Release Notes for iCUE 5.12.97
CORSAIR Marcus
Corsair Support
Hallo zusammen!
Hier könnt ihr die aktuellen Release Notes von iCUE einsehen, inkl. einem Link zum download.
iCUE 5.12.97 Issues Resolved
Software Enhancements
  • Resolved an issue that caused iCUE to unexpectedly quit when importing a profile on a system with a NVIDIA Founder’s Card GPU installed
  • Battery Status sensor widgets on the Dashboard will now properly show a graph in the background
  • Certain widgets will no longer be missing their context menus when added to the Dashboard
  • Lighting Effects will no longer be duplicated when dragging and dropping layers in the list
  • Resolved various issues with naming in Murals
  • HARPOON PRO will now properly show up as a device in Murals
HID Product Enhancements
  • Resolved an issue that causes KATAR PRO WIRELESS to stop responding if the polling rate is changed to 2000 Hz
  • Resolved an issue that prevented Imitate Holding Key from working properly with Hardware Key Assignments
  • Resolved various issues that may cause iCUE to unexpectedly quit when changing polling rates across various devices
  • Resolved various issues that caused keypress combinations from working properly with Japanese layouts on certain keyboards
  • The Brightness Control icon will no longer be missing for the K100 Control Wheel
  • Resolved an issue that caused K70 CORE RGB to show up as a CRP_DISABLED device after a firmware update
  • Resolved the following issues with iCUE NEXUS:
    • Background image will now display properly when using the 640x48 px window size
    • Image rescaling logic was improved
    • Profile switching issues were fixed so that all profiles will properly appear on the rotation list
    • Changing Lighting Link will no longer cause the name of the effect to disappear
    • Renaming an EQ preset will properly update the device screen
DIY Product Enhancements
  • GIPHY support has been added to all LCD devices – users can now browse, download, and add animated GIFs to their devices. To find this feature select 'Images/GIF' then click the 'GIPHY' tab:
  • Resolved an issue that caused a delay in DDR5 detection when creating a new user profile
  • Resolved an issue with VOYAGER Gaming Laptops battery widgets not updating their status properly after the charger is removed – the widget for this sensor can also now be properly added to the Home Screen
  • The brightness between the keyboard and the touch bar for VOYAGER Gaming Laptops will now be properly adjusted together when using the hotkey
  • An additional prompt has been added to the Performance Manager tab for DDR5
  • Resolved various issues with the customization of Alerts
  • Resolved a display issue when using custom fan curve names when a QX fan is connected
Ist es möglich Asus Armory Crate und Icue zusammen zu betreiben?
Ich habe es seit Monaten so laufen... allerdings habe ich aktuell ein Problem mit der RGB-Beleuchtung der Corsair Lüfter, aber keine Ahnung, ob das nun an der Asus Software liegt oder nicht. Ich bin der Sache bis jetzt auch noch nicht genauer auf den Grund gegangen.
Mein Problem aktuell ist, sobald Windows geladen ist und ich einige Sekunden im Loginbildschirm warte, dann geht die RGB-Beleuchtung der Lüfter irgendwas aus und es bleibt dunkel. Solange ich aber im EFI hänge, leuchten die Lüfter, drehen sich aber nicht. Wenn Windows einige Sekunden da ist, dreht sich das Verhalten um. Sie fangen an sich zu drehen aber die Beleuchtung geht aus.
Wenn ich in der iCUE Software am Helligkeitsregler herumspiele, ist die Beleuchtung so lange da, wie ich den Regler hin und her schiebe. Sobald ich damit aufhöre, geht es wieder komplett aus. Das sind aktuell viele Fragezeichen über meinem Kopf...
Da das Verhalten im EFI aber schon seltsam ist, denke ich nicht, dass es wirklich ein Softwareproblem ist :unsure:
Was war eigentlich damals das Ziel als ihr eure alte Software durch iCue ersetzt habt?
Neu, aber so schlecht wie nur irgendwie möglich?
Seitdem es iCue gibt hab ich immer wieder Probleme mit meiner K95 RGB.
Jetzt will iCue die Firmware auf 3.08 updaten, diese ist aber seit Jahren auf der Tastatur installiert.
Und iCue bekommt das Update auch nicht hin.
Kurz: Euer Dreck hat mir die Tastatur zerschossen.
