Starte jetzt mal einen Sammelthread für einen sehr guten P/L Mainboard.
MSI P45 Platinum - Technische Austattung:
CPU
• Supports Intel® Core 2 Extreme/Core 2 Quad/Core 2 Duo based processors in LGA775 package.
• Supports Intel® Yorkfield, Wolfdale in the LGA775 package.
• Supports FSB 1600* (OC)/1333/1066/800 MHz.
Chipset
• Intel® P43 Chipset
- Supports FSB 800/1066/1333/1600* (OC) MHz.
• Intel® ICH10 Chipset
- Hi-Speed USB (USB2.0) controller, 480Mb/sec, up to 12 ports.
- 6 SATAII ports with transfer rate up to 3Gb/s.
- PCI Master v2.3, I/O APIC.
- ACPI 2.0 compliant.
- Integrated AHCI controller.
Main Memory
• Supports four unbuffered DIMM of 1.8 Volt DDR2 667/800/1066 SDRAM, 16GB Max (To support 16GB max, please check the criteria at Intel website)
Slots
• One PCI Express x16 slot (PCI Express Bus SPEC V2.0 compliant).
• Two PCI Express x1 slots. (support PCI Express Bus specification v1.0a compliant)
• Three 32-bit v2.3 master PCI bus slots.
- Support 3.3v/5v PCI bus interface.
On-Board IDE/SATA
• One Ultra DMA 66/100/133 IDE controller integrated in JMicron® 368.
- Supports PIO, Bus Master operation modes.
- Can connect up to two Ultra ATA drives.
• SATAII controller integrated in ICH10 chipest
- Up to 3Gb/s transfer speed.
- Supports six SATAII ports by ICH10
Audio
• Chipset integrated by Realtek® ALC888
- Flexible 8-channel audio with jack sensing
- Compliant with Azalia 1.0 Spec
- Meet Microsoft Vista Premium spce
LAN
• Supports PCI Express LAN 10/100/1000 Fast Ethernet by Realtek 8111C.
IEEE1394
• Chipset integrated by JMicron® 381
- Transfer rate is up to 400Mbps
Internal I/O Connectors
- ATX 24-Pin power connector
- 4-pin ATX 12V power connector
- CPU / System x 2 FAN connectors
- CD-in connector
- Front panel audio connector
- Front panel connector
- 1 x chasis intrusion connector
- 4 x USB 2.0 connectors
- 1 x Floppy disk drive connector
- 6 x Serial ATAII connectors
- 1 x ATA133 connector
- 1 x SPDIF-Out connector
- Clear CMOS Jumper
- 2 x HW-OC FSB jumpers
- 1 x IEEE1394 connector support additional 1 port (optional)
- 1 x TPM module connector (optional)
Dimension
• 30.5cm(L) x 22.0cm(W) ATX Form Factor
Mounting
• 6 mounting holes.
Kritik ist selbstverständlich erwünscht
grezz
Crunge78
 für einen sehr guten P/L Mainboard.MSI P43
Back Panel
- 1 x PS/2 keyboard
- 1 x PS/2 mouse
- 1 x Parallel port
- 1 x Serial port
- 1 x 6 in 1 audio jack
- 4 x USB 2.0 ports
- 1 x RJ45 LAN jack
- 1 x IEEE1394 port (optional)
Weitere MSI P43 Platinen:
P43 Neo3-F (PCB 1.0)--------P43 Neo3-F (PCB 1.1)--------P43 Neo3-FR (PCB 1.1)
Back Panel
- 1 x PS/2 keyboard
- 1 x PS/2 mouse
- 1 x Parallel port
- 1 x Serial port
- 4 x USB 2.0 ports
- 1 x RJ45 LAN jack
CPU
Chipset
Main Memory
Slots
On-Board IDE/SATA
Audio
LAN
IEEE1394
- CD-in connector
- Clear CMOS Jumper
Dimension
Mounting
• 6 mounting holes.
Product Accessories
3CD´s waren bei mir mit bei:
HDD Backup
Mainboard CD für XP
Mainboard CD für Vista
Bios update
http://www.msi-technology.de/index.php?func=downloaddetail&type=bios&maincat_no=1&prod_no=1484
Treiber
http://www.msi-technology.de/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=1484
Utility
http://www.msi-technology.de/index.php?func=downloaddetail&type=utility&maincat_no=1&prod_no=1484
CPU Tabelle
Daten Blatt
http://web-datenblatt.de/xslt/getDataSheet?method=getDataSheet&iwsKey=iOx/7FqpVPKLW8i1+axr/w&customSheet=true&cnetPid=S5531903
HDD Backup
Mainboard CD für XP
Bios update
Treiber
Utility
CPU Tabelle
Daten Blatt
grezz
Crunge78
 . Ansonsten ein solides Board. Habe es mal verbaut.
 läuft mit 2,2V
 läuft mit 2,2V
