DiePike
Legende
- Ort
- Hamburg :]
- Laptop
- Lenovo Legion 14"
- Details zu meinem Laptop
- AMD Ryzen 7 7840HS
- 32GB
- Nvidia GTX 4060
- 14" 4k Display
- 1TB SSD
- Windows 10 Pro
gestern Abend ist mein Vista-PC abgeschmiert , vorher gab er noch einen netten Bluescreen mit dieser Meldung aus : "REFERENCE_BY_POINTER".
MiniDump Inhalt:
Verbaut sind 2 x 512MB Ram , Memtest86+ hat nach 100% (passed) keine Errors gefunden.
MiniDump Inhalt:
Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [D:\Mini013110-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image \SystemRoot\system32\ntkrnlpa.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntkrnlpa.exe
*** ERROR: Module load completed but symbols could not be loaded for ntkrnlpa.exe
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Machine Name:
Kernel base = 0x81c18000 PsLoadedModuleList = 0x81d2fc70
Debug session time: Sun Jan 31 02:47:53.706 2010 (GMT+1)
System Uptime: 0 days 1:24:22.862
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 18, {8333ca40, 8f88d038, 2, fffffffc}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** work. ***
Probably caused by : ntkrnlpa.exe ( nt+44d91 )
Followup: MachineOwner
