[Sammelthread] J&W 790GX Extreme (AMD 790GX)
J&W 790GX Extreme
Spezifikationen
unterstützte Prozessoren
• Sockel AM2+/AM2 for AMD Phenom™FX / AMD Phenom™ / AMD Athlon™ 64 FX / AMD Athlon™ 64 X2 / AMD Athlon™ 64 / AMD Sempron™ Prozessoren (Unterstützung bis 140W TDP Prozessoren.)
Chipsatz
• AMD® 790GX + SB750 (Built in Radeon™ HD 3300 Graphics, DirectX® 10 Ready, with 128MB DDR3 side-port memory onboard)
• Marvell® 10/100/1000 Mbps Ethernet Controller
• Super I/O: Winbond W83627EHG chip
• Realtek ALC 888 HD Audio Codec
• 8M bit flash ROM
HyperTransport™
• HyperTransport™ 3.0/1.0, 5200/2000 MT/s
Memory
• Dual Channel DDR2 1066/800/667/533 support (DDR2 1066 support is dependent on CPU)
• Max Kapazität: 8 GB
• DIMM slots: 4
Interne I/O Anschlüsse
• 1 x 24-pin ATX power connector
• 1 x 8-pin ATX 12V power connector (compatible with 4-pin connector)
• 1 x floppy connector
• 1 x IDE connector (for 2 PATA devices)
• 6 x SATA 3Gb/s connectors (Support RAID 0,1,0+1,5)
• 1 x CPU fan connector
• 2 x system fan connectors
• 1 x front panel connector
• 1 x front audio connector
• 3 x USB 2.0 header for additional 6 USB 2.0 ports (by cables)
• 1 x buzzer connector
• 1 x IR connector
• 1 x COM connector
• 1 x CD-IN connector
• 1 x SPDIF In/Out header
Erweiterungs- Slots
• 3 x PCI-E x16 slots
• 1 x PCI-E x1 slot
• 2 x PCI slots
Anschlüsse hinten I/O
• 1 x PS/2 Keyboard port
• 1 x PS/2 Mouse port
• 1 x HDMI port
• 1 x S/PDIF In port (coaxial)
• 1 x S/PDIF Out port (optical)
• 1 x DVI port
• 1 x VGA port
• 1 x eSATA port
• 4 x USB 2.0 ports
• 1 x RJ45 GigaLAN port
• 6 x Audio ports (Line In / Line Out / MIC In / Rear Speaker Out / Center-Subwoofer Speaker Out / Side Speaker Out)
Form Faktor
• ATX
• 304.8mm x 245mm
H/W Monitoring
• Winbond W83627DHG
• System health status auto-detect and reported by BIOS
BIOS
• 8Mbit flash ROM, Award BIOS
Bundle Software
• Treiber- und Utility CD/DVD
Besonderheiten
• 100% Solid Capacitors, Debug LED onboard.
Links und Downloads
Bios - http://www.jwele.com/motherboard_detail.php?147#_bios
Treiber - http://www.jwele.com/motherboard_detail.php?147#_driver
Manual - http://www.jwele.com/motherboard_detail.php?147#_manual
Utilities - http://www.jwele.com/motherboard_detail.php?147#_util
Hier kann man das Board kaufen - http://www.jwele.de/
Ram Kompatibilität : Läuft
4gb Kit 2x 2gb OCZ Flex EX 9600 ( Mr.Wifi )
2gb Kit Crucial Ballistix Tracer - Sollen laut Aussagen eines Users sehr gut laufen :)
4GBCrucial Ballistix Tracer DIMM PC2-6400U CL4-4-4-12 ( Octa )
4gb TRANSCEND AxeRAM (TX1066QLU-4GK) Laufen sehr gut 600mhz @ 2,16v. ( Chubaka )
4gb Kit A-DATA XPG G Series DIMM PC2-6400U CL5-5-5-15 Laufen sehr gut ( Daniel N )
Man kann sagen dass das Board sehr gut für Ram OC geeignet ist, meldungen über nichtlaufenden Speicher gab es bis jetzt keine ;)
Kühler Kompatibilität :
Passt nicht
Scythe Kama Kama Cross ( Kollidiert mit Northbridge Kühler durch ausladenen Halteklammern, evtl. muss man mit Gewalt oder anders improvisieren )
Passt
IFX 14 ( niedrige Ram HS sind Pflicht wenn man Dualchannel benutzen möchte, weiterhin wird der erste Ram Slot von einem Lüfter blockiert oder man platziert ihn zwischen den Kühlblöcken des IFX und oder einen hinten ziehend )
Zerotherm FZ 120 ( gleiches Problem wie IFX )
Hexa Tabelle um die Multiplikatoren bzw. Vcore unter Pstates im Bios einzustellen ( Thx an Chubaka )
Interessantes über das Board :
http://www.xtremesystems.org/forums/showthread.php?t=191428
Die folgenden Screens zeigen was Monteboy ( AF ) an OC mit diesem Board erreicht hat ;)
http://www.hwbot.org/result.do?resultId=808042
Die 4GHz SM Tool stable von Chubaka ( 0849DPAW !!! )
4.1Ghz Primestable von Chubaka ( 0850 DPMW )
Bios Pics : Thx an Octa und CBOT
Ich hab ein viel dickeres Problem, ich bekomme meine CPU nie Primestable!
Muss jetzt Zähneknirschend wieder bei 3,22 anfangen :(
Aber jetzt hab ich ein kleines Problem, mein Speicher Takt der Onboard Grafik ist übertaktet aber ich hab nichts gemacht...
Getestet@ Ref Takt 200,HT-Link default,NB Frequency default und die Onboard Grafik ist trotzdem noch übertaktet?!
Hilfe :d
Graka OC ist doch schön :shot:
Hast du mal in der SB Config geguckt ob du dort evtl. was verstllt hast ? Die Onboard Graka lässt sich dort ocen.... :wink:
Graka OC schön hin oder her, hab ja sonst mit OC keine Probleme ;-) ist aber evtl. hinderlich beim max. OC darum frag ich...
Du meinst bestimmt die NB, hab leider nichts gefunden :-[
Wie siehts eigtl. mit den Temps der anderen Bauteile aus?
Hast du ein Wärmemessgerät?
hab mir vor das Board (JW-790GX-EXTREME) zu holen.
CPU soll ein 940BE werden.
Grafik soll die 4870X2 übernehmen.
Also eine vollwertige DRAGON Plattform :rolleyes:
Kann jemand Ram entfehlen. Die CPU soll min. auf 3,5-3,7Ghz
laufen.
Wie gross ist der unterschied zwischen 790GX und FX.
Da ich kein Crossfire plane müsste die Performance doch gleich
bleiben
bleiben
Bei Ram solltest du im Arbeitsspeicher Forumteil nachschauen, da es bisher keine Probs mit verschiedenen Rams auf dem Board gab! (Also such dir was aus :d)
GX->2x 8 Lanes für GraKas (und Onboard GraKa für OfficeRechner)
FX->1x 16 Lanes und 1x 8 Lanes für GraKas.
Heißt wenn du ein gutes Board mit SB750 UND FX findest, solltest du die perfekte Gamingplatform haben!
MfG OCta
der fx hat 2x 16 lanes
laut PCGH skalieren die 800 fast gleich wie die 1066.
Denk ich bleib dei 790GX (JW 790GX) da es doch eine sehr gute
OC Grundlage ist das Bard.
Mal ne Frage... Das ist doch eher die Ausnahme, dass 6400-er Ram SPD bis 533 programmiert haben? Oder hast Du das selber geflasht?
PS. Ich muss nun auch entscheiden, welches Board ich nehme für nen Phenom 2. Es soll nen Office PC geben.
Kann mich beim Besten Willen nicht entscheiden. Esata ist wichtig und wenn OC-fähigkeiten, dann eben auch konf. NB.
Hmm... Mann der Kuma kostet noch 85.- Sfr. :-) 1.52 = Euronen)
lol:wall::wall:
sorry hab mich grad was verschaut. Ich dachte es seine 4x1GB. :rolleyes:
weiß niemand was der chubaka für RAMs drin hat?
Würde mich brennend interessieren
aus dem startpost^^
Siehst du auch im Screen welche das sind. Habe extra den Reiter für SPD mit geöffnet. Nein hab die nicht selbst geflashed es sind 1066+ :d
Ich "musste" die nehmen weil mein Riesen CPU Kühler IFX14 die ersten Dimms verdeckt:fresse:
€: hab mir jetzt die Tracer 1066er bestellt 4x1GB und wehe die gehen nicht so wie ich das will....
ich werde mir die Patriot holen die sollen ja noch besser gehen wie die Transcend.
Dann lass mal sehen wenn du alles zusammen hast, muss ja nicht mit 4GHz CPU Takt sein ;)
Hast du evtl. noch einen link der das bestätigt was du sagst....
ich denke das klappt nichtmal immer mit wakü^^
also doch: geiles board und gut gehende cpu :asthanos:
Aber hallo :coolblue:
Bei Asus zb. kannst den CPU Multi im Bios "nur" bis x20 einstellen also 4GHz das wars :fresse:
Mit unserm Board und dem K10P-States im Bios kannst du so hoch wie du willst oder die CPU schafft :p
Bei denen müsste ich die Headspreader entfernen damit die unter meinen CPU Kühler passen...
und in Everest Read,Write,Copy und Latenz bekommen die nen guten abzuch von den Transcend und das bei 3,6GHz@560MHz@5-5-5-15-31-2T :d
die Transcend sind schon geil aber sehen so :kotz: kacke aus.
Passen die Patriot und ein Mugen 2 zusammen??
wie gesagt wenn du den Mugen drehst dann ja, ansonsten wird es eng...
Copy
Latenz
und die Patriot zum vergleich
ja aber ich glaub ich versuchs, wenns nicht klappen sollte hab ich ja eine
gute alternative ;)
so muss mir jetzt ein paar Bier reinkippen bis später zu wohl
Ähnliche Themen
