maninblack
Semiprofi
ok passt, aber warum steht dann da 5400-7200rpm
?Follow along with the video below to see how to install our site as a web app on your home screen.
?The manufacturer is careful in not directly citing spindle speed, instead nominally positioning the Caviar GP as a "7200 RPM-class" drive. Under its "IntelliPower" moniker, WD claims a "A fine-tuned balance of spin speed, transfer rate and cache size designed to deliver both significant power savings and solid performance." Some folks have misinterpreted some admittedly vague specs on WD's website. Under "Rotational Speed," the manufacturer cites "IntelliPower (5400 to 7200 RPM)." This does not mean the drive dynamically changes its spindle speed during operation... indeed, such a feature would entail considerable mechanical engineering and would in many ways defeat the point -- rapidly accelerating and decelerating the spindle's speed would increase rather than decrease net power draw. Rather, the IntelliPower term indicates that the GP family as a whole does not have a set spindle speed (nor a set buffer size, for that matter). Different capacity points may feature differing spin speeds and buffer sizes. For those that must know, WD admits "sub-6000 RPM operation" for the 1-TB Caviar GP (more on this on the following page).
We have to take a different approach when assessing the Caviar GP's seek time since WD does not explicitly give users the drive's spindle speed. The GP turns in a measured access time of 15.0 ms, a score that lags the 7200-RPM WD7500AAKS by a significant margin. The WD7500AAKS's measured seek time when accounting for 4.2 ms of 7200 RPM latency is 9.5 ms (missing the firm's claim by over half a millisecond). Assuming the GP also shares such a seek time, that leaves us with 15 ms [measured access time] minus 9.5 ms [assumed seek time] which equals 5.5 ms, almost exactly the rotational latency associated with a 5400 RPM spindle speed.
The Caviar GP's outer-zone score clocks in at 79.8 MB/sec and as a result lags the older, less dense WD7500AAKS by 21%. Assuming similar sector-per-track zone configurations, a 7200 RPM drive would boast a 33% advantage over a 5400 RPM unit. The difference between the GP and the WD7500AAKS is less than that, likely of course due to a density advantage on the GP's part. Nevertheless, this second low-level diagnostic again suggests a 5400 RPM spindle speed.
Marketing.ok passt, aber warum steht dann da 5400-7200rpm?
Ich Suche eine sehr leise und möglichst virbrationsarme HD ab 500GB, bitte um Tips
Habe derzeit noch richtig alte Dinger drin
SAMSUNG SP2504C SataII
SAMSUNG SP1614C SataI
Laufen aber seit der ersten Stunde gut und relativ leise, nie Probleme gehabt bis auf dass mein Gehäuse nach einer unbestimmten Zeit anfängt zu vibrieren, nicht dauerhaft sondern im Interval, ganz schwer zu beschreiben...
Hallo.
Ich möchte mir eine neue Platte gönnen. ^^
Bedingungen:
1. viel Platz (mindestens 500gb)
2. Vibration egal
3. Lautstärke egal
4. Hitzeentwicklung egal
5. Geschwindigkeit fast egal (Flaschenhals ist eh USB 2.0)
6. Kein RAID
7. 3,5" gross (normal/standard)
Die Platte wird in ein externes USB Gehäuse gepackt und nur selten angeschlossen. Sie dient nur für Backups/Archivierung und wird selten länger als eine Stunde am Stück laufen.
Ich habe bereits einige Samsung Platten und daher folgende rausgesucht:
http://preisvergleich.hardwareluxx.de/deutschland/a369604.html (1 TB für 75,90 Euro)
Wenn ich schon mal beim Fragen bin: Ich spiele auch mit dem Gedanken mir eine SSD zu kaufen, um darauf dann mein WinXP zu installieren. Gibt es denn schon SSD unter 150 Euro, die spürbar die Performance des Systems erhöhen?
MfG, Goderion
Tag
Welche 1TB HDD unter 100€ eignet sich am besten als Systemplatte? Samsung f1?
mfg Mpx1
€ Einigermaßen leise sollte sie auch sein.
Welche 500GB 3,5" SATA2 Festplatten haben denn nur 1 Platter?
Samsung F2 und Seagate 7200.12 is klar. Wie sieht es bei WD aus?
Zu meiner Situation:
Habe z.Z. einen HP Pavilion m8180.de mit einer Seagate ST3500630AS Festplatte. Es ist ein komplett PC. Seit dem ersten Tag macht die Platte ganz unregelmäßig sehr laute mechanisch klackernde Geräusche, zwar immer nur kurz (1-3 Sekunden) aber es tritt auf und hört sich einfach nicht gut an. Habe schon zig Festplattendiagnosetools durchlaufen lassen, auch Seagate-eigene Tools und auch der Support meinte das ist wohl bei dem Modell normal. Nungut, ich wills trotzdem nicht drauf ankommen lassen. Leider weiß ich jetzt garnicht genau was ich da einbauen kann. Ich glaube es sollte eine 3,5 Zoll SATA werden. Ob S-ATA oder S-ATA II weiß ich gar nicht habe auch wenig Ahnung wo ich das nachschauen kann, bei EVEREST und Konsorten wird ja auch nur angezeigt was drin ist und nicht was man reinpacken könnte. Passt eigentlich so eine 3,5 Zoll Platte auch 100%ig rein in meinen TOWER? Ist ja ein HP komplettrechner und innen wohl eher enger.
Da ich die Platte nicht einschicken will (ich hab keine Lust meine sensiblen Daten durch die Welt zu schicken), wollte ich nun eine neue kaufen.
Anforderungen:
- mind. 500GB
- leise!
- wenig Hitzeentwicklung (ist ein sehr kleiner Tower)
- wenig Vibration
- kein RAID
- keine Seagate Platte
Ich denke der Teil zu Festplatte intern beschreibt meine Situation. Nun brauche ich noch eine zusätzliche externe Platte, auf der ich in regelmäßigen Abständen Backups von meinem System machen kann. Ich habe eigentlich vor dieses Backup alle 2-3 Wochen zu machen und dann von der kompletten Platte (wie weiß ich noch nicht ganz aber so lautet der Plan). Die Platte wird dann also schätzungsweise so eine Stunde laufen oder länger, je nachdem ob ich mich dazu entscheide das Backup seltener zu machen oder die Platte vielleicht ständig angeschlossen zu lassen.
Anforderungen:
- 1TB
- wenns geht leise
- wenns geht wenig Hitzeentwicklung
- wenns geht wenig Vibration
- kein RAID
Die WD Platten mit nur einer 500GB Scheibe werden wohl erst die nächsten Monate die Platten mit 2x250GB ablösen, das wird eine ganze Zeit parallel laufen bis sich nur noch die 500er Scheiben im Umlauf befinden![]()
