Fehler bei DynDNS Updater
0
0divx0
Guest
Hey...So hab mir grade mal DynDNS eingerichtet aber beim DynDNS Updater bekomm ich immer denn fehler "error no update" was hab ich da nun wieder falsch gemacht lol.
Hier mal nen auszug aus der log:
DynDNS Updater - Version 3.1.0 (Build 9) log file. Created on 16:32:04 - 06.07.2006.
[001] - 16:32:04 - 06.07.2006 - DynDNS Updater started...
[002] - 16:32:45 - 06.07.2006 - Total group(s): No group
[002] - 16:32:45 - 06.07.2006 - Total host(s): No host
[002] - 16:32:45 - 06.07.2006 - Connected from: Christian
[002] - 16:32:45 - 06.07.2006 - Connected using: Local Area Network
[002] - 16:32:45 - 06.07.2006 - Automatic update: Disable
[002] - 16:32:45 - 06.07.2006 - Checking interval: Not applicable
[002] - 16:32:45 - 06.07.2006 - IP address is detected automatically
[002] - 16:32:45 - 06.07.2006 - Current IP: 10.10.0.3
[002] - 16:32:45 - 06.07.2006 - Updated IP: 10.10.0.3
[002] - 16:32:45 - 06.07.2006 - Last updated: Cannot detect last update time
[002] - 16:32:45 - 06.07.2006 - Next force update: 07.02.2007 16:32:45
[002] - 16:32:45 - 06.07.2006 - DynDNS Updater ready...
[003] - 16:34:35 - 06.07.2006 - IP changes (10.10.0.3 > [automatic])
[005] - 16:34:35 - 06.07.2006 - Update process starts
[004] - 16:34:36 - 06.07.2006 - christianw85 [dyndns.org]: notfqdn (A Fully-Qualified Domain Name was not provided)
[005] - 16:34:36 - 06.07.2006 - Update process finished
[004] - 16:34:36 - 06.07.2006 - Update result: error no update
[002] - 16:34:37 - 06.07.2006 - Next force update: 07.02.2007 16:34:19
[002] - 16:34:37 - 06.07.2006 - DynDNS Updater ready...
[003] - 16:34:44 - 06.07.2006 - Manual update is requested
[005] - 16:34:44 - 06.07.2006 - Update process starts
[004] - 16:34:44 - 06.07.2006 - christianw85 [dyndns.org]: notfqdn (A Fully-Qualified Domain Name was not provided)
[005] - 16:34:45 - 06.07.2006 - Update process finished
[004] - 16:34:45 - 06.07.2006 - Update result: error no update
[002] - 16:34:45 - 06.07.2006 - Next force update: 07.02.2007 16:34:19
[002] - 16:34:45 - 06.07.2006 - DynDNS Updater ready...
[003] - 16:35:08 - 06.07.2006 - Manual update is requested
[005] - 16:35:08 - 06.07.2006 - Update process starts
[004] - 16:35:09 - 06.07.2006 - christianw85 [dyndns.org]: notfqdn (A Fully-Qualified Domain Name was not provided)
[005] - 16:35:09 - 06.07.2006 - Update process finished
[004] - 16:35:09 - 06.07.2006 - Update result: error no update
[002] - 16:35:09 - 06.07.2006 - Next force update: 07.02.2007 16:34:19
[002] - 16:35:09 - 06.07.2006 - DynDNS Updater ready...
[003] - 16:35:15 - 06.07.2006 - Manual update is requested
[005] - 16:35:15 - 06.07.2006 - Update process starts
[004] - 16:35:16 - 06.07.2006 - christianw85 [dyndns.org]: notfqdn (A Fully-Qualified Domain Name was not provided)
[005] - 16:35:16 - 06.07.2006 - Update process finished
[004] - 16:35:16 - 06.07.2006 - Update result: error no update
[002] - 16:35:16 - 06.07.2006 - Next force update: 07.02.2007 16:34:19
[002] - 16:35:16 - 06.07.2006 - DynDNS Updater ready...
[001] - 16:35:30 - 06.07.2006 - DynDNS Updater stopped...
[001] - 16:40:23 - 06.07.2006 - DynDNS Updater started...
[002] - 16:40:24 - 06.07.2006 - Total group(s): 1 group
[002] - 16:40:24 - 06.07.2006 - Total host(s): 1 host
[002] - 16:40:24 - 06.07.2006 - Connected from: Christian
[002] - 16:40:24 - 06.07.2006 - Connected using: Local Area Network
[002] - 16:40:24 - 06.07.2006 - Automatic update: Enable
[002] - 16:40:24 - 06.07.2006 - Checking interval: 5 minutes
[002] - 16:40:24 - 06.07.2006 - IP address is detected automatically
[002] - 16:40:24 - 06.07.2006 - Current IP: 10.10.0.3
[002] - 16:40:24 - 06.07.2006 - Updated IP: 10.10.0.3
[002] - 16:40:24 - 06.07.2006 - Last updated: Cannot detect last update time
[002] - 16:40:24 - 06.07.2006 - Next force update: 07.02.2007 16:40:24
[002] - 16:40:24 - 06.07.2006 - DynDNS Updater ready...
[003] - 16:40:31 - 06.07.2006 - IP changes (10.10.0.3 > [automatic])
[005] - 16:40:31 - 06.07.2006 - Update process starts
[004] - 16:40:31 - 06.07.2006 - Group christianw85 cannot be updated again
[005] - 16:40:31 - 06.07.2006 - Update process finished
[004] - 16:40:31 - 06.07.2006 - Update result: error no update
[002] - 16:40:31 - 06.07.2006 - Next force update: 07.02.2007 16:40:24
[002] - 16:40:31 - 06.07.2006 - DynDNS Updater ready...
[003] - 16:40:55 - 06.07.2006 - IP changes (10.10.0.3 > [automatic])
[005] - 16:40:55 - 06.07.2006 - Update process starts
[004] - 16:40:55 - 06.07.2006 - Group christianw85 cannot be updated again
[005] - 16:40:55 - 06.07.2006 - Update process finished
[004] - 16:40:56 - 06.07.2006 - Update result: error no update
[002] - 16:40:56 - 06.07.2006 - Next force update: 07.02.2007 16:40:54
[002] - 16:40:56 - 06.07.2006 - DynDNS Updater ready...
[003] - 16:41:12 - 06.07.2006 - Manual update is requested
[005] - 16:41:12 - 06.07.2006 - Update process starts
[004] - 16:41:13 - 06.07.2006 - christianw85 [dyndns.org]: notfqdn (A Fully-Qualified Domain Name was not provided)
[005] - 16:41:13 - 06.07.2006 - Update process finished
[004] - 16:41:13 - 06.07.2006 - Update result: error no update
[002] - 16:41:13 - 06.07.2006 - Next force update: 07.02.2007 16:40:54
[002] - 16:41:13 - 06.07.2006 - DynDNS Updater ready...
[003] - 16:41:20 - 06.07.2006 - Manual update is requested
[005] - 16:41:20 - 06.07.2006 - Update process starts
[004] - 16:41:21 - 06.07.2006 - christianw85 [dyndns.org]: notfqdn (A Fully-Qualified Domain Name was not provided)
[005] - 16:41:21 - 06.07.2006 - Update process finished
[004] - 16:41:21 - 06.07.2006 - Update result: error no update
[002] - 16:41:21 - 06.07.2006 - Next force update: 07.02.2007 16:40:54
[002] - 16:41:21 - 06.07.2006 - DynDNS Updater ready...
[004] - 16:42:15 - 06.07.2006 - Current IP address (10.10.0.3) is not public IP
[002] - 16:42:15 - 06.07.2006 - Will try to check again within 1 minutes
[003] - 16:42:25 - 06.07.2006 - Manual update is requested
[004] - 16:42:25 - 06.07.2006 - Current IP address (10.10.0.3) is not public IP
[002] - 16:42:25 - 06.07.2006 - Will try to check again within 1 minutes
[003] - 16:42:34 - 06.07.2006 - Manual update is requested
[004] - 16:42:34 - 06.07.2006 - Current IP address (10.10.0.3) is not public IP
[002] - 16:42:34 - 06.07.2006 - Will try to check again within 1 minutes
[003] - 16:42:45 - 06.07.2006 - IP changes (10.10.0.3 > [automatic])
[005] - 16:42:45 - 06.07.2006 - Update process starts
[004] - 16:42:45 - 06.07.2006 - Group christianw85 cannot be updated again
[005] - 16:42:45 - 06.07.2006 - Update process finished
[004] - 16:42:45 - 06.07.2006 - Update result: error no update
[002] - 16:42:45 - 06.07.2006 - Next force update: 07.02.2007 16:42:44
[002] - 16:42:45 - 06.07.2006 - DynDNS Updater ready...
[003] - 16:43:09 - 06.07.2006 - Manual update is requested
[005] - 16:43:09 - 06.07.2006 - Update process starts
[004] - 16:43:09 - 06.07.2006 - christianw85 [dyndns.org]: notfqdn (A Fully-Qualified Domain Name was not provided)
[005] - 16:43:10 - 06.07.2006 - Update process finished
[004] - 16:43:10 - 06.07.2006 - Update result: error no update
[002] - 16:43:10 - 06.07.2006 - Next force update: 07.02.2007 16:42:44
[002] - 16:43:10 - 06.07.2006 - DynDNS Updater ready...
VLLT. KANN MIR JA EINER WEITERHELFEN..........:bigok:
Sieht aus als würdest du über einen Router reingehen. Deine IP ist immer 10.10.0.3, diese ändert sich nicht, deshalb gibts auch kein Update.
Hat dein Router keine DynDNS-Funktion?
ja 10.10.0.3 ist meine IP die ist fest vergeben...mein router ist ne fritzbox fon wlan 7050 der hat ne dyndns funktion aber frag mich nicht wie das funktioniert lol...kannste mir da vllt. helfen???
Ja, du navigierst im Router-Menü zur der Funktion und trägst dort die Daten ein, die du schon in den DynDNS-Updater eingetragen hast. Also Benutzername, Passwort, Domain usw.
Dann einfach bestätigen. Nach jeder Einwahl wird deine IP aktualisiert.
Den DynDNS-Updater kannste dann von deinem PC runterschmeißen.
so siehts jetzt aus und wie weiß ich das man jetzt auf dateien von mir zugreifen kann und wie geb ich die frei????
Damit hat das alles nicht zu tun. Du bist jetzt nur immer unter der selben Adresse erreichbar.
Wenn du Dateien Freigeben willst, würde ich dir einen FTP-Server empfehlen.
Dort kannst du dann Benutzer anlegen und Ordner "freigeben" auf die die Benutzer zugreifen können.
Tutorials wie man sowas einrichtet gibts hier mehrere, einfach mal die Suchfunktion bemühen.
jupp ok werd mal suchen...aber im router is das alles soweit eingerichtet oder???
ja genau das meine IP ;-)...konntest drauf zugreifen was
hmmm hab mal gesucht aber nix so richtig gefunden...nach was müsste man genau suchen???
hey thx hat alles funktioniert...danke für deine hilfe Jean Pernod!!!
