Everest2000
Semiprofi
Servus, es geht genau gesagt um das Arbeiten am bzw. mit dem KVM-Gerätvon IBM:
"The BladeCenter has a Keyboard/Video/Monitor (KVM) switch built in to MM’s and AMM’s. To switch the keyboard, mouse, and monitor between blade servers, press the following key stroke combination
NumLk, NumLk, <blade server number>, Enter from the keyboard attached to the AMM:
Where <blade server number> is the number of the blade server bay where the blade server is installed.
For example, to select the blade server in bay 2, press the NumLk key twice, press the number 2,
and then press the Enter key.
There is currently no time out period programmed. Once the process is started by pressing the NumLk key twice, the AMM waits for a blade bay number to be selected followed by the Enter key before the keyboard is returned to normal function.
If the user does not know about this KVM feature, it will appear that the keyboard is locked after just hitting the NumLk key twice.
Once the NumLk key has been pressed twice, the MM will wait for the Enter key to be pressed to terminate this sequence. If a keyboard/mouse/video select button on one of the other blades in the chassis is pressed, the video display and mouse will be switched to that blade. However, the keyboard will remain in this “locked state” until the Enter key is pressed. Unplugging the keyboard from the MM and reinserting it into either the MM or the USB connector, on the media tray, also have no effect. The MM is waiting for the Enter key to "
von dieser Zeit: KVM Key Stroke Combination for IBM BladeCenter | VMETC.com
Zu Erklärung: da die Tastaturkombination sehr "komplex" ist und ich die öfters nutze wäre das ideal sowas auf die Macros einer solchen Tastatur legen z.B. auf die Razer BlackWidow 2013 oder ist das nicht möglich.
Danke für die Hilfe
EDI:T, die Kombination ist: NumLk - NumLk - Servernummer - Enter-Taste. Manche andere KVM haben noch verrücktere Kombinationen z.B:
http://www.aten.com/data/quick_finder/hotkey/hotkey.htm
Danke für die Hilfe
