RAM G.Skill Aegis F4-3200C16S-8GIS 8gb(1x8GB) DDR4 3200MHz CL16 B-die
Tatilica
Experte
Romania
Hello everyone, I've got RAM kit for my Ryzen built today, notice that GSkill surprise me with 2 module 8gb Samsung B-die, very cheap ones, that cost me 36 € each one I've bought from 2 different local providers!
Love this achievement so I recomand this Aegis 3200 whom they are concern about buying expensive ones, good luck!
Hi @Tatilica and welcome to Hardwareluxx :wink:
Sadly that is a very common false positive by Thaiphoon Burner. The lot code on the module in your photo confirms them to be Samsung 8Gbit C-Die instead. The FAQ of he B-Die list also covers this and exlains how to identify Samunsg 8Gbit B-Die vs C-Die on Corsair and GSK models.
For C-Die information check: https://www.hardwareluxx.de/communi...c-ergebnisse-im-startbeitrag-updated.1198323/
Tks then I apreciate this, still pleasant and smooth experience with this Aegis kit, still recomended GSkill for short budget here in Eastern Europe, better invest in other system components of my built:
Hello again community, I received early days my second 8gb stick Aegis F4-3200C16S-8GIS, same specs B-die checked by Thaiphoon see picture
Lucky me to overclock both stick Dual 16gb very nice to 3466MHz CL-16 1.45v no issue at all, surprisely checked in Bios Primary Timings found this:
Primary Timings: 312 tRFC in my Bios, according to Reus Table check below :
IC​
tRFC (ns)​
8Gb AFR​
260 - 280​
8Gb CJR​
260 - 280​
8Gb Rev. E​
290 - 310​
8Gb B-die​
160 - 180​
meens no Thaiphoon error: B-die for Aegis
Thx for Reus and his masterpiece work!
Sadly the 312 value is a known issue if it is set to Auto the first time. Please check the tRFC with ZenTimings. This this show the real value.
Hy, I checked with Zen Timings and Ryzen Master: 606 tRFC value, lights me up, thx!
There's any way to check tRFC(ns) value in Zen?
I hope tRFC(ns) will be added in the next version of ZenTimings
Thx Reous, don't look anymore tRFC(ns) stay chill with my actual setup, nice bench scores, wish you best luck!
Any reason why your Infinity Fabric is not in sync?
Tried to sync, system stable after restart, not stable and boot after shut down!
Hi Reous, let you know that I found my sistem stable setup for sync infinity fabric: after clear CMOS and back to default Bios, increase just to 100 BLCK, a bit also VDDP and VDDR, PBO enabled, that's the secret do run any issue! Also change to 555 tRFC(ns) value from your TABLE voila, thx!
Better CPUZ single and multi thread, but lower in Cinebench, as I just used for gaming, I can live with that hooray!
