team
Hessen\LDK
Verfügbare Modelle:
X-560 (SS-560KM) - Preisvergleich EOL
X-660 (SS-660KM) - Preisvergleich
X-760 (SS-760KM) - Preisvergleich
X-850 (SS-850KM) - Preisvergleich
Herstellerseite: New X-Series
X-1050 (SS-1050XM) - Preisvergleich
X-1250 (SS-1250XM) - Preisvergleich
Spezifikationen:
[660-760-850]
80PLUS® Gold Certified Super High Efficiency
Full Modular Cabling Design
Patented DC Connector Module with Integrated VRM [Voltage Regulator Module]
DC to DC Converter Design
Seasonic Hybrid Silent Fan Control
Sanyo Denki San Ace Silent Fan
Conductive Polymer Aluminum Solid Capacitors
Highly Reliable 105℃ Japanese Brand Capacitors
Tight Voltage Regulation [±3%]
Active Power Factor Correction [99% PF Typical]
High +12V Output
High Current Gold Plated Terminals
Dual Sided PCB Layout
Ultra Ventilation [Honeycomb Structure]
Multi-GPU Technologies Supported
All-in-One DC Cabling Design
Easy Swap Connector
Universal AC Input [Full Range]
7 Years Warranty
Dimension: W150 x L160 x H86 mm
[1050-1250]
1. 80PLUS® Gold Certified Super High Efficiency
2. Full Modular Cabling Design
3. Patented DC Connector Module with Integrated VRM [Voltage Regulator Module]
4. DC to DC Converter Design
5. Seasonic Hybrid Silent Fan Control
6. Sanyo Denki San Ace Silent Fan
7. Conductive Polymer Aluminum Solid Capacitors
8. Highly Reliable 105℃ Japanese Brand Capacitors
9. Tight Voltage Regulation [±3%]
10. Active Power Factor Correction [99% PF Typical]
11. High +12V Output
12. High Current Gold Plated Terminals
13. Dual Sided PCB Layout
14. Ultra Ventilation [Honeycomb Structure]
15. Multi-GPU Technologies Supported
16. All-in-One DC Cabling Design
17. Easy Swap Connector
18. Universal AC Input [Full Range]
19. 7 Years Warranty
Dimension: L190 x W150 x H86 mm
Leistung:
Zubehör:
Für die Modelle [(400FL-460FL)-560-660-760-850] kann man vollständige Kabelsätze kaufen: Seasonic Kabelsatz für Retail X-400FL/460FL/560/660/760/850
Die beiden Modelle [650-750] sind dazu allerdings nicht kompatibel, ebenso wenig passen die Kabel umgekehrt.
Für die beiden älteren Modell findet man aber auch einen passenden Kabelsatz: Seasonic Kabelsatz für Retail X-650 und X-750
Reviews:
Seasonic X-750 80Plus Gold - Gehäuse, Kühlung, Netzteile - Planet 3DNow!
Seasonic X-Series X-750 750 Watt | PC-Max: Hardware News und Tests
Introduction - Seasonic X Series: X-750 Power Supply Review | [H]ard|OCP
Technic3D Review: Netzteile: Netzteil Seasonic X-650W Modell SS-650KM: Effizient und leise - Seite 1: Einleitung
Seasonic X-650 650W Review
X-650: Seasonic hits Gold | silentpcreview.com
Seasonic X-Series 650 W Power Supply Review | Hardware Secrets
PC-Experiance X750 Review
Seasonic X-560 | Hardwareluxx
Hohe Effizienz zum fairen Preis: Vier günstige Goldnetzteile im Test | Tom's Hardware
EDIT: Liste von Hienen zur bisherigen Übersicht wie viele Geräte Fiepen:
#1 Hienen x650 | 1.piept | 2. piept |
#2 Tenchi Muyo x650 | 1. geräuschlos |
#3 Gebieter x650 | 1.geräuschlos | <- per PM erfragt
#4 Matze71 x650 | 1.Lüfter schleift stark | 2.geräuschlos | <- aus Kaufberatungsthread entnommen
#5 Sarko | 1.geräuschlos |
#6 gonix | 1.geräuschlos |
#7 Moosbart x650 | 1.geräuschlos |
#8 cascade x650 geräuschlos
#9 tarabas x750 hörbares sehr hochfrequentes fiepen
#10 whippersnapper x750 geräuschlos
#11 matze71 x650 1. schleifgeräusche vom lüfter, 2. geräuschlos (beide kein fiepen)
#12 smoothwater x750 geräuschlos
#13 Gollum (CON) x650 geräuschlos
#14 Nordhesse x650 geräuschlos
#15 Chrisch x750 geräuschlos
#16 Eros Thanatos x650 fiepen und leises brummen
#17 Handle x750 leises sirren
#18 Maeximum30 x650 geräuschlos
#19 he1nz1 x650 geräuschlos
#20 schnarx x650 geräuschlos
#21 dr-ami x650 geräuschlos
#22 GuRk86 x750 geräuschlos
#23 The-Master x750 geräuschlos
#24 tyrannoblaurus2010 x750 geräuschlos
#25 NightTrooper x650 geräuschlos
#26 hexadezimal x650 geräuschlos
#27 mArTiAn x650 geräuschlos
laut test in der pcgh hat auch deren gerät leicht gefiept, was aber im warmen zustand geringer wurde.
fett, nur könnt ich das JETZT gerade gebrauchen... mist
Seasonic expects X-Series power supplies to be available at online retailers in late July or early August.
Woher kommt denn techreport.com? Verfügbarkeit hier in D oder irgendwo in Amiland, weiß das einer?
Gibt es schon iwelche Neuigkeiten?
Würde mir zum August hin gerne die 550W Version kaufen :)
Hey das gefällt mir, ahb mir zwar gerade das enermax Modu bestellt, aber das hol ich mir!
Ähhm, also ab September hab ich ein Modu 82+ 525 abzugeben!:haha:
hab grad mal seasonic eine mail geschrieben wie die kabel aussehen werden. ob normal gesleeved oder flachband die wie die corsaair hx ;)
mal schauen ob sie antworten^^
Hat seasonic schon geantwortet ?^^
nein, leider nicht. dachte eigentlich das auf ich bei so einer firma schnell eine ausführliche antwort erhalte. naja...
gibt ja bisher auch keine weiteren infos zu den netzteilen. warte aber trotzdem noch drauf. alleine wegen den 100% modularen kabeln :)
Ich warte auch drauf. Wenn der September Termin jedoch erneut verschoben wird, kaufe ich mir halt was anderes.
hallo luxxer :wink:
bin gerade zurück von der gamescom und war auch bei seasonic am stand. leider gab es kein x-series psu zu begutacten, aber einige neue infos.
und zwar wird es vorerst nur eine 650 und 750w variante geben
alle kabel sind vollmodular
es werden flachbandkabel verwendet
launch in europa ist im september
hier nochmal die infos vom flyer
besondere merkmale:
-80 plus gold zertifiziert, bis zu 92% effiziens
-patentiertes dc-anschluss modul mit integriertem vrm
-leise hybrid lüftersteuerung
-äußerst zuverlässige japanische 105°C marken kondensatoren
-äußerst zuverlässige festkondensatoren
-strenge spannungsregulierung mit nur +-3% toleranz
-all in one dc-kabel-design
-unterstützung für mehrere pci-e grafikkarten
spezifikationen:
-kompatibel mit atx12v und eps12v
-mtbf > 150.000 stunden bei 25°C
-abmessungen (lxbxh) 160 x 150 x 86 mm
-weitbereichseingang (100-240v)
-schutz gegen überlastung, überspannung, überstrom und kurzschluss
ziemlich schick die teile =)
frag mich nur wie es nesteq schafft bei ihren netzteilen so extrem hohe ampere zahlen zu erreichen...
schade, dass das 550er erstmal nicht am start ist, das wäre sicher für viele sehr interessant gewesen...
angeblich soll in der nächsten zeit ein kleines video-review vom netzteil kommen :) (laut mitarbeiter des seasonic standes auf der gamescom)
na ja ob der preis akzeptabel ist, bezweifel ich. angeblich soll es preislich in den regionen vom m12d liegen. :(
Öhm, is das normal dass die sich mit ihrer Watt-Klassifizierung ausschließlich auf die 12W-Schiene beziehen und die anderen nicht mit dazurechnen?
Ich hab ein-zwei Jahre nicht mehr auf den Markt geguckt, aber damals war es soweit ich mich erinnern kann noch so, dass immer die kombinierte maximale Leistungsabgabe auf allen Schienen zusammengezählt wurde...
Da wundert es mich auch weniger, dass die hier ein Gold-Netzteil mit "nur" 550W vorstellen, denn kombiniert wird es wohl 700W Leistung bringen. Das sollte auch für dicke SLI-Systeme immer noch gut reichen.
Die Netzteile könnten durchaus interessant werden.
Aber warum muss das Lüftergitter offensichtlich gestanzt sein? :shake: Ein normales (notfalls entfernbares) hätte auch gereicht und würde weniger Luftrauschen verursachen.
Hi,vorallem steht das "Lüftergitter" ein bissel über und somit wird das NT schonmal in kein Case passen wo das NT auf den Boden kommt. mfg omni :wink:
Weil das Netzteil die komplette Leistung über die 12V Schiene abgeben kann, und 3,3V und 5V aus dieser 12V Schiene generiert werden ;)
Nicht schlecht von Seasonic.
Epoxid Platine, zwei Nippon-Chemicon Elkos, positiverweise nur ein großer Kühlkörper, viele Feststoffkondensatoren usw.
Wow, das nenn ich mal ein ungewöhnliches internes Layout. Aber die verbauten Komponenten sehen (bis auf den Lüfter) sehr gut aus. Die Testergebnisse sind ganz ok, wobei das Ripple-Verhalten wirklich merkwürdig ist... vor allem, weil ich dieses Innenleben mal herunterskaliert für ein Sub-400w Netzteil sehen will :)
Selbst bei 110V schaut die Effizienz seht gut aus :d
Das Teil sollte ja im September nach Europa kommen, na ob das noch hinhaut...
Wollte nicht Enermax im Spätsommer auch seine Goldserie vorstellen? Was ist da los?
