[Sammelthread] DFI LANparty DK P45-T2RS / T3RS / Plus (Intel P45) [3]
@Fresh_Thing: Hier sind meine Settings. Das muss doch ein Bug sein, wenn die Einstellungen vorher stabil waren. Und nicht nur diese Einstellungen...
>CPU Feature:
Thermal Management Control.......... - Disabled
PPM(EIST) Mode...................... - Disabled
Limit CPUID MaxVal.................. - Disabled
CIE Function........................ - Disabled
Execute Disable Bit................. - Disabled
Virtualization Technology........... - Disabled
Core Multi-Processing............... - Enabled
>DRAM Timing:
Enhance Data transmitting........... - Normal
Enhance Addressing.................. - Normal
T2 Dispatch......................... - Disabled
>Clock Setting Fine Delay Press Enter:
DLL And RCOMP Settings.............. - By User
Ch1 Dram Defaul Skew................ - Model 3
Ch2 Dram Defaul Skew................ - Model 3
RCOMP Settings...................... - Model 1
Fine Delay Step Degree.............. - 140ps
Ch1 Clock Crossing Setting.......... - More Relaxed
DIMM1 Clock Fine Delay.............. - Current[2396ps]
DIMM2 Clock Fine Delay.............. - Current[2396ps]
Ch1 Control0 Fine Delay............. - Current[268ps]
Ch1 Control1 Fine Delay............. - Current[268ps]
Ch1 Control2 Fine Delay............. - Current[268ps]
Ch1 Control3 Fine Delay............. - Current[268ps]
Ch1 Command Fine Delay.............. - Current[394ps]
Ch2 Clock Crossing Setting.......... - More Relaxed
DIMM3 Clock Fine Delay.............. - Current[2066ps]
DIMM4 Clock Fine Delay.............. - Current[2066ps]
Ch2 Control0 Fine Delay............. - Current[48ps]
Ch2 Control1 Fine Delay............. - Current[48ps]
Ch2 Control2 Fine Delay............. - Current[48ps]
Ch2 Control3 Fine Delay............. - Current[48ps]
Ch2 Command Fine Delay.............. - Current[394ps]
Ch1 Ch2 Common Clock Setting........ - More Relaxed
Ch1 RDCAS GNT-Chip Delay............ - Auto
Ch1 WRCAS GNT-Chip Delay............ - Auto
Ch1 Command To CS Delay............. - Auto
Ch2 RDCAS GNT-Chip Delay............ - Auto
Ch2 WRCAS GNT-Chip Delay............ - Auto
Ch2 Command To CS Delay............. - Auto
Flex Memory Mode..................... - Auto
CAS Latency Time (tCL)............... - 5
RAS# to CAS# Delay (tRCD)............ - 5
RAS# Precharge (tRP)................. - 5
Precharge Delay (tRAS)............... - 18
All Precharge to Act................. - 6
REF to ACT Delay (tRFC).............. - 54
Performance Level.................... - 14
>Read delay phase adjust Press Enter:
Channel 1 Phase 0 Pull-In........... - Auto
Channel 1 Phase 1 Pull-In........... - Auto
Channel 1 Phase 2 Pull-In........... - Auto
Channel 1 Phase 3 Pull-In........... - Auto
Channel 1 Phase 4 Pull-In........... - Auto
Channel 2 Phase 0 Pull-In........... - Auto
Channel 2 Phase 1 Pull-In........... - Auto
Channel 2 Phase 2 Pull-In........... - Auto
Channel 2 Phase 3 Pull-In........... - Auto
Channel 2 Phase 4 Pull-In........... - Auto
Write to PRE Delay (tWR)............ - 14
Rank Write to Read (tWTR)........... - 11
ACT to ACT Delay (tRRD)............. - 3
Read to Write Delay (tRDWR)......... - Auto
Ranks Write to Write (tWRWR)........ - Auto
Ranks Read to Read (tRDRD).......... - Auto
Ranks Write to Read (tWRRD)......... - 4
ALL PRE to Refresh.................. - 10
>Voltage Settings:
CPU VID Special Add................. - + 225mV
DRAM Voltage Control................ - 2v
SB Core/CPU PLL Voltage............. - 1.55v
NB Core Voltage..................... - 1.2700v
CPU VTT Voltage..................... - 1.20v
VCore Droop Control................. - Disabled
Clockgen Voltage Control............ - normal
CPU GTL0/2 REF Volt................. - 0.67x
CPU GTL 1/3 REF Volt................ - 0.67x
North Bridge GTL REF Volt........... - 0.63x
FSB Vref............................. - 23
Genie BIOS Settings:
Exist Setup Shutdown................ - Mode 2
Exist Shutdown After AC loss........ - Enabled
O.C Clock Fail Retry Counter........ - 0
O.C Clock Fail CMOS Reloaded........ - Disabled
CPU Clock Ratio..................... - 8
Target CPU Clock.................... - 3,8GHz
CPU Clock........................... - 475
Boot Up Clock....................... - Auto
CPU Clock Amplitude................. - 800mV
CPU Clock0 Skew..................... - 400ps
CPU Clock1 Skew..................... - 400ps
DRAM Speed.......................... - 333/667
Target DRAM Speed................... - 950 MHz
PCIE Clock.......................... - 102mhz
CPU Spread Spectrum................. - Disabled
PCIE Spread Spectrum................ - Disabled
@ Tobi
Könnte sein das durch Linux so eine art schutz vorm Formatieren drauf ist.
Sicher die Daten und mach die Platte ganz platt !!!
@ Master
Bilder hätten auch gereicht ;)
So hohe CPU Clock Skew's sind doch net nötig.
Meine stehen bei 100
Was für Hardware hast du überhaupt ???
Ja hmm Bilder, ich hab' gerade nur ein Nokia 6280 2MP zur Hnd und die Bilder wollt ihr nicht sehen xD
Q9550 E0
DFI DK P45-T2RS-PLUS
4GB OCZ Reaper 1066-DDR2 (wird auf DFI-Seite mpfohlen)
HD 3450 ^^
BeQuiet! P7 550W
Vista Home P. x64
SpinPoint F1 320GB
Das ist nicht schwer. Gehe ganz normal ins Bios und stelle die NB Core Voltage mal so auf 1,20V, wenn das noch nicht reicht kannst du ja noch weiter nach oben gehen.
Hallöchen. Hab die NB Spannung schon auf 1.23V aber Memtest haut immer noch Fehler en massé raus. Kanns noch woanders dran liegen, bzw. wieviel Spannung kann ich risikolos geben?
also ich bin ein wenig am verzweifeln. hab inzwischen die nbcore auf 1.24V und dram auf 1,98V angehoben aber es kommen immer noch fehler. wie hoch soll ich denn da noch gehen? HILFE :(
geh doch noch ein oder zwei stufen höher mit den beiden spannungen!
ich teste grad mal manuelle timings, die waren auch nicht dem datenblatt entsprechend. hab die auf 5-5-5-18 gestellt und nb sowie dram spannung noch ne stufe angezogen, gibt nu schon deutlich weniger fehler, gehe noch eine stufe spannung mehr, aber dann muss eigentlich mal schluss sein, oder? was kann ich noch versuchen?
also es muss echt an den 4gb liegen, habe jetzt mal nur einen riegel entfernt und mit 3gb läuft memtest ohne fehler durch, und das sogar ohne jegliche spannung zu erhöhen. keine ahnung warum...auf dem board ist weder eine bank defekt noch spinnt der speicher, die hab ich schon einzeln getestet. seltsam, aber ich glaub ich find mich mit 3gb ab
@ Tobi
Kannst du das näher erläutern? Was soll ich mir unter "schutz vor formatieren" vorstellen???
:confused:
Mal abgesehen davon dass ich mir darunter grad gar nix vorstellen kann kommt das Setup ja nicht mal annähernd zu dem Punkt wo irgendwas formatiert werden soll!
Ich glaub ich werde versuchen irgendwo nochmal ne andere SATA platte aufzutreiben zum testen
@ hummelmm
Stell mal bitte die 3 Optionen die du unten auf dem Bild siehst auf Nominal !!!
Und auf dem Bild unten stellst du alles so ein wie du es siehst bis auf:
TRFC - den auf 60
Performance LVL - auf 11
Und FSB Vref............................. - 23 ......auf ...
FSB Vref............................. Auto stellen !
Denn wenn der Wert von FSB Vref nicht stimmt ...gibt es Reboot`s oder das System will zu frecken nicht hoch fahren !
Aber es lief ja bei ihm mit diesen settings
Was mir aber auch noch auffällt,sein PL ist ziemlich entschärft !
Ich bräuchte mal ein paar FSB 600 Settings
NB / FSB Vref / VTT / ....usw... !
Bitte mal posten wer FSB 600 primestable hat !
hallo zusammen,
kann mir jemand sagen, ob auf das DK P45 T2RS Plus der Alpenföhn Groß Clock'ner drauf passt? Habe schon in den anderen Sammelthreads dieses Mobos geschaut und nichts gefunden..
mfG
xXRadioaktivXx
vREF auf Auto kann man bei den Settings vergessen. vref 23 ist perfekt, habs ausgetest.
Wegen PL, ich muss noch gucken wie weit ich den noch runterkriege. Nicht, dass das Sys erst mit PL 14 stabil ist.
Passt der ifx 14 aufs Plus ?
Ja klar, aber es kein Platz mehr zwischen der Kühlerhalteklammer und der oberen Ende der Heatpipe.
Ich glaube das sollte mal in den ersten Post rein.
@Felix the Cat:
Schreibe den IFX-14 mal bei "Passt mit Problemen". Oder da wo du mit den in diesem Post geschriebenen Problemen einsortieren würdest.
schade eigentlich, denn so wie es aussieht werden wir wohl überhaupt nicht mehr mit nem neuen bios bedient, sind wahrscheinlich alle mit den x58 boards beschäftigt.
richtig, bin ma gespannt ob da was neues kommt. Immoment läuft das Board @ Standard bei mir. Es will mir nichts mehr gelingen.......
ich denk mal eher nicht denn wie gesagt konzentrieren sich diese idioten auf den x58 chipsatz, leider.
ein neues bios für das dk p45 plus ist schon längst überfällig und hätte auch schon längst rauskommen müssen.
FSB 600 @ 4200 Mhz
1:1 Ram 1200 Mhz
PL : 11
So langsam kommen meine 24/7 Setting`s ! :d :teufel:
Wenn ich die Diskussionen hier so verfolge, ist auch aktuell vom DFI DK P45 eher abzuraten. Gerade für mittelmäßig Erfahrene wie mich. Sehe ich das richtig?
Also Gigabyte P45-UD3R. (?)
MfG Jan
nein
wenn man gewillt ist etwas (oder etwas mehr^^) zeit zu investieren kann man sehr gute ergebnisse erreichen.
wenn man aber lieber alles zusammensteckt und es muss laufen ist man mitm anderen board evtl besser beraten
Weiß einer wie man den VID Bug wegbekommt?
Wenn ich EIST an habe bootet der Rechner immer mit der IDLE EIST Spannung ins Windows. Die ist dann logischerweise viel zu niedrig wenn die CPU beim booten mit Volllast läuft und trotdem nur die EIST Spannung anliegt.
Die Folge, entweder der Recner bootet nicht, oder die CPU muß mit viel mehr VCore betrieben werden nur damit der Rechner startet.
Nochmal anders erklärt:
Die CPU braucht ohne EIST 1.264 VCore für 4GHz bei Prime, mit EIST 1.344, aber nur weil beim starten dann nur 1.216 anliegen, weil das Board mit der Energiesparspannung startet. Die 1.216 sind sozusagen die gringste Spannung die die CPU bei 4GHz braucht um zu starten.
Es muß doch möglich sein, dass beim booten die Last Spannung anliegt und dann im Windows erst mit EIST runtergetaktet und die Spannung gesenkt wird. So sollte es ja eigentlich funktionieren...!
Da hat man schon ein Board bei dem EIST und overclocking funktioniert und durch so nen blöden Bug kann man es dann trotzdem nicht nutzen!
Jemand ne Idee??
Adapter
Hört hört :fresse: ich hab den nur manchmal aber will ihn unbedingt gezielt hervorrufen für 4GHz Runs ;) ich glaube der tritt auf wenn man Profile lädt so kommt mir das vor, wenn mans manuell alles eingibt, hatt ich den noch nicht.
Ich habe schon so viel versucht, es ist immer das gleiche, sobald EIST an ist wird die Spannung schon beim starten gesenkt, nicht erst im Windows so wie es eigentlich sein sollte.
Du hast den Bug also nicht oder tritt er bei dir nur bei bestimmten Einstellungen auf?
Adapter
Tritt nicht immer auf allerdings wechsle ich ja mehrfach pro Tag die CPUs kann auch daran liegen ;) wäre jetzt nur meine erste Vermutung, hab aber noch zu viel zum testen bevor ich mir das genauer anschauen kann.
Da wird nix falsch ausgelesen ;)
Ein paar seiten zurück sind auch screens von meinem Q9550 @ 471FSB und einer VTT von 1,18 :drool:
Das haben auch viele für nicht möglich gehallten aber mit dem DK P45 und den richtigen settings ist alles möglich :hail:
