ASUS Maximus II Gene (Intel P45)
Allgemeine Informationen:
____________________________________________
Bilder:
coming soon
eigene Bilder folgen sobald ich mein Board bekommen hab
Spezifikationen:
CPU: Intel® Socket 775 Core™2 Quad/Core™2 Extreme/Core™2 Duo/Pentium® dual-core/Celeron® dual-core / Celeron® Processors Support Intel® 45nm Multi-Core CPU
* Refer to www.asus.com for Intel CPU support list
Chipset: Intel® P45 /ICH10R
FSB: 1600/1333/1066/800 MHz
Memory: 4 x DIMM, Max. 16 GB, DDR2 1300/1200/1066/800/667
Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*Refer to www.asus.com or this user manual for the
Memory QVL(Qualified Vendors Lists).
Expansion Slots: 2 x PCIe 2.0 x16 (single max @ x16,dual @ x8 speed)
1 x PCIe x1
1 x PCI 2.2
Multi-GPU Support: Support ATI CrossFireX™ Technology
Storage: Intel ICH10R controller
6 xSATA 3 Gb/s ports
Intel Matrix Storage Technology Support RAID 0,1,5,10
JMicron® JMB363 PATA and SATA controller
1 xUltraDMA 133/100/66/33 for up to 2 PATA devices
1 xExternal SATA 3.0 Gb/s port (SATA On-the-Go)
1 xSATA 3.0 Gb/s port
LAN: Gigabit LAN
Audio: SupremeFX X-Fi built-in
8 - Channel High Definition Audio CODEC
- EAX® Advanced™ HD 4.0
- X-Fi CMSS®-3D
- X-Fi Crystalizer™
- Creative ALchemy
IEEE 1394: 2 x 1394a ports (1 port at back I/O, 1 port onboard)
USB: 12 USB 2.0 ports (6 ports at back I/O, 6 ports onboard)
Overclocking Features: Keyboard-TweakIt
Power Design:
- 8-phase CPU power
- 2-phase DRAM power
- 2-phase NB power
CPU Level Up
iROG
Extreme Tweaker
Loadline Calibration
Intelligent overclocking tools:
- TurboV
- O.C Profile
Overclocking Protection:
- COP EX (Component Overheat Protection - EX)
- Voltiminder LED
- ASUS C.P.R.(CPU Parameter Recall)
Special Features:
ASUS MyLogo 3
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Connector
External LCD Poster
MemOK!
One DIMM latch
Onboard Switches:
Power / Reset / Memok / Clr CMOS (at rear)
ASUS EPU-6 Engine
ASUS Fan Xpert
Back Panel I/O Ports:
1 x External SATA
1 x S/PDIF Out (Optical)
1 x IEEE 1394a
1 x LAN(RJ45) port
6 x USB 2.0/1.1
8 -Channel Audio I/O
1 x PS/2 Keyboard port(purple) 1 x Clr CMOS switch
Internal I/O Connectors:
3 x USB connectors supports additional 6 USB 2.0 ports
7 x SATA connectors
1 x IDE connector for two devices
5 x Fan connectors: 1 x CPU / 2 x Chassis / 2 x Optional
Front panel audio connector
System Panel connector
2 x thermal sensor connectors
1 x LCD Poster connector
1 x SPDIF_OUT connector
24-pin ATX Power connector
8-pin ATX 12V Power connector
1 x En/Dis-able Clr CMOS header
1 x CD audio in
BIOS:
16 Mb Flash ROM
AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.4,
ACPI2.0a, Multi-Language BIOS
Manageability:
WOL by PME,WOR by PME,PXE
Accessories User's manual:
1 x UltraDMA 133/100/66 cable
2 x SATA cable
I/O Shield
1 x External LCD Poster
1 x 2 in 1 ASUS Q-Connector Kit
1 x Cable Ties
1 x ROG theme label
Support Disc:
Support DVD:
- Drivers and applications
Sound Blaster X-Fi Utility
Futuremark® 3DMark® 06 Advanced Edition
Kaspersky® Anti-Virus
ASUS TurboV utility
ASUS PC Probe II
ASUS Update
ASUS AI Suite
Form Factor:
uATX Form Factor
9.6 inch x 9.6 inch ( 24.4 cm x 24.4 cm )
BIOS:
coming soon
Wichtige Informationen:
Wichtige Links:
Asus-Produktseite
Reviews
AwardFabrik
ThinkComputer
BIOS
Beta BIOS
Das Board bekommt ihr bei folgenden Shops:
Geizhals-Link
Kühler:
Luftkühler:
Wasserkühler
so das wars jetzt mal von meiner Seite das Board ist bestellt und sobald es da ist gibt es erste Test, inkl. OC unter Dice und möglicherweise auch LN2
Wünsche, Anregungen und Verbesserungsvorschläge den Thread betreffend jederzeit ausdrücklich erwünscht
Bilder:
coming soon
Spezifikationen:
1 x PCIe x1
1 x PCI 2.2
LAN: Gigabit LAN
- X-Fi CMSS®-3D
- X-Fi Crystalizer™
- Creative ALchemy
Power Design:
- 8-phase CPU power
- 2-phase NB power
CPU Level Up
iROG
Extreme Tweaker
- TurboV
- O.C Profile
- Voltiminder LED
Special Features:
ASUS MyLogo 3
ASUS EZ Flash 2
ASUS Q-Connector
External LCD Poster
MemOK!
One DIMM latch
Onboard Switches:
ASUS EPU-6 Engine
ASUS Fan Xpert
1 x External SATA
1 x IEEE 1394a
1 x LAN(RJ45) port
6 x USB 2.0/1.1
7 x SATA connectors
1 x CD audio in
BIOS:
16 Mb Flash ROM
Manageability:
2 x SATA cable
I/O Shield
1 x Cable Ties
1 x ROG theme label
Support Disc:
Support DVD:
ASUS TurboV utility
ASUS PC Probe II
ASUS Update
ASUS AI Suite
Form Factor:
uATX Form Factor
BIOS:
coming soon
Wichtige Links:
Asus-Produktseite
Reviews
AwardFabrik
ThinkComputer
BIOS
Beta BIOS
Geizhals-Link
Kühler:
Luftkühler:
Wasserkühler
. Trotz schleifens der CPU. Ich warte jetzt mal auf den NH-U9B.
