hallo , leider im M8 Handbuch steht nichts viel, bis welche Leistungsaufnahme ist diese Anschluss geeignet ,
google spricht so um 18 W als Max , jedoch rein-theoretisch 18W ist relativ viel ???
für detaillierte Antwort werde mich sehr freuen
Also present on the PCB is a water-cooling pump header - the same deal that we saw with the Deluxe. This essentially sends a constant 12V to the pump, so you can be sure the board's fan control isn't interfering with your cooling. Being a ROG board, this is a good addition, but we'd like to see Asus go one step further and support standard 18W Molex pumps in the ROG series, especially on the Formula/Extreme models. It's pretty popular to run a pump at 7V to cut noise as well so the ability to fine-tune the pump voltage and tie everything into the motherboard's fan control would be a fantastic feature to have.
