Vista
Legende
- Ort
- im PC
- Desktop System
- System Wahnwitz
- Laptop
- Intel Xeon W-3175X, 28C/56T, 3.10-3.80GHz LGA3647
- Asus ROG Dominus Extreme LGA3647
- Phanteks Glacier Dominus Extreme Kit CPU+VRMs
- Corsair Dominator RGB DDR4-4000 MHZ CL19 12 x 16 GB
- ASUS ROG Matrix Platinum GeForce RTX 5090 30th Anniversary Edition 32GB GDDR7
- 2x Philips 43 Zoll 4K + Samsung ARK 4K
- Samsung 970 Evo Plus 2TB + 980 Pro 1TB + 4x 990 Pro 4TB+ Seagate 530 4TB+ Intel Optane 905p 1,5TB
- HDD
- 3x Toshiba MG09 18 TB + 8x WD Raptor 1 TB
- Opt. Laufwerk
- ASUS Blu-Ray Laufwerk
- Soundkarte
- Creative AE-5 Plus + 2x Lightning Kit
- Thermaltake W200 Core + 6x Thermaltake P200 Core
- 2x Corsair AX1600i
- Keyboard
- Corair K100 Gold + Corsair Nexus + Corsair PBT white Caps
- Mouse
- Corsair + MM800 RGB Cloth
- Windows 10 Pro for Workstation 64Bit
- Webbrowser
- Firefox, Edge, Opera, Chrome, Brave, Vivaldi
- Sonstiges
- 2x Mo-Ra 420 Pro Steel Push/Pull Noctua a20 HP
- Internet
- ▼100 MBit ▲30 MBit
Winamp v5.23 Beta (Build 666)
http://download.nullsoft.com/winamp/beta/w...6_beta_full.exe
Whats new:
* Improved: [gen_jumpex] jump-to-file speed improvements
* Fixed: playlist saving with network share files
* Fixed: Media Library preferences not loading in correct order
* Fixed: main window not hilited when restoring from minimized state in classic skin.
* Fixed: slow loading of playlists with URLs
* Fixed: CD burning using third party input plugins
* Fixed: classic skin winshade playlist time display
* Fixed: [gen_ff] Wasabi XML font-related fixes from Martin Poehlmann
* Fixed: [gen_ff] Map.getHeight() maki script function returning width instead
* Fixed: [gen_ff] winshade global hotkeys broken w/ modern skins
* Fixed: [gen_jumpex] 'Add to Queue' issues
* Fixed: [gen_jumpex] NT4 incompatability
* Fixed: [gen_jumpex] misc bug fixes
* Fixed: [gen_ml] icon changes on drag+drop items
* Fixed: [in_mp3] playback of AAC streams
* Fixed: [in_mp4] seek bug when using right arrow key
* Fixed: [in_wm] Playback restarts from beginning when editing tags of a currently playing .wma file
* Fixed: [in_wm] protocol/extension reversed in config > filetype > edit
* Fixed: [in_wm] 'Audio only' always checked for ASF/WMV in config
* Fixed: [in_wm] seek bug when using right arrow key
* Fixed: [ml_bookmarks] 'Edit Bookmarks' menu item not working when Media Library is hidden
* Fixed: [ml_local] crash while rearranging media library views
* Fixed: [ml_local] crash on close
* Fixed: [ml_local] sort arrow reversed in some columns
* Fixed: [ml_playlists] Import Playlists uses containing dir for title instead of filename
* Fixed: [ml_playlists] No "Recurse" checkbox in Import Playlists From Folder
* Fixed: [ml_playlists] Add Dir adds all filetypes (not just all-supported)
* Fixed: [ml_playlists] rt-click enqueue not working & other issues
* Fixed: [ml_playlists] Not saving playlists in some situations
* Fixed: [ml_playlists] crash when loading badly formed WPL playlists
* Fixed: [ml_playlists] drag&drop into playlist not adding to correct position
* Fixed: [ml_playlists] root playlist screen not updating when adding new playlist
* Fixed: [ml_playlists] reverting changes on send-to: playlist
* Fixed: [ml_wire] some podcasts only display one item
* Fixed: [out_ds] stop with fade (shift+v) issue
* Fixed: [ml_pmp] Syncing duplicates finally fixed (thanks gordol)
* Fixed: [pmp_ipod] Playlist sort now works again
* Fixed: [ml_pmp] Removing items from a playlist not saving issue (thanks Nick)
* Updated: [in_cdda] CDDB 2.0.1.25
