diese rams haben aber 3,5ns chips nicht 4,5 wie du behauptet hast seht mal hier
GeIL Announces PC4000 DDR500 / PC4200 DDR533 Dual Channel DDR Platinum Series ~Paul
City of Industry, CA - (July 24, 2003) GeIL Corp, as one of the top memory manufacture for high-performance DDR memory, is proud to announce the release of PC4000 (500MHz) / PC4200 (533MHz) Platinum Series Dual Channel DDR Kits.
The outrageous speed is achieving by GeIL 3.5ns TSOP memory chips and platinum copper heat spreader. Unlike other PC4000 rated at CAS 3, GeIL PC4000 is rated at CAS 2.5!
With the advanced Dual Channel DDR technology from Intel's 875/865 chipsets, we are proud that our newest GeIL PC4000/PC4200 Platinum is ready to take the full advantages of Intel's new technology. As for our PC4200 Ultra Platinum which is capable of running at the speed of 533MHz, it would be by far the fastest DDR memory module available in the market now.
The PC4000 / PC4200 would be available only in Dual Channel DDR Ultra Platinum Kits.
SKU Code Descriptions
GL5124000DC 512MB (2x256MB) PC4000 500Mhz DC
GL1G4000DC 1GB     (2x512MB) PC4000 500Mhz DC
GL5124200DC 512MB (2x256MB) PC4200 533Mhz DC
GL1G4200DC
 1GB     (2x512MB) PC4200 533Mhz DC
The detailed specifications are listed as the following.
PC4000 500MHz Dual Channel DDR Ultra Platinum Version:
Available only in 512MB (2X256MB) and 1GB (2X512MB) Dual Channel DDR Platinum Kits.
- 184pin, Non-ECC, Un-buffered, high performance DDR memory modules.
- GeIL 3.5ns Chips
- 6 Layers Ultra Low Noises Shielded PCB board.
- Optimized SPD for Intel's 875/865 chipset Dual Channel DDR motherboards.
- Tin Coated Platinum - Copper Heat Spreader
- Lifetime Warranty
- CAS 2.5 7-4-4 Running @ DDR500MHz PC4000
- 2.65v-2.95V
- Retail package with clear acrylic case and instructions.
PC4200 533MHz Dual Channel DDR Ultra Platinum Version:
Available only in 512MB (2X256MB) and 1GB (2X512MB) Dual Channel DDR Ultra Platinum Kits.
- Hand Picked GeIL 3.5ns Chips
- Lifetime Warranty
- CAS 3 8-4-4 Running @ DDR533MHz PC4200
- 2.65v-2.95V
also passt das dann doch auf jeden fall
