welches ist das "beste" ios fürs iphone 6
Roger B
welche ios version ist denn die stabilste und beste für das iphone 6?
Die aktuellste = iOS 12. Du kannst es dir aber sowieso nicht aussuchen, ausser du hast noch eine alte Version drauf und machst kein Update.
For every iOS 12 compatible iPhone, it will be the best OS version so far. Apple has really worked a lot in iOS 12 in regard with the stability as well as security. I have tested iOS 12 beta versions and trust me it is the best iOS. I have tested iOS 10 also. There I was getting so many issues like iTunes error 0xe800002d, server issue, software downloading problem. So, I always recommended you to use Ios 12 for its advanced features
