Black Lion
eben, drum würde mich interessieren, ob hier einer nen PS3-Stick uner XP am Laufen hat.
PS3 Fightstick/Pad
1) works great on Intel and VIA chipsets
2) does not work on Nvidia and AMD chipsets
Xbox 360 Fightstick/Pad
1) work well on all systems as long as you download the drivers from Microsoft.
Q: My PS3 Arcade FightStick (TE and Standard) or PS3 FightPad is not working on my computer.
A: The PS3 SFIV TE/SE FightStick and FightPad does not officially support the PC, but should work with PCs that do not make use of a NVIDIA® chipset. If a workaround is discovered, we will post more information for you here.
das is alles sehr unbefriedigend, zumal MadCatz wohl auch keine Treiber mehr veröffentlichen wird nachdem was man so liest.
Gibts evtl. noch Alternativen an XBOX-Sticks(die PC-tauglich sind)? Die Horis sollen ganz gut sein, allerdings kenn ich da nur den EX2 und der hat kein 8 Button-Layout.
Quadrat = low punch / Dreieck = mid punch / R1 = high punch / X = low kick / O = mid kick / R2 = high kick / L1 = 3xpunch / L2 = 3xkick
