Die aktuellen nVidia Forceware Treiber für WinXP und Vista (Part 3.1)
Le_Frog99
Forenleitung , Chefsklave , Turbo Froschn !
Hardwareluxx Team
Magdeburg
Treiber für Windows XP 32/64Bit
  • Final
Code:
[COLOR="Black"][B]Windows XP Treiber 181.22 WHQL Final[/B][/COLOR]
[URL="http://www.nvidia.de/object/winxp_181.22_whql_de.html"]Win32[/URL]
[URL="http://www.nvidia.de/object/winxp64_181.22_whql_de.html"]Win64[/URL]
[COLOR="Black"][B]Windows XP Treiber 181.20 WHQL Final[/B][/COLOR]
[URL="http://www.nvidia.de/object/winxp_181.20_whql_de.html"]Win32[/URL]
[URL="http://www.nvidia.de/object/winxp64_181.20_whql_de.html"]Win64[/URL]
  • Beta
Code:
[COLOR="black"][B]ForceWare 182.05 XP 32/64Bit[/B][/COLOR]
[URL="http://www.nvidia.com/object/winxp_182.05_beta.html"]hier[/URL]
[URL="http://www.nvidia.com/object/winxp64_182.05_beta.html"]hier[/URL]
[COLOR="black"][B]ForceWare 181.22 XP 32/64Bit BETA[/B][/COLOR]
[URL="http://www.nvidia.com/object/winxp_181.22_beta.html"]hier[/URL]
[URL="http://www.nvidia.com/object/winxp64_181.22_beta.html"]hier[/URL]
Treiber für Windows Vista 32/64Bit
  • Final
Code:
[COLOR="black"][B]Treiber 181.22 für Vista 32/64bit WHQL Final[/B][/COLOR]
[URL="http://www.nvidia.de/object/winvista_x86_181.22_whql_de.html"]Vista 32[/URL]
[URL="http://www.nvidia.de/object/winvista_x64_181.22_whql_de.html"]Vista 64[/URL]
[COLOR="black"][B]Treiber 180.48 für Vista 32/64bit WHQL Final[/B][/COLOR]
[URL="http://www.nvidia.de/object/winvista_x86_180.48_whql_de.html"]Vista 32[/URL]
[URL="http://www.nvidia.de/object/winvista_x64_180.48_whql_de.html"]Vista 64[/URL]
  • Beta
Code:
[COLOR="black"][B]ForceWare 182.05 Vista 32/64Bit BETA[/B][/COLOR]
[URL="http://www.nvidia.com/object/winvista_x86_182.05_beta.html"]hier[/URL]
[URL="http://www.nvidia.com/object/winvista_x64_182.05_beta.html"]hier[/URL]
[COLOR="black"][B]ForceWare 181.22 Vista 32/64Bit BETA[/B][/COLOR]
[URL="http://www.nvidia.com/object/winvista_x86_181.22_beta.html"]hier[/URL]
[URL="http://www.nvidia.com/object/winvista_x64_181.22_beta.html"]hier[/URL]
  • Bugfixes
Code:
[B]Vista Hotfixes für 8er Gforce Karten[/B] [URL="http://www.nvidia.com/object/windows_vista_hotfixes.html"]hier[/URL]
  • Tools
Code:
[B]NHancer[/B]
[URL="http://www.nhancer.com/?dat=home"]hier
[/URL]
[B]RivaTuner[/B]
[URL="http://downloads.guru3d.com/downloadget.php?id=163&file=5&evp=2d213e528fb556c354432a3976bff55a"]hier[/URL]
[B]GPUZ[/B]
[URL="http://www.techpowerup.com/downloads/811/TechPowerUp_GPU-Z_v0.0.9.html"]hier[/URL]
[B]Ntune[/B]
[url=http://www.nvidia.de/object/ntune_5.05.25.00_de.html]hier[/url]
  • Info
Hinweise zum aktuellen 180.43 dem Nvidia BigBang2 Treiber:
Mit einführung der GeForce 180.43 bietet Nvidia zum ersten mal Multimonitoring Unterstützung auch für den SLI Betrieb, was leider vorher nur den Quadro Karten vorbehalten war.
Computerbase.de
Mit dem GeForce-180-Treiber ist es nun auch möglich, mehrere Monitore im SLI-Modus anzusprechen, die bis jetzt im Multi-GPU-Modus immer ausgeschaltet blieben. Dabei gibt es verschiedene Einstellungsmöglichkeiten. Entweder bleibt im 3D-Betrieb der eine Monitor schwarz beziehungsweise ohne Inhalt (Fullscreen 3D Gaming Mode) oder man lässt eine 3D-Applikation im Fenster laufen, wodurch man auf dem zweiten Monitor eine 2D-Anwendung starten kann (Windows Gaming & Interactive Web Mode).
Desweiteren ist es der erste Treiber welcher SLI auf dem zukünftigen Intel Chipsatz X58 unterstützen wird. Damit ist es das erste mal möglich SLI Betrieb auch auf den Intel Mainboards legal zu nutzen.
Computerbase.deDie GeForce-180-Generation soll Verbesserungen in vier generellen Kategorien erhalten haben. So soll die Performance in Spielen gestiegen sein, SLI wird auf zertifizierten X58-Mainboards (Nehalem) ermöglicht, es gibt Multi-Display-Funktionen im SLI-Betrieb und man soll nun eine separate zweite oder dritte GPU als reinen PhysX-Beschleuniger ohne Schwierigkeiten nutzen können.
Auch das Nvidia PhysX wurde jetzt gleich in den Treiber intigriert, es ist jetzt nicht mehr nötig diesen zusätzlich zu installieren, alles PhysX Funktionen können ab jetzt über das Nvidia Control Panel eingestellt werden.
Computerbase.deAls letztes großes Feature der GeForce-180-Generation muss die PhysX-Beschleunigung herhalten (ComputerBase-Test), die nun auch Einzug in das Control Panel erhalten hat. Ein separates Tool für PhysX gibt es mit den neuen Treibern nicht mehr. Neu hinzugekommen ist die Möglichkeit, auf einer zweiten, separaten Grafikkarte die PhysX-Effekte berechnen zu lassen. Das war zwar bereits vorher möglich, jedoch noch sehr umständlich. So kann man bei zwei verschiedenen 3D-Beschleunigern im Control Panel einstellen, welcher davon PhysX berechnen soll.
  • Hinweise zum Vram Bug
Laut Computerbase:
Update 29.08.2007 09:08 Uhr: Wie uns James Wang, Technical Marketing Analyst bei Nvidia, soeben mitteilte, sind die von uns festgestellten Performanceverbesserung nicht mit dem scheinbar behobenen VRAM-Bug begründet, da dieser im ForceWare 163.44 immer noch vorhanden ist. So hat man im Treiber zwei Verbesserungen eingebaut, die den VRAM-Bug ein wenig neutralisieren. Nvidia modifiziert in dem neuen Beta-Treiber die Speicherkompression, was in Company of Heroes D3D10 auf einer 256-MB- und einer 320-MB-Karte den gemessenen FPS-Gewinn erklärt. Darüber hinaus verwaltet die G8x-GPU die Texturen in Stalker anders als mit den Vorgängertreibern, was dort den Performancevorteil erklärt. Laut James Wang wird der VRAM-Bug im nächsten offiziellen Treiber-Release behoben sein.
  • Wie funktioniert Ntune wieder?
Alle treiber und ntune runter, Drivercleaner drüber laufen lassen, Treiber installieren 158.19, ntunen installieren, altes panel freischalten.
  • Aktivierung des alten Treibermenüs:
Per "Ausführen" und *Regedit* in den Registrierungseditor gehen.
Unter HKEY_LOCAL_MACHINE/Software/NVIDIA Corporation/Global/NvCplApi/Policies die DWORD Werte der Schlüssel ContextUIPolicy und TaskbarUIPolicy von 2 auf 1 setzen.
  • Für die Leute mit älteren GForce Karten und Laptops
Hier gibt es eine Auswahl an aktuellen Treibern mit geänderter *.inf damit sie auch auf den älteren Karten laufen.
hier
  • Spezielle Treiber für Games
Code:
Unreal Tournament 3
[URL="http://www.nzone.com/object/nzone_ut3_downloads.html"]Hier[/URL]
Allgemeine Hinweise
Um das Geflame, Gespame oder sonstige Unannehmlichkeiten zu minimieren wird gebeten im Falle eines Versoßes den „Beitrag-melden“ - Button (
) zu benutzen! Natürlich auch im Falle eines Verstoßes der Forenregeln! ;)
Solche Beiträge oder nicht Themenbezogene Beiträge werden dann entfernt.
Der erste Post sollte immer aktuell gehalten werden. Sollte er einmal nicht aktualisiert worden sein, dann meldet euch per PN bei mir oder bei den anderen zuständigen Moderatoren!
Noch ist dieser Treiber aber nicht Offiziell verfügbar, also müssen wir uns mit dem neuen 182.50 WHQL begnügen.
Ja gut und schön, der wird aber erstmal Hauptsächlich auf die GTX 275 abgestimmt sein, bzw. überhaupt für die GTX 200 Serie, für meinen einen ist der eher egal.
Geforce 185.65
Vista 32Bit: http://www.nvidia.com/object/winvista_x86_185.65_beta.html
Vista 64Bit: http://www.nvidia.com/object/winvista_x64_185.65_beta.html
Unterstützte Produkte:
GeForce GTX 295
GeForce GTX 285
GeForce GTX 280
GeForce GTX 275
GeForce GTX 260
GeForce GTS 250
GeForce GT 140
GeForce GT 130
GeForce GT 120
GeForce 9800 GX2
GeForce 9800 GTX+
GeForce 9800 GTX
GeForce 9800 GT
GeForce 9600 GT
GeForce 9600 GS
GeForce 9600 GSO
GeForce 9500 GT
GeForce 9500 GS
GeForce 9400 GT
GeForce 9400
GeForce 9300 GS
GeForce 9300 GE
GeForce 9300
GeForce 9200
Nvidia GeForce 185.65 Beta
DEUTSCH
http://www.nvidia.de/object/winxp_185.65_beta_de.html
http://www.nvidia.de/object/winxp64_185.65_beta_de.html
http://www.nvidia.de/object/winvista_x86_185.65_beta_de.html
http://www.nvidia.de/object/winvista_x64_185.65_beta_de.html
Unterstütze Produkte
  • GeForce GTX 295
    GeForce GTX 285
    GeForce GTX 280
    GeForce GTX 275
    GeForce GTX 260
    GeForce GTS 250
    GeForce GT 140
    GeForce GT 130
    GeForce GT 120
    GeForce 9800 GX2
    GeForce 9800 GTX+
    GeForce 9800 GTX
    GeForce 9800 GT
    GeForce 9600 GT
    GeForce 9600 GS
    GeForce 9600 GSO
    GeForce 9500 GT
    GeForce 9500 GS
    GeForce 9400 GT
    GeForce 9400
    GeForce 9300 GS
    GeForce 9300 GE
    GeForce 9300
    GeForce 9200
Jap war nen Schreib- bzw. Kopier Fehler :lol:
@eta
Passiert schon mal,:xmas:
@Dancop
ich denke ich werde mal den 185.65 austesten und schauen ob da wirklich 22% mehr Leistung in Warhead bei rumkommen. Dann sollte 1920x1200 4xAA und Enthusiast Einstellung locker spielbar sein auf ner single 285. :)
Warum? Das hatte ATI mit dem 9.2 auch geschafft!
Mir wird der neue beta nichts bringen mit meinen 8800er Karten und laut NV wird sie ja nicht mal Unterstützt, werde ihn mir aber mal runter Laden und in die inf schauen.
Schön das Seegert200683 und ich den Beta jetzt doppelt gepostet haben :fresse:
Zur Not einfach die 8800 GTS 512 in die .inf einfügen. :d
Habe in meinem Post #1506 die Treiber in Deutsch ersetzt da sie grad Online kamen.
Könnte mir aber dennoch vorstellen dass der G92 mehr Leistung mit den neuen Treibern erreicht wenn er unterstützt wird, die G92 GTS ist doch im Prinzip die GT250 (oder wie die heisst ^^).
Gelöschter Beitrag
Dieser Beitrag wurde auf Wunsch des Nutzers gelöscht.
Nicht ganz, die 9800 GTX+ ist vergleichbar mit der GTS 250 da sie beide den G92b Chip haben ;)
Wie bekommt man bitte diesen Treiber auch für ältere Geräte zum Laufen. Kann wer, der sich damit auskennt, eine neue .inf datei bereitstellen, wäre das möglich
Was verstehst du unter "ältere Geräte" ???
So also in der inf vom 185.65 für Vista x64 stehen folgende Karten drin:
[Strings]
DiskID1 = "NVIDIA Windows Vista64 Driver Library Installation Disk 1"
NVIDIA = "NVIDIA"
NVIDIA_DEV.05E0.01 = "NVIDIA GeForce GTX 295"
NVIDIA_DEV.05E1.01 = "NVIDIA GeForce GTX 280"
NVIDIA_DEV.05E2.01 = "NVIDIA GeForce GTX 260"
NVIDIA_DEV.05E3.01 = "NVIDIA GeForce GTX 285"
NVIDIA_DEV.05E6.01 = "NVIDIA GeForce GTX 275"
NVIDIA_DEV.05EB.01 = "NVIDIA GeForce GTX 295 "
NVIDIA_DEV.0600.01 = "NVIDIA GeForce 8800 GTS 512"
NVIDIA_DEV.0601.01 = "NVIDIA GeForce 9800 GT"
NVIDIA_DEV.0602.01 = "NVIDIA GeForce 8800 GT"
NVIDIA_DEV.0604.01 = "NVIDIA GeForce 9800 GX2"
NVIDIA_DEV.0605.01 = "NVIDIA GeForce 9800 GT "
NVIDIA_DEV.0606.01 = "NVIDIA GeForce 8800 GS"
NVIDIA_DEV.060D.01 = "NVIDIA GeForce 8800 GS "
NVIDIA_DEV.0610.01 = "NVIDIA GeForce 9600 GSO"
NVIDIA_DEV.0611.01 = "NVIDIA GeForce 8800 GT "
NVIDIA_DEV.0612.01 = "NVIDIA GeForce 9800 GTX/9800 GTX+"
NVIDIA_DEV.0613.01 = "NVIDIA GeForce 9800 GTX+"
NVIDIA_DEV.0614.01 = "NVIDIA GeForce 9800 GT "
NVIDIA_DEV.0615.01 = "NVIDIA GeForce GTS 250"
NVIDIA_DEV.0622.01 = "NVIDIA GeForce 9600 GT"
NVIDIA_DEV.0623.01 = "NVIDIA GeForce 9600 GS"
NVIDIA_DEV.0625.01 = "NVIDIA GeForce 9600 GSO 512"
NVIDIA_DEV.0626.01 = "NVIDIA GeForce GT 130"
NVIDIA_DEV.0627.01 = "NVIDIA GeForce GT 140"
NVIDIA_DEV.062D.01 = "NVIDIA GeForce 9600 GT "
NVIDIA_DEV.062E.01 = "NVIDIA GeForce 9600 GT "
NVIDIA_DEV.0637.01 = "NVIDIA GeForce 9600 GT "
NVIDIA_DEV.0640.01 = "NVIDIA GeForce 9500 GT"
NVIDIA_DEV.0641.01 = "NVIDIA GeForce 9400 GT "
NVIDIA_DEV.0643.01 = "NVIDIA GeForce 9500 GT "
NVIDIA_DEV.0644.01 = "NVIDIA GeForce 9500 GS"
NVIDIA_DEV.0645.01 = "NVIDIA GeForce 9500 GS "
NVIDIA_DEV.0646.01 = "NVIDIA GeForce GT 120"
NVIDIA_DEV.065B.01 = "NVIDIA GeForce 9400 GT "
NVIDIA_DEV.06E0.01 = "NVIDIA GeForce 9300 GE"
NVIDIA_DEV.06E1.01 = "NVIDIA GeForce 9300 GS"
NVIDIA_DEV.06E6.01 = "NVIDIA GeForce G100"
NVIDIA_DEV.06E7.01 = "NVIDIA GeForce 9300 SE"
NVIDIA_DEV.06E9.01 = "NVIDIA GeForce 9300M GS"
NVIDIA_DEV.0847.01 = "NVIDIA GeForce 9100"
NVIDIA_DEV.084A.01 = "NVIDIA nForce 730a"
NVIDIA_DEV.084C.01 = "NVIDIA nForce 780a SLI"
NVIDIA_DEV.084D.01 = "NVIDIA nForce 750a SLI"
NVIDIA_DEV.0860.01 = "NVIDIA GeForce 9400"
NVIDIA_DEV.0861.01 = "NVIDIA GeForce 9400 "
NVIDIA_DEV.0864.01 = "NVIDIA GeForce 9300"
NVIDIA_DEV.0865.01 = "NVIDIA GeForce 9300 "
NVIDIA_DEV.0868.01 = "NVIDIA nForce 760i SLI"
NVIDIA_DEV.086A.01 = "NVIDIA GeForce 9400 "
NVIDIA_DEV.086C.01 = "NVIDIA GeForce 9300 / nForce 730i"
NVIDIA_DEV.086D.01 = "NVIDIA GeForce 9200 "
NVIDIA_DEV.0871.01 = "NVIDIA GeForce 9200 "
Also kann ich den mit meinen 8800 GTS G92 doch testen.
Gelöschter Beitrag
