Manuals
Processor Module
Dell™ Vostro™ 1700 and Inspiron™ 1720/1721 Service Manual
Removing the Processor Module
Replacing the Processor Module
CAUTION: Before you begin the following procedure, follow the safety instructions in the Product Information Guide.
Follow the instructions in Before You Begin.
Remove the optical drive (see Removing the Optical Drive).
Remove the hard drive (see Removing a Hard Drive).
Remove the hinge cover (see Removing the Hinge Cover).
Remove the keyboard (see Removing the Keyboard).
Remove the display assembly (see Removing the Display Assembly).
Remove the internal card with Bluetooth wireless technology, if installed (see Removing the Bluetooth Card).
Remove the palm rest (see Removing the Palm Rest).
Remove the processor thermal-cooling assembly (see Removing the Processor Thermal-Cooling Assembly).
NOTICE: To avoid damage to the processor, hold the screwdriver so that it is perpendicular to the processor when turning the cam screw.
To loosen the ZIF socket, use a small, flat-blade screwdriver and rotate the ZIF-socket cam screw counterclockwise until it comes to the cam stop.
