Hallo Leute, ich hab folgendes Problem: die Vista installation kann nicht abgeschlossen werden da ich immer vor dem abschluss ein BSOD bekomme. BSOD ist 0x0000007E und mit der datei nvlddmkm.sys also hat mit GraKa zu tun.
Mein system:
Abit A8N 32x
X2 2,5GHz
1GB RAM
MSI 7900 GTO
SATA HDD
Audigy 2ZS
Ich habe schon folgendes probiert:
Hat jemand ein vorschlag?
Mein system:
Abit A8N 32x
X2 2,5GHz
1GB RAM
MSI 7900 GTO
SATA HDD
Audigy 2ZS
Both Vista pre-RC1 (5536) and RC1 (5600) shipped with the buggy nvidia 95_64 vista drivers. On certain nvidia cards like my 7900GX2 this causes a BSOD during the device installation phase, reporting an error in nvlddmkm.sys.
The latest 96_33 drivers work, but you are unable to install them normally or boot into safe mode because Vista cannot complete setup correctly.
Here's how to fix that.
Requirements:
1) Dual-boot machine with Windows XP running on another partition.
2) Administrative privileges in XP
I performed this fix using the x64 version of RC1
Phase 1:
1) Download the latest 96_33 Vista drivers from nvidia
2) Extract the contents of the driver file to a directory (I used WinRAR for this).
3) Open a command window in the driver directory and enter the following:
mkdir expand
expand -r nvapi64.dl_ expand\nvapi64.dll
expand -r nvd3dum.dl_ expand\nvd3dum.dll
expand -r nvd3dumx.dl_ expand\nvd3dumx.dll
expand -r nvlddmkm.sy_ expand\nvlddmkm.sys
(You might just need nvlddmkm.sys, but I replaced the other files as well to be sure.)
You end up with a new directory called expand that contains the files you need to replace.
Phase 2:
1) Perform a clean install of Vista RC1 on a fresh partition.
2) Critical After the setup process has expanded the installation files the machine will reboot. You must select 'Earlier version of windows' and boot back into XP at this stage.
Phase 3:
1) Since the Vista files are secured with an SID that XP doesn't know about, you need to take ownership of the relevant files.
2) Turn off simple file-sharing in the Folder View options.
3) Navigate to <VistaDrive>:\Windows\System32\DriverStore\FileRepository
4) If you are using a desktop graphics card, the files that have to be changed are in nv_lh.inf_185bb110. It appears that nv_aw.inf_d8327a6a contains the files for laptop cards. This fix was performed on a desktop altering just the files in the nv_lh directory. If in doubt you can alter both sets.
5) Back up the relevant folder in case you screw something up.
6) For each of the files to be changed (the files with the same name as the ones in the expand directory you created above) right-click, select Properties and click the Security tab. Click on Advanced and then Take Ownership. Change the owner to the admin account that you are logged on as. Click OK. R-click and select Properties->Security again, then click on Add, add your account and click Full Control.
7) Finally, copy the new 96.33 files across to overwrite the old ones.
Now restart your computer and let the Vista install proceed. The driver will still report itself as 95.64, I would advise performing a proper driver update to the new ones.
