pissdrunx1987
Bin beim surfen auf dieses meiner meinung nach sehr interessantes gerät gestossen. man darf bei dieser kombination wohl auf erste tests gespannt sein. gerade der schmale rahmen, vesa 100 kompatibilität mit einem pva panel gefallen
NEC MultiSync EX231Wp silber/weiß, 23" (60003149) | Geizhals.at Deutschland
NEC MultiSync EX231Wp schwarz, 23" (60003150) | Geizhals.at Deutschland
EX231Wp-BK, 23 Widescreen Ultra Slim Desktop Monitor - Highlights & Specifications | NEC Display Solutions
Product Specifications
Display
Panel Technology PVA
Viewable Image Size 23
Aspect Ratio 16:9
Native Resolution 1920 x 1080
Pixel Pitch 0.27
Pixels Per Inch 96
Backlight Type W-LED
Brightness (typical) 250
Contrast Ratio (typical) 3000:1
Viewing Angle (typical) 178° Vert., 178° Hor. (89U/89D/89L/89R) @ CR>5
ResponseTime (typical) 25
Displayable Colors More than 16.7 million
Synchronization Range
Horizontal (Analog/Digital) 31.5-83 kHz
Vertical 56-75 Hz
Input Signal
Video Analog RGB 0.7 Vp-p/75 Ohms
Sync Separate Sync: TTL Level (Positive/Negative)
Composite Sync: TTL Level (Positive/Negative)
Composite Sync on Green: (0.3Vp-p negative 0.7Vp-p positive)
Input Connectors
DisplayPort, DVI-I
Power Consumption (typical)
On 27
Power Savings Mode 0.37
Physical Specifications
Dimensions (WxHxD)
Net (with stand) 21.3 x 15.8-20.1 x 8.5 in. / 540.2 x 401.3-511.3 x 215mm
Net (without stand) 21.3 x 12.5 x 1.9 in. / 540.2 x 318.3 x 47.7mm
Weight
Net Weight (with stand) 9.3 lbs. / 4.2 kg
Net Weight (without stand) 6.2 lbs. / 2.8 kg
VESA Hole Configuration Specifications
100 x 100mm
Environmental Conditions
Operating Temperature 41-95°F / 5-35°C
Operating Humidity 20-80%
Operating Altitude 6562 ft. / 2000m
Storage Temperature 14-140°F / -10-60°C
Storage Humidity 10-85%
Storage Altitude 40,000 ft. / 12,192m
Environmental Compliance
ENERGY STAR 5.0
TCO 5.2
EPEAT Gold
RoHS Yes
Limited Warranty (parts & labor, including backlight)
3 years
Additional Features
Ultra-thin frame
PVA panel
LED backlit
Touch-sensitive OSD user controls
Auto brightness with ambient light sensor
Human sensor
USB pass-through
ECO Mode
Carbon footprint meter
Resettable cost meter
Integral power meter
Off timer
Tilt
Swivel
Pivot
Height-adjustable stand
Quick release stand
Carrying handle
Rapid Response
Ambix
XtraView
NaViSet software
Cable management
VESA mount
HDMI-capable via DVI adapter
HDCP
DDC/CI
No Touch Auto Adjust
Plug and Play (VESA DDC 2B)
VESA DPMS power management
Dynamic Video Mode
6-preset color control system
Digital smoothing
Digital controls
Ships With
Setup sheet
User manual
Power cord
DVI cable
USB cable
15-pin D-sub to DVI-A
AC adapter
DC cable for AC adapter
