[Sammelthread] Gigabyte GA-EX58-UD5 / Extreme (Intel X58) [3]
Chrisch
Legende
Münsterland
[blockquote]
Spezifikationen Spezifikationen
CPU
  • LGA 1366 socket for:
    - Intel® Core i7 920/940 & 965XE
Intel® chipset
  • Northbridge:
    - Intel® X58 Express chipset
  • Southbridge:
    - Intel® ICH10R
Memory
  • 6 x DIMM, Max. 24 GB, DDR3 2130(*)/1860(*)/1600(*)/1333/1066/800
  • Triple Channel memory architecture
    *Overclock speed
    - Supports Intel® Extreme Memory Profile (XMP)
Expansion Slots
  • 3 x PCIe 2.0 x16 (support x16/x16 or x16/x8/x8)
  • 1 x PCIe x4
  • 1 x PCIe x1
  • 2 x PCI 2.2
BIOS
  • Dual-Bios
Audio
  • HD Audio, 8-channel
Storage Interface
  • South Bridge:
    - 6 x SATA 3Gb/s connectors (SATA2_0, SATA2_1, SATA2_2, SATA2_3, SATA2_4, SATA2_5) supporting up to 6 SATA 3Gb/s devices
    - Support for SATA RAID 0, RAID 1, RAID 5, and RAID 10
  • GIGABYTE SATA2 chip:
    - 1 x IDE connector supporting ATA-133/100/66/33 and up to 2 IDE devices
    - 2 x JMB322 chips (Smart Backup):
    - 4 x SATA 3Gb/s connectors (GSATA2_0, GSATA2_1, GSATA2_2, GSATA2_3) supporting up to 4 SATA 3Gb/s devices (Note 5)
    - Support for SATA RAID 0, RAID 1 and JBOD
  • iTE IT8720 chip:
    - 1 x floppy disk drive connector supporting up to 1 floppy disk drive
Internal I/O Connectors
  • 1 x 24-pin ATX main power connector
  • 1 x 8-pin ATX 12V power connector
  • 1 x floppy disk drive connector
  • 1 x IDE connector
  • 10 x SATA 3Gb/s connectors
  • 1 x CPU fan header
  • 3 x system fan headers
  • 1 x power fan header
  • 1 x North Bridge fan header
  • 1 x front panel header
  • 1 x front panel audio header
  • 1 x CD In connector
  • 1 x S/PDIF In header
  • 1 x S/PDIF Out header
  • 2 x USB 2.0/1.1 headers
  • 2 x IEEE 1394a headers
  • 1 x power LED header
  • 1 x chassis intrusion header
  • 1 x power switch
  • 1 x reset switch
Rear Panel I/O Connectors
  • 1 x PS/2 keyboard port
  • 1 x PS/2 mouse port
  • 1 x coaxial S/PDIF Out connector
  • 1 x optical S/PDIF Out connector
  • 1 x IEEE 1394a port
  • 1 x clearing CMOS switch
  • 8 x USB 2.0/1.1 ports
  • 2 x RJ-45 ports
  • 6 x audio jacks (Center/Subwoofer Speaker Out/Rear Speaker Out/Side Speaker Out/Line In/Line Out/Microphone
Features
  • Dynamic Energy Saver Advanced
  • Ultra Durable 3
  • Dynamic 6-Gear Swithching
  • 45nm CPU Optimized
  • 3 way CrossFireX
  • 3 way SLI support
  • Debug LED
  • Dolby Home Theater
  • Blu-ray Support
  • OV-Alert LED, OC-Alert LED, TMP-Alert LED
  • Hybrid Silent-Pipe 2 (nur das Extreme!)
BilderBilder
Bilder vom EX58-UD5
Die Verpackung und das Zubehör
Das BiosDas Bios (bei UD5 sowie Extreme identisch!)
Erste OC ErgebnisseErste OC Ergebnisse
Ersten eigenen OC Ergebnisse mit einem Retail Core i7-920 & Geforce 8800GTS G92 SLI
Voltage ModsVoltage Mods & read Points
*Jede Modifikation geschieht auf eigene Gefahr und führt zum erlöschen der Garantie!
DownloadsDownloads
Das Flashen geschieht wie immer auf eigene Gefahr!
Bios Downloads EX58-UD5
  • Bios F2
    - Auslieferungsbios
  • Bios F3
    - Fix CPU compatibility issues
  • Bios F4
    - Fix S3 resume turbo mode issue
    - Fix DualBIOS recovery issue
    - improve System Stability
  • Bios F5
    - Improve VGA card compatibility
    - Improve S3 resume compatibility
    - Intel®Core™ i7 processor D-0 stepping support
  • Bios F6a (beta / Testversion)
    - keine Changelog
  • Bios F6b (beta / Testversion)
    - Fix: QPI/Vtt Kaltstart Bug größer 1.280V
    - Bug: S3 fehlerhaft (E1) bei OC
  • Bios F6c (beta / Testversion)
    - Info: Neue Intel® AHCI ROM Version 1.20E... keine Wartezeit mehr !!!
    - Bug: S3 bei OC teilweise immer noch fehlerhaft (E1)... er wird daran gearbeitet !
Bios Downloads EX58-Extreme
  • Bios F3
  • Bios F4
  • Bios F5
  • Bios F6d (beta / Testversion)
    - Info: Erfolgreich geflasht...
  • Bios F6e (beta / Testversion)
    - keine Changelog
Thx @ JZElectronic für die aktuellen Bios Versionen :)
Wichtige InformationenWichtige Informationen
  • Achtet auf die Speicheranordnung, wenn die Riegel in den falschen Slots sind bootet das Mainboard nicht (hat mit dem IMC der CPU zu tun!)
    - Dazu bitte Seite 16 im Handbuch nachschlagen.
Wichtige LinksWichtige Links
Garantieverlängerung für in D, A, CH gekaufte Mainboards
Bedingung hierfür ist die vorangegangene Registrierung des Produktes innerhalb von 12 Wochen nach Kauf.
[/blockquote]
könntest du die anderen GA EX58 Mainboards vielleicht mit ins Topic übernehmen, denn es gibt für diese bisher kein sammelthread, und die änderungen zwischen den boards sind marginal. mfg crackie
hi!
ich hab das in http://www.hardwareluxx.de/community/showthread.php?t=614131 beschriebene problem, das mit der cpu inkompatibilität könnte sein, gemäss http://www.gigabyte.com.tw/Support/Motherboard/CPUSupport_Model.aspx?ProductID=2958#anchor_os wird der i7 920 d0 erst ab bios f5 unterstützt, welches bei meinem neu gekauften board wohl nicht drauf ist....
hat denn sonst niemand dieses board mit nem d0 core i7 in betrieb genommen?
wie würdet ihr jetzt vorgehen? händler um bios update bitten? ich kenne leider niemanden der nen i7 hat und mit dem seinem cpu ich mein board flashen könnte...
Wenn es denn so viele gibt, warum eröffnest Du denn keinen eigenen Thread dazu?
Hey sagt mal wäre es nicht sinnvoll das UD4P auch in diesen Sammelthread mit aufzunehmen ?
@JZ,
omg ich gebs auf :fresse: werd andauern von Win7 verarscht:grrr::motz:
läuft ja gar nichts durch ey :kotz:
nicht mal 20*160:fresse:
das muss doch ein mega bug sein oder im bios ist was faul :rolleyes:
naja ich seh gezwungen mal unter vista zu teste :fresse:
Hallo, also bei mir läuft es super mit win7. Muss an Deinem Bios liegen.
Nicht ein Treiber Prob hab ich mit Win7, finde läuft sogar besser als mit Vista.
Gruss Michael
hast du die 64bit version ?
und was hast du im bios bei HPET mode eingestellt 32bit oder 64bit ?
Naja läuft es denn gar nicht oder nur mit WENIGER TAKT BCLK als bei XP
omfg habs endlich fast geschafft Win7 nach tage lang stabil zubetreiben :banana:
ich hab ein paar einstellungen vornehmen müssen was normal unter xp super gelaufen ist, alles auf auto auser vcore und ram voltage :fresse:
musste für 21*191=4011mhz vcore 1,2v, CPU PLL auf 1,84V anheben, dann den QPI Vtt auf 1,36v und IOH auf 1,14v , rams auf 764mhz cl8.8.8.24 1T 1,62v
leider leider bricht bei 896K noch ein Worker ab :shake:
vorher 7 Worker abruch :fresse:
aber bin fast am knacken :d
Hi
hatte gerade etwas weiter übertaktet..nur leider hatte ich den An und Aus Bug beim Hochfahren..habe das F6H Bios drauf..musste das NT ausschalten, dann hat er normal gestartet, frage wie kann ich diesen An und Aus bug den beheben?
@crynis
...QPI/Vtt mal höher einstellen oder mal schauen, was deine CPU für eine QPI voreinstellt... am besten unter der neusten ET6 bei "Power On" zu sehen...
sag die mir mal...
also wenn ich es auf auto lasse nimmt er 1,34v :rolleyes:
ioh ebenfalls bei auto 1,14v
aber der hammer ist wenn ich den qpi vtt ab 1,38v hoh einstelle brechen alle Worker gleich ab bei 1024K :rolleyes: :fresse: unter xp habe ich diese probleme nicht :fresse:
...XP erzeugt ja auch nicht so eine last, als vista64 oder win7
das hängt wohl alles mit dem uncore bereich zusammen... oder deine CPU ist nicht 4 GHz geeignet :-/
jo kann sein :rolleyes:
so sieht es aus hier
hab mal den vcore auf 1,325v erhöht und ioh auf 1,16v, und Performance Enhance auf turbo den ich immer normal auf standard gelassen habe,
sag mal kann das sein das die rams die täter sind ? auserdem XMP sagt command rate 2T :fresse:
Hi
Im Prinzip ist er ja nur da wenn was nicht 100% läuft...zb war bei mir mal das Board kaputt dadurch bedingt ging er immer nur an und aus
aber bei Dir wird es ja ne falsche oder zu hohe Einstellung sein ...und wenn Du da wohl etwas weiter daneben liegst ist er in diesem Zyklus drin
So könnte ich es mir vorstellen.
Und wenn Du nur etwas daneben liegst bzw das Board es selber wieder zurücksetzen kann, hast Du es nur 1 bis 2 mal und dann fährt er wieder "normal" hoch
Ahah..hatte das nur einmal da ging der immer an und aus..wie gesagt habe das NT
ausgeschalten und jetzt fährt er ganz normal hoch, Board ist auch unglaublich kühl..jetzt
unter Wasser 32° mit Luft so 45..hat sich gelohnt doch noch das Board unter Wasser zu
setzen.
Bei welchem Takt bzw BCLK hast Du diese Auto Werte danke dir
bei 191x21 ??!!
ja bei 21*191
und bin mir 100% sicher das mein cpu ein renner ist, kann ich mir niemals vorstellen das er nicht 4ghz geeignet ist, läuft nicht mal mit 3,2ghz stabil unter Win7 :fresse: und wiegesagt immer bei 896K abruch das ganze, hab echt das gefühl muss an rams liegen :rolleyes:
