ROG CROSSHAIR VI HERO AMD X370 ATX - W_FLOW Sensoreingang / Kompatibilität ?
Speeddeamon
Urgestein
Metropolregion Hamburg
ich versuche grade herauszufinden welche Durchflussmesser ich direkt an diesem besagten Anschluss des Mainboards betreiben könnte.
Es scheint nirgendwo verlässliche Informationen dazu zu geben welche Geräte geeignet sind.
Besteht die Möglichkeit hier etwas Licht ins dunkel zu bringen?
Vielen Dank Vorab
Beste Grüße
Markus
Hoi,
ich habe im Moment leider nur diese Infos:
1. Does we have a minimum impulsrate by the W_FLOW connector ? 3 L/MIN
2. How can the flow volume pro impulse calibrate?
There is no way to calibrate, because the size of each manufacturing tachometer is different and the diameter, PUMP output that customer used are different, currently we estimate the value by converting the rotating speed into the flow rate
3. How are the connectors W_IN and W_OUT right to use?
Since W_IN ,OUT are both 2-pin thermistor without positive and negative, it will be detected when inserted.
4. Does the W_IN port refer to the input of the processor or of the input from the cooling circuit (radiator)?
Customer can set Fan temp manually in FAN XPERT4. SOURCE set as W_IN or OUT, and it need manually set by user .Since the default value is the main source of CPU & GPU.
Since the head of water flow was designed as right into the left, if customer's water flow direction is left into the right, then there will be no way to promote the water flow, please help to explain it to customer.
Besides, the minimum detection rate of flow_rate meter is 200rpm (that is, 3L/1 min), if USER's water route is too long, or too far from the WATER PUMP, or pump output is not connected to the monoblock in port , then the water pressure May not push the flow rate meter.
