[Projekt] Project: G5 conversion, Art is a philosophy, Update (26/11/08)
ultimeus
Hi all I know this a deutch forum but since I look a lot of project here I post mine.
I begin my first worklog, it's a apple G5 conversion, I try to keep the apple look outside and inside but with my own choices.
Hardware :
Q6600
DFI P35 UT
4GB crucial ballistix tracer 5300
Twintech 8800GTS 512 (to change with black pcb card)
Samsung T166 500gb raid
Corsair HX 520w
Sony dvd burner
Liquid cooling if budget can be complete
Ek supreme
Laing ddc 3.2 with Ek acetal top
Ek northbridge cooler
EK nickel block (depend from graphic card)
Dual microcool 240 rad (stacked rads)
10/16 compressions fittings
10/16 white tubing
Mod parts:
Apple G5
Lian li A10 motherboard tray
Lian li rack drive
TJ-07 watercooling rad supports
Full white sleeving
Nanoxia Fans
Some objectives of the project:
Try to keep the mac look with mods, painting of all parts to mac grey,
Reuse powersupply plastic surround port in lian li motherboard tray
Cover rads, bottom case with custom aluminium plate.
Color scheme : white, grey, green.
Repaint case to original grey.
Sponsor : EK waterblocks
Modding parts
Case ready for some action
First placement of motherboard tray
Cut for opening door mechanism
Motherboard tray inside
Second cutting session and more adjustment
Cutting back plate for door opening and lapping
Adaptation of powersupply plastic surround port , final form of hole would be made with mastic
Holes will be filled with mastic too
I'll try some sketchup for final look
Would you be so kind to resize the pics a little bit? Otherwise scrolling down is nearly impossible :d
I am very ecited to see how it would be finished in the future (and now nobody sais something against my low level school english :d)
Thanks all for welcome, I have to say that a lot of projects here inspired me, and nils project of course ^^
Next update I would rezise picture.
Ultimeus: You have to raise the bar that the "bit-tech-G5" set. Externally it was fantastic , but on his internals there was never really anything shown except the one shot through the window. Just top it :d
I'll try my best to beat Bit tech G5's, I contact Eddy from EK watercooling, he accept to sponsor me, I'm really happy.
Tomorrow big update, I play all the afternoon with mastic, some parts are modded and painted with filler.
Nils, I'll send length for sleeving tomorrow.
Do you mean Mr. Beans Bad Apple, or the Apple Core Duo by Cyprio?
There are a few more MAC-related Mods on bit-tech, not sure which you are refering to.
Ultimeus: Nice start, dude. I already saw your Log on bit-tech, so keep up the good work. :bigok:
Edit: There are 4 G5 Worklogs on the first page of the worklog-forum... ;)
Great work so far.
You have a different approach than Cyprio in his Mod, who kept the original mainboard tray of the mac, if I remember correctly.
Personally I adore the mac's interior, since it is very tidy and very well thought throughout the case.
Looking forward to your result.
Do your very best!
I think he was talking about these mods, I agree with nils opinion outside they are great, Mr bean bad apple is great inside too, but for me there is no a classy touch I like.
Great work so far.
Do your very best!
Thank you I'll try my best.
Very nice ! ABO.
But plz make the pictures smaller. The maximum size is 900x900 Pixel @400kb. TY !
:wink:
Why the Ek Supreme? Good cooling power, but a big chance für failures, bevaus ist works like a particle filter.
I choose Ek supreme for look and performance.
Hard drive rack prepared for some modding (3 to 2 hard drives)
Integration of apple psu hole
backside
superior side, there was an hole in the upper side, I cut a little plate from aluminium and filled with bondo.
Rack drive modded and prepared with filler.
Back motherboard tray finished
Painted
I'm not very happy with paint, it doesn't look professional, kind of plastic texture and don't match apple grey.
Since I had planed to repaint the case ( to much little dents, and color dismatch because smoking) soon, I've ask a friend who work in a paint garage to resparay all the parts.
Definitely looks very nice :)
An apple G5 or the newer MacPro Cases are very yummy :)
Very curious how this will continue :)
Abo
Looks great till now. WHITE :love:
hi all i know this a deutch forum but since i look a lot of project here i post mine.
I begin my first worklog, it's a apple g5 conversion, i try to keep the apple look outside and inside but with my own choices.
liquid cooling if budget can be complete
ek supreme the heatkiller 3.0 is a better block
laing ddc 3.2 with ek acetal top
ek northbridge cooler i prefer watercool blocks, cause they are modular and i can use it on the next board. Just through changin the bottomplate.
ek nickel block (depend from graphic card) same on the gpu...
dual microcool 240 rad (stacked rads) stacked rads or not as effective as not stacked ones
10/16 white tubing
Ich denke dass er kaum Watercool MB Kühler benutzen wird aufgrund der Optik ;)
Und soo schlimm wenn man nicht das größte Dreckferkel ist ist der EK Supreme auch nicht
Very nice Projet!
Hope you´ll continue it soon as possible :drool:
I´m gonna watch this projekt :d
Greets Thermal
Hi guys, here is an update :up:
Sleeving pron (first part)
Re soldered front G5 cable
Scythe himuro
