Suche Treiber für NV 8800GTS
Matthias1981
Semiprofi
Bei Ingolstadt
Hi. Möchte auf mein Vista gerne meine 8800GTS installieren. Gibts jetzt endlich Treiber? nehme auch Beta treiber^^
THX schonmal
Vlg Matthias
Nein es gibt leider immer noch nichts...
Mfg Oliver
Einerseits steht drinne, dass er die 8800 net unterstützt, aber unter supported Products steht se wieder drinne. :confused:
ForceWare 97.46 Windows Vista (x86)
Version: 97.46
Publisher: nvidia
Date added: 2006-12-17 00:53:19
File Size: 29 mb
OS Support: Windows Vista x86 RTM
License: FreeWare
Downloads: 9416 downloads
Software type: Videocards - NVIDIA ForceWare Vista
You are here: Guru3D.com » downloads » category selection » ForceWare 97.46 Windows Vista (x86)
Software Description
Windows Vista RTM x86
We have a new Vista driver for you guys. This is nVidia Forceware Vista Driver 97.46. Most GeForce 6 & 7 cards are supported as we have included a modified.inf file (courtesy laptopvideo2go)
In it's original form this 32-bit packages was released at a 51 MB file-size each. Guru3D has, with the help of some smart compression, have been able to down-size this file towards a nice 29 MB download.
Unfortunately GeForce 8800 is not yet supported though. Please regard this set as beta drivers. You use and install them at your own risk.
Supported products:
NVIDIA_BR02.DEV_00F1.1 = "NVIDIA GeForce 6600 GT "
NVIDIA_BR02.DEV_00F2.1 = "NVIDIA GeForce 6600 "
NVIDIA_BR02.DEV_00F3.1 = "NVIDIA GeForce 6200 "
NVIDIA_BR02.DEV_00F4.1 = "NVIDIA GeForce 6600 LE "
NVIDIA_BR02.DEV_00F5.1 = "NVIDIA GeForce 7800 GS "
NVIDIA_BR02.DEV_00F6.1 = "NVIDIA GeForce 6800 GS/XT"
NVIDIA_BR02.DEV_00F8.1 = "NVIDIA Quadro FX 3400/4400"
NVIDIA_BR02.DEV_00F9.1 = "NVIDIA GeForce 6800 Series GPU"
NVIDIA_BR02.DEV_00FA.1 = "NVIDIA GeForce PCX 5750"
NVIDIA_BR02.DEV_00FB.1 = "NVIDIA GeForce PCX 5900"
NVIDIA_BR02.DEV_00FC.1 = "NVIDIA GeForce PCX 5300"
NVIDIA_BR02.DEV_00FD.1 = "NVIDIA Quadro PCI-E Series"
NVIDIA_BR02.DEV_00FE.1 = "NVIDIA Quadro FX 1300"
NVIDIA_BR02.DEV_00FF.1 = "NVIDIA GeForce PCX 4300"
NVIDIA_BR02.DEV_02E0.1 = "NVIDIA GeForce 7600 GT "
NVIDIA_BR02.DEV_02E1.1 = "NVIDIA GeForce 7600 GS "
NVIDIA_BR02.DEV_02E2.1 = "NVIDIA GeForce 7300 GT "
NVIDIA_C51.DEV_0240.1 = "NVIDIA GeForce 6150"
NVIDIA_C51.DEV_0241.1 = "NVIDIA GeForce 6150 LE"
NVIDIA_C51.DEV_0242.1 = "NVIDIA GeForce 6100"
NVIDIA_C51.DEV_0243.1 = "NVIDIA C51 "
NVIDIA_C51.DEV_0245.1 = "NVIDIA Quadro NVS 210S / NVIDIA GeForce 6150LE"
NVIDIA_C51.DEV_0246.1 = "NVIDIA C51 "
NVIDIA_C51.DEV_0248.1 = "NVIDIA C51 "
NVIDIA_C51.DEV_0249.1 = "NVIDIA C51 "
NVIDIA_C51.DEV_024A.1 = "NVIDIA C51 "
NVIDIA_C51.DEV_024B.1 = "NVIDIA C51 "
NVIDIA_C51.DEV_024C.1 = "NVIDIA C51 "
NVIDIA_C51.DEV_024D.1 = "NVIDIA C51 "
NVIDIA_C51.DEV_024E.1 = "NVIDIA C51 "
NVIDIA_C51.DEV_024F.1 = "NVIDIA C51 "
NVIDIA_C61.DEV_03D0.1 = "NVIDIA GeForce 6100 nForce 430"
NVIDIA_C61.DEV_03D1.1 = "NVIDIA GeForce 6100 nForce 405"
NVIDIA_C61.DEV_03D2.1 = "NVIDIA GeForce 6100 nForce 400"
NVIDIA_C61.DEV_03D5.1 = "NVIDIA GeForce 6100 nForce 420"
NVIDIA_CR11.DEV_01A0.1 = "NVIDIA GeForce2 Integrated GPU"
NVIDIA_CR17.DEV_01F0.1 = "NVIDIA GeForce4 MX Integrated GPU"
NVIDIA_G70.DEV_0090.1 = "NVIDIA GeForce 7800 GTX"
NVIDIA_G70.DEV_0091.1 = "NVIDIA GeForce 7800 GTX "
NVIDIA_G70.DEV_0092.1 = "NVIDIA GeForce 7800 GT"
NVIDIA_G70.DEV_0093.1 = "NVIDIA GeForce 7800 GS"
NVIDIA_G70.DEV_0094.1 = "NVIDIA GeForce 7800SE/XT/LE/LT/ZT"
NVIDIA_G70.DEV_0095.1 = "NVIDIA GeForce 7800 SLI"
NVIDIA_G70.DEV_009D.1 = "NVIDIA Quadro FX 4500"
NVIDIA_G70.DEV_009E.1 = "NVIDIA G70GL"
NVIDIA_G71.DEV_0290.1 = "NVIDIA GeForce 7900 GTX"
NVIDIA_G71.DEV_0291.1 = "NVIDIA GeForce 7900 GT/GTO"
NVIDIA_G71.DEV_0292.1 = "NVIDIA GeForce 7900 GS"
NVIDIA_G71.DEV_0293.1 = "NVIDIA GeForce 7900/7950 GX2"
NVIDIA_G71.DEV_0294.1 = "NVIDIA GeForce 7950 GX2 "
NVIDIA_G71.DEV_0295.1 = "NVIDIA GeForce 7950 GT"
NVIDIA_G71.DEV_0296.1 = "NVIDIA G71"
NVIDIA_G71.DEV_029C.1 = "NVIDIA Quadro FX 5500"
NVIDIA_G71.DEV_029D.1 = "NVIDIA Quadro FX 3500"
NVIDIA_G71.DEV_029E.1 = "NVIDIA Quadro FX 1500"
NVIDIA_G71.DEV_029F.1 = "NVIDIA Quadro FX 4500 X2"
NVIDIA_G72.DEV_01D0.1 = "NVIDIA Quadro FX 350"
NVIDIA_G72.DEV_01D1.1 = "NVIDIA GeForce 7300 LE"
NVIDIA_G72.DEV_01D2.1 = "NVIDIA G72 "
NVIDIA_G72.DEV_01D3.1 = "NVIDIA GeForce 7300 SE"
NVIDIA_G72.DEV_01D5.1 = "NVIDIA G72 "
NVIDIA_G72.DEV_01DD.1 = "NVIDIA GeForce 7500 LE"
NVIDIA_G72.DEV_01DE.1 = "NVIDIA Quadro FX 350"
NVIDIA_G72.DEV_01DF.1 = "NVIDIA GeForce 7300 GS"
NVIDIA_G73.DEV_0390.1 = "NVIDIA GeForce 7650 GS "
NVIDIA_G73.DEV_0391.1 = "NVIDIA GeForce 7600 GT"
NVIDIA_G73.DEV_0392.1 = "NVIDIA GeForce 7600 GS"
NVIDIA_G73.DEV_0393.1 = "NVIDIA GeForce 7300 GT"
NVIDIA_G73.DEV_0394.1 = "NVIDIA GeForce 7600 LE"
NVIDIA_G73.DEV_0395.1 = "NVIDIA GeForce 7300 GT "
NVIDIA_G73.DEV_039E.1 = "NVIDIA Quadro FX 560"
NVIDIA_G80.DEV_0191.1 = "NVIDIA GeForce 8800 GTX"
NVIDIA_G80.DEV_0193.1 = "NVIDIA GeForce 8800 GTS"
NVIDIA_NV10.DEV_0100.1 = "NVIDIA GeForce 256"
NVIDIA_NV10.DEV_0101.1 = "NVIDIA GeForce DDR"
NVIDIA_NV10.DEV_0103.1 = "NVIDIA Quadro"
NVIDIA_NV11.DEV_0110.1 = "NVIDIA GeForce2 MX/MX 400"
NVIDIA_NV11.DEV_0111.1 = "NVIDIA GeForce2 MX 100/200"
NVIDIA_NV11.DEV_0113.1 = "NVIDIA Quadro2 Go / Quadro2 MXR/EX"
NVIDIA_NV15.DEV_0150.1 = "NVIDIA GeForce2 GTS/GeForce2 Pro"
NVIDIA_NV15.DEV_0151.1 = "NVIDIA GeForce2 Ti"
NVIDIA_NV15.DEV_0152.1 = "NVIDIA GeForce2 Ultra"
NVIDIA_NV15.DEV_0153.1 = "NVIDIA Quadro2 Pro"
NVIDIA_NV17.DEV_0170.1 = "NVIDIA GeForce4 MX 460"
NVIDIA_NV17.DEV_0171.1 = "NVIDIA GeForce4 MX 440"
NVIDIA_NV17.DEV_0172.1 = "NVIDIA GeForce4 MX 420"
NVIDIA_NV17.DEV_0173.1 = "NVIDIA GeForce4 MX 440-SE"
NVIDIA_NV17.DEV_0178.1 = "NVIDIA Quadro4 550 XGL"
NVIDIA_NV17.DEV_017A.1 = "NVIDIA Quadro NVS"
NVIDIA_NV18.DEV_0181.1 = "NVIDIA GeForce4 MX 440 with AGP8X"
NVIDIA_NV18.DEV_0182.1 = "NVIDIA GeForce4 MX 440SE with AGP8X"
NVIDIA_NV18.DEV_0183.1 = "NVIDIA GeForce4 MX 420 with AGP8X"
NVIDIA_NV18.DEV_0185.1 = "NVIDIA GeForce4 MX 4000"
NVIDIA_NV18.DEV_0188.1 = "NVIDIA Quadro4 580 XGL"
NVIDIA_NV18.DEV_0189.1 = "NVIDIA GeForce4 MX with AGP8X (MAC)"
NVIDIA_NV18.DEV_018A.1 = "NVIDIA Quadro NVS 280 SD"
NVIDIA_NV18.DEV_018B.1 = "NVIDIA Quadro4 380 XGL"
NVIDIA_NV18.DEV_018C.1 = "NVIDIA Quadro NVS 50 PCI"
NVIDIA_NV20.DEV_0200.1 = "NVIDIA GeForce3"
NVIDIA_NV20.DEV_0201.1 = "NVIDIA GeForce3 Ti 200"
NVIDIA_NV20.DEV_0202.1 = "NVIDIA GeForce3 Ti 500"
NVIDIA_NV20.DEV_0203.1 = "NVIDIA Quadro DCC"
NVIDIA_NV20.DEV_02A0.1 = "NVIDIA NV2A GeForce 3 Integrated (XBOX)"
NVIDIA_NV25.DEV_0250.1 = "NVIDIA GeForce4 Ti 4600"
NVIDIA_NV25.DEV_0251.1 = "NVIDIA GeForce4 Ti 4400"
NVIDIA_NV25.DEV_0252.1 = "NVIDIA GeForce4 Ti"
NVIDIA_NV25.DEV_0253.1 = "NVIDIA GeForce4 Ti 4200"
NVIDIA_NV25.DEV_0258.1 = "NVIDIA Quadro4 900 XGL"
NVIDIA_NV25.DEV_0259.1 = "NVIDIA Quadro4 750 XGL"
NVIDIA_NV25.DEV_025B.1 = "NVIDIA Quadro4 700 XGL"
NVIDIA_NV28.DEV_0280.1 = "NVIDIA GeForce4 Ti 4800"
NVIDIA_NV28.DEV_0281.1 = "NVIDIA GeForce4 Ti 4200 with AGP8X"
NVIDIA_NV28.DEV_0282.1 = "NVIDIA GeForce4 Ti 4800 SE"
NVIDIA_NV28.DEV_0288.1 = "NVIDIA Quadro4 980 XGL"
NVIDIA_NV28.DEV_0289.1 = "NVIDIA Quadro4 780 XGL"
NVIDIA_NV30.DEV_0300.1 = "NVIDIA NV30"
NVIDIA_NV30.DEV_0301.1 = "NVIDIA GeForce FX 5800 Ultra"
NVIDIA_NV30.DEV_0302.1 = "NVIDIA GeForce FX 5800"
NVIDIA_NV30.DEV_0308.1 = "NVIDIA Quadro FX 2000"
NVIDIA_NV30.DEV_0309.1 = "NVIDIA Quadro FX 1000"
NVIDIA_NV30.DEV_030A.1 = "NVIDIA ICE FX 2000"
NVIDIA_NV31.DEV_0311.1 = "NVIDIA GeForce FX 5600 Ultra"
NVIDIA_NV31.DEV_0312.1 = "NVIDIA GeForce FX 5600"
NVIDIA_NV31.DEV_0313.1 = "NVIDIA NV31"
NVIDIA_NV31.DEV_0314.1 = "NVIDIA GeForce FX 5600XT"
NVIDIA_NV31.DEV_0318.1 = "NVIDIA NV31GL"
NVIDIA_NV31.DEV_0319.1 = "NVIDIA NV31GL"
NVIDIA_NV34.DEV_0320.1 = "NVIDIA GeForce FX 5200"
NVIDIA_NV34.DEV_0321.1 = "NVIDIA GeForce FX 5200 Ultra"
NVIDIA_NV34.DEV_0322.1 = "NVIDIA GeForce FX 5200 "
NVIDIA_NV34.DEV_0323.1 = "NVIDIA GeForce FX 5200LE "
NVIDIA_NV34.DEV_0323.1 = "NVIDIA GeForce FX 5200LE"
NVIDIA_NV34.DEV_0326.1 = "NVIDIA GeForce FX 5500"
NVIDIA_NV34.DEV_0327.1 = "NVIDIA GeForce FX 5100"
NVIDIA_NV34.DEV_0329.1 = "NVIDIA GeForce FX 5200 (MAC)"
NVIDIA_NV34.DEV_032A.1 = "NVIDIA Quadro NVS 55/280 PCI"
NVIDIA_NV34.DEV_032B.1 = "NVIDIA Quadro FX 500/FX 600"
NVIDIA_NV34.DEV_032F.1 = "NVIDIA NV34GL"
NVIDIA_NV35.DEV_0330.1 = "NVIDIA GeForce FX 5900 Ultra"
NVIDIA_NV35.DEV_0331.1 = "NVIDIA GeForce FX 5900"
NVIDIA_NV35.DEV_0332.1 = "NVIDIA GeForce FX 5900XT"
NVIDIA_NV35.DEV_0333.1 = "NVIDIA GeForce FX 5950 Ultra"
NVIDIA_NV35.DEV_0334.1 = "NVIDIA GeForce FX 5900ZT"
NVIDIA_NV35.DEV_0338.1 = "NVIDIA Quadro FX 3000"
NVIDIA_NV35.DEV_033F.1 = "NVIDIA Quadro FX 700"
NVIDIA_NV36.DEV_0341.1 = "NVIDIA GeForce FX 5700 Ultra"
NVIDIA_NV36.DEV_0342.1 = "NVIDIA GeForce FX 5700"
NVIDIA_NV36.DEV_0343.1 = "NVIDIA GeForce FX 5700LE"
NVIDIA_NV36.DEV_0344.1 = "NVIDIA GeForce FX 5700VE"
NVIDIA_NV36.DEV_0345.1 = "NVIDIA NV36"
NVIDIA_NV36.DEV_034E.1 = "NVIDIA Quadro FX 1100"
NVIDIA_NV36.DEV_034F.1 = "NVIDIA NV36GL"
NVIDIA_NV40.DEV_0040.1 = "NVIDIA GeForce 6800 Ultra"
NVIDIA_NV40.DEV_0041.1 = "NVIDIA GeForce 6800"
NVIDIA_NV40.DEV_0042.1 = "NVIDIA GeForce 6800 LE"
NVIDIA_NV40.DEV_0043.1 = "NVIDIA GeForce 6800 XE"
NVIDIA_NV40.DEV_0044.1 = "NVIDIA GeForce 6800 XT"
NVIDIA_NV40.DEV_0045.1 = "NVIDIA GeForce 6800 GT"
NVIDIA_NV40.DEV_0047.1 = "NVIDIA GeForce 6800 GS"
NVIDIA_NV40.DEV_0048.1 = "NVIDIA GeForce 6800 XT "
NVIDIA_NV40.DEV_0049.1 = "NVIDIA NV40GL"
NVIDIA_NV40.DEV_004E.1 = "NVIDIA Quadro FX 4000"
NVIDIA_NV41.DEV_00C0.1 = "NVIDIA GeForce 6800 GS "
NVIDIA_NV41.DEV_00C1.1 = "NVIDIA GeForce 6800 "
NVIDIA_NV41.DEV_00C2.1 = "NVIDIA GeForce 6800 LE "
NVIDIA_NV41.DEV_00C3.1 = "NVIDIA GeForce 6800 XT "
NVIDIA_NV41.DEV_00CD.1 = "NVIDIA Quadro FX 3450/4000 SDI"
NVIDIA_NV41.DEV_00CE.1 = "NVIDIA Quadro FX 1400"
NVIDIA_NV43.DEV_0140.1 = "NVIDIA GeForce 6600 GT"
NVIDIA_NV43.DEV_0141.1 = "NVIDIA GeForce 6600"
NVIDIA_NV43.DEV_0142.1 = "NVIDIA GeForce 6600 LE"
NVIDIA_NV43.DEV_0143.1 = "NVIDIA GeForce 6600 VE"
NVIDIA_NV43.DEV_0145.1 = "NVIDIA GeForce 6610 XL"
NVIDIA_NV43.DEV_0147.1 = "NVIDIA GeForce 6700 XL"
NVIDIA_NV43.DEV_014A.1 = "NVIDIA Quadro NVS 440"
NVIDIA_NV43.DEV_014B.1 = "NVIDIA NV43"
NVIDIA_NV43.DEV_014C.1 = "NVIDIA Quadro FX 550"
NVIDIA_NV43.DEV_014D.1 = "NVIDIA Quadro FX 550 "
NVIDIA_NV43.DEV_014E.1 = "NVIDIA Quadro FX 540"
NVIDIA_NV43.DEV_014F.1 = "NVIDIA GeForce 6200"
NVIDIA_NV44.DEV_0160.1 = "NVIDIA GeForce 6500"
NVIDIA_NV44.DEV_0161.1 = "NVIDIA GeForce 6200 TurboCache(TM)"
NVIDIA_NV44.DEV_0162.1 = "NVIDIA GeForce 6200SE TurboCache(TM)"
NVIDIA_NV44.DEV_0163.1 = "NVIDIA GeForce 6200 LE"
NVIDIA_NV44.DEV_0165.1 = "NVIDIA Quadro NVS 285"
NVIDIA_NV44.DEV_0169.1 = "NVIDIA GeForce 6250"
NVIDIA_NV44.DEV_016A.1 = "NVIDIA GeForce 7100 GS"
NVIDIA_NV44.DEV_016E.1 = "NVIDIA NV44GL"
NVIDIA_NV44.DEV_0220.1 = "NVIDIA NV44 "
NVIDIA_NV44.DEV_0221.1 = "NVIDIA GeForce 6200 "
NVIDIA_NV44.DEV_0222.1 = "NVIDIA GeForce 6200 A-LE"
NVIDIA_NV45.DEV_0046.1 = "NVIDIA GeForce 6800 GT "
NVIDIA_NV48.DEV_0210.1 = "NVIDIA NV48"
NVIDIA_NV48.DEV_0211.1 = "NVIDIA GeForce 6800 "
NVIDIA_NV48.DEV_0212.1 = "NVIDIA GeForce 6800 LE "
NVIDIA_NV48.DEV_0215.1 = "NVIDIA GeForce 6800 GT "
NVIDIA_NV48.DEV_0218.1 = "NVIDIA GeForce 6800 XT "
Diese Liste also NVIDIA_BR02.DEV_00F1.1 u.s.w ist nur dafür da das sich der Treiber nicht beschwert das die Graka. nicht vorhanden ist.
Guru3D bastelt sich da immer selber was zusammen und niemt wohl die .ini der XP Treiber wo ja die 8800er drin steht!
Aber offizell weder BETA noch sonst was gibt es keine für Vista und der 8800er Serie.
MFG
Aber des is ja ne frechheit. Vista gibts ja schon aus den USA zu bestellen und die von der Uni hams au schon.
Also was soll der Mist??
Frag mich nicht selbst die Vista Treiber für die anderen Geforce Karten sind eher Bugy!
Bei mir gibt es öfters mal eine Lightshow wenn ich bestimmte Grafikeinstellungen in Spielen oder Desktop einstelle :stupid:
Dessweiteren gibt es keine SATA RAID Treiber für den nForce4 Chipsatz eigentlich ging ich ja davon aus das die Zeiten von Diskette machen und reinstecken vorbei wären und nVidia alles in die Final reinpackt würden hatten ja eigentlich genug Zeit...
nVidia scheint entweder alles sehr locker zu sehen oder hat doch größere Probleme als wir ahnen können..
MFG
Also ich habe zZ einen Vista Test PC mit einer alten Geforce 3 Ti 500 am laufen. Dafür gibts dann wohl auch keine Treiber oder?
Hat jemand ne Ahnung wie ich meinen Moni auf mehr als 75hz stellen kann. es gehen nur 60 im mom und das flimmert wie sau.
Hat jemand ne Mailadresse wo ich Nvidia mal wegen den Treibern schreiben könnte??
Vlg Matthias
du könntest versuchen einen Monitor treiber so anzupassen dass er NUR 75hz und mehr unterstützt dann müsste vista gezwungenermaßen auf 75hz gehen
das hab ich bei windoof2000 gemacht um dem 60hz bug aus dem weg zu gehen.
ui und wie stelle ich das an? Und wie vor allem zocke ich dann NFS Carbon? Also brauche ich wohl weiterhin XP^^
Und wie soll ich nu nen treiber modifizieren.
