[Sammelthread] Intel E5x00 OC Thread
oli792
Intel Pentium Dual Core E5x00 OC-Thread​
Regeln:
Screen mit
  • Prime95 v25.x min. 1,5h Echtzeit
  • Cpu-Z Registerkarte "Cpu"
  • Cpu-Z Registerkarte "Memory"
  • Temperaturwerte mit Realtemp/Coretemp
  • Taskmanager Registerkarte "Prozesse" mit Prozesszeit und Ram-Auslastung
Ein Post sollte so aussehen:
Code:
Takt Name/CPU-Bezeichnung/Stepping/Batch/Volt/VID/FSB/Ram/Ramtimings/Board/Kühlung
+Screen
Beispiel:
Code:
3666MHz R3ViL0/E5200/Stepping 6 Rev.M0/Batch 3828A646/1.24V/1.125V/FSB 333MHz/4x1024MB/3-4-3-8 @2.1V/Gigabyte P35-DS3/Scythe Ninja
+Screen
Tools:
Links:
Dann mal frohes OCen! :bigok:
Liste:
Code:
E5200:
4625MHz Dark_angel/E5200/Stepping 6 Rev.M0/1.440V/1.2375V/FSB 370MHz/2x2048MB/5-5-5-15@1.9V/Gigabyte GA-965P-DS3P rev.2.0/Zerotherm Nirvana
4600MHz st0ny/E5200/Stepping 6 Rev. M0/Batch 833B307/1.424V/1.2500V/FSB 368MHz/2x1024MB/5-5-5-15-2T @1.92V/DFI DK P35-T2RS/Wakü (Zern PQ+)
4450MHz fanello/E5200/Stepping 6 Rev.M0/Batch 833B307/1.376V/1.2500V/FSB 356MHz/2x1024MB/5-5-5-15 @1.8V/DFI LANparty DK P35-T2RS/EKL Brocken
4300MHz Dark_angel/E5200/Stepping 6 Rev.M0/1.440V/1.0500V/FSB 344MHz/2x2048MB/5-5-5-15@1.9V/Gigabyte GA-965P-DS3P rev.2.0/Zerotherm Nirvana
4204MHz st0ny/E5200/Stepping 6 Rev.M0/1.456V/FSB 336MHz/1x1048MB/5-5-5-15@1.9V/DFI UT P35-T2RS/Wakü(EK Supreme)
4150MHz Leinad78/E5200/Stepping 6 Rev.M0/Batch 3825A387/1,46V/1,1375V/FSB 332MHz/2x1024MB/5-6-6-15@1,8V/Asus P5N7A-VM/Xigmatek HDT-S1283
4020MHz duplex/E5200/Stepping 6 Rev.M0/Batch 833B307/1.20V/1.2500V/FSB 335MHz/2x2048MB/5-4-4-12 @1.8V/Gigabyte EP45-DS3L/Scythe Mugen
4008MHz Egge/E5200/Stepping 6 Rev.C0/Batch 38J88469/1,1500V/1,360V/FSB 334MHz/4x1024MB/5-6-6-19@2,0V/Gigabyte GA-P35-DS3R/Zalman9700
4005MHz TROLL/E5200/Stepping 6 Rev.M0/1.38V/FSB 333MHz/2x2048MB/5-5-5-15@1.8V/Asrock P43 Twins/Wakü
4003MHz Leinad78/E5200/Stepping 6 Rev.M0/Batch 3825A387/1,448V/1,1375V/FSB 320MHz/2x1024MB/5-6-6-15@1,8V/Asrock ConRoe1333-D667 R1.0/Xigmatek HDT-S1283
4.000MHz Kr0n05//E5200/Stepping A Rev.R0/1,408V/FSB 320MHz/2x2048MB/5-5-5-18@2,1V/DFI DK P45 T2RS+/Lukü
4000MHz >>Mü]-[Li<< /E5200/Stepping 6 Rev. M0/Batch 3848A240/1.408V/1.1875V/FSB 320MHz/2x2048MB/5-5-5-15-2T @2.0V/GB EP45-DS3R/Wakü (EK Supreme)
3887MHz TROLL/E5200/Stepping 6 Rev.M0/1.32V/FSB 338MHz/2x2048MB/5-5-5-15@1.8V/Asrock P43 Twins/NINJA CU
3752MHz Leinad78/E5200/Stepping 6 Rev.M0/Batch 3825A387/1,304V/1,1375V/FSB 300MHz/2x1024MB/5-6-6-15@1,8V/Asrock ConRoe1333-D667 R1.0/Xigmatek HDT-S1283
3750MHz R3ViL0/E5200/Stepping 6 Rev.M0/Batch 3828A646/1.296V/1.125V/FSB 300MHz/4x1024MB @DDR2-1000/5-5-5-12 @2.0V/Gigabyte P35-DS3/Scythe Ninja +Slipstream 500
3463MHz Leinad78/E5200/Stepping 6 Rev.M0/Batch 3825A387/1,184V/1,1375V/FSB 277MHz/2x1024MB/5-6-6-15@1,8V/Asrock ConRoe1333-D667 R1.0/Xigmatek HDT-S1283
3450MHz UsAs/E5200/Stepping 6, Rev. M0/3840A510/1.264/1.2250/276/2x1024, 1x2048/5-5-5-15@1.8/Biostar TP43D2-A7/Zalman CNPS 9500AT
3450Mhz maaco90/E5200/Stepping 6 Rev.M0/1.28/1.225/FSB 300Mhz/1x2048MB/5-5-5-15 @1.8V/Gigabyte GA-EP43-DS3L/Scythe Mine Cooler Rev.A + S-Flex 1200
3333MHz Chrisch / E5200 / Stepping 6 Rev.M0 / Batch Q838B006 / 1.136v / 1.0875v / FSB 266MHz / 2x1024MB / 5-5-5-15 @ 2V / Asus P5QL-EM / Wakü (Zern PQ)
2515MHz Leinad78/E5200/Stepping 6 Rev.M0/Batch 3825A387/0,96V/1,1375V/FSB 360MHz/2x1024MB/5-4-4-12@1,8V/Asrock ConRoe1333-D667 R1.0/Xigmatek HDT-S1283
Na dann wollen wir doch mal :)
Leinad78/3327MHz/E5200/Stepping 6 Rev.M0/Batch 3825A387/1,168V/1,1375V/FSB 266MHz/2x1024MB/5-6-6-15@1,8V/Asrock ConRoe1333-D667 R1.0/Xigmatek HDT-S1283
TROLL/3887MHz/E5200/Stepping 6 Rev.M0/1.32V/FSB 338MHz/2x2048MB/5-5-5-15@1.8V/Asrock P43 Twins/NINJA CU
Leinad78/3463MHz/E5200/Stepping 6 Rev.M0/Batch 3825A387/1,184V/1,1375V/FSB 277MHz/2x1024MB/5-6-6-15@1,8V/Asrock ConRoe1333-D667 R1.0/Xigmatek HDT-S1283
Regeln:
Screen mit
traurig wenn der thread-ersteller sich schon nicht an seine eigenen regeln hält...
Leinad78/3752MHz/E5200/Stepping 6 Rev.M0/Batch 3825A387/1,304V/1,1375V/FSB 300MHz/2x1024MB/5-6-6-15@1,8V/Asrock ConRoe1333-D667 R1.0/Xigmatek HDT-S1283
hab das andere vergessen und außerdem sehe ich das nicht so eng. danke trotzdem ;)
Freut mich zu hören, dann sollte das ja kein Problem sein...
Leinad78/4003MHz/E5200/Stepping 6 Rev.M0/Batch 3825A387/1,448V/1,1375V/FSB 320MHz/2x1024MB/5-6-6-15@1,8V/Asrock ConRoe1333-D667 R1.0/Xigmatek HDT-S1283
Wird bestimmt falsch ausgelesen :eek:
Mein Bruder hat die CPU samt MSI P43 Board bestellt.
Werde auf die CPU meinen Quadcore Boxed Kühler setzen, damit sollten 3,2GHz drin sein :lol: Irgendwann kommt ein anderer rauf :xmas:
Soweit ich weiß sind die 45nm Boxed ja wesentlich kleiner und schlechter *g*
hat einer mal die maximale FSB Grenze getestet? Hab auch nen E5200 hier und wundere mich warum ich keinen 400er FSB auf dem Gigabyte P35-DS3 hinbekomme...
edit: so, bis FSB 380 bekomme ich nen Boot, danach nur noch nen Blackscreen... auch mit erhöhter vFSB oder vMCH...
Da hat doch Intel garantiert eine Sperre eingebaut, oder?
Leinad78/2515MHz/E5200/Stepping 6 Rev.M0/Batch 3825A387/0,96V/1,1375V/FSB 360MHz/2x1024MB/5-4-4-12@1,8V/Asrock ConRoe1333-D667 R1.0/Xigmatek HDT-S1283
Meiner schafft auch keine 400MHz FSB, auch bei ca. 380 schluss..
Kleines Update:;)
TROLL/4.005MHz/E5200/Stepping 6 Rev.M0/1.38V/FSB 333MHz/2x2048MB/5-5-5-15@1.8V/Asrock P43 Twins/Wakü
Ist mir auch aufgefallen....
Liegt wohl daran,das ich Prime vor dem neuen Run nicht beendet habe...
I'dont Know....
Aber fürs Faken bin ich zu alt....;)
wollt ich damit auch nich sagen. allerdings bin ich ein freund von bedingungsgleichheit und um allen die selben grundlagen zu geben, gibts halt die 1,5h regel.
wobei der wert ansich ganz gut sein sollte :) ich brauch unbedingt mal nen neues mainboard :)
Meiner macht "nur" 3,6 ghz mit bei ca 1.35 V ,darüber hinaus wirds dann instabil ich hab ein MSI P35 NEO , meint ihr wenn ich die NB Spannung anhebe geht da noch was?
Ich auch, aber wenn man in so einem niedrigem FSB-Bereich bleibt, sollte das nicht unbedingt ein Problem sein. Obwohl man hier auch die Güte der verbauten Spannungswandler und CO. beachten muss. Mich wundert nur, dass fast alle aus der obigen Liste ein Asrock-Board haben.
So sieht es aus.
Bin mit dem P43 Twins sehr zufrieden!;)
OC per Asrock Tool im Desktop funktioniert auch sehr gut.
Wenn man sich diese CPU kauft,dann achtet man normalerweise extrem auf Preis/Leistung....
Ist mittlerweile mein zweites Asrock Brett ( 1.A770 Crossfire Am2+),und muß sagen für den Preis eine echte Alternative,keine Zicken,preiswert,was will man mehr?? ;-))
@Temp
Da mein E5200 eine sehr niedrige Vid besitzt (1.125v) wird die CPU ziemlich warm.
Bin mit Wakü bei Prime Custom schon bei 58-60° mit anliegenden 1.37v....
So sieht es aus.
@Temp
Deine Kombi ist eigentlich genau das, was ich mir zulegen will. Als kostengünstiger Lan-Rechner wäre das optimal mit einer 4850 zB. ;) P/L ist da Top. Ich hab hier noch einen E8400 mit 1.25Vid, der wird bei 50° gehalten mit OC mit einem Freezer 7 Pro auf Silent-Betrieb. Da konnte man noch am Kühler sparen :p
