multiprocessor configuration not supported
toedai
Hallo
Wollte win 7 auf windows 10 updaten. 32 bit system und nach dem windows 10 fast fertig war gab es einen bluescreen mit der Meldung multiprocessor configuration not supported
Es ist ein Intel quad core
Muss ich im Bios irgend was umstellen?
Danke
Toedai
Ein Microsoft Support Engineer schrieb dazu folgendes [1]:
This issue may occur due to System file is corrupt or BIOS driver is out dated. Try the below steps and check.
Method 1.
Based on your description (Your PC ran into problem and need to restart. We will restart it for you) it usually occur due to the system file is corrupt. I would suggest you to download and create the ISO for Windows 10 and then repair your computer to check if it helps to recover the Operating System.
Download official ISO media for Windows 10 from Microsoft:
http://www.microsoft.com/en-us/software-download/windows10
Insert the disk in your DVD drive and press any key to start loading Windows from the Installation Disk. Perform the following steps to perform a repair:
  1. Choose the Language and then proceed to Next.
  2. Choose Repair your computer at the Install Now screen.
  3. Click on Advanced Options.
  4. Click on Troubleshoot.
  5. Click on Startup repair
And also try the method 2 if the issue still persist.
Method 2.
For the issue (Multi-processor configuration not supported error), I would suggest you to update the chipset and BIOS drivers from the computer manufacturer’s website.
Note: Modifying BIOS/ complementary metal oxide semiconductor (CMOS) settings incorrectly can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting from the configuring of BIOS/CMOS settings can be solved. Modifications of the settings are at your own risk.
Also visit the below link for The Windows 10 upgrade appears to hang:
http://answers.microsoft.com/en-us/windows/forum/windows_10-windows_install/the-windows-10-upgrade-appears-to-hang/a3359013-80a7-4a25-a75d-1c828e576c40?tm=1438143969182
Ändere im BIOS doch mal folgende Einstellungen:
  • Max CPUID Value Limit (sollte disabled sein)
  • Hyperthreading
  • Multiple CPU Cores
[1] http://answers.microsoft.com/en-us/windows/forum/windows_10-update/windows-10-upgrade-from-windows-81-hangs/89ee35d9-959b-4b1f-af3b-8b1f9e5bbeb2
