Nightmare86
Habe probleme mit meinem Lite On SOHW-1633S.
Hier ist der Log:
########################### System Information ###########################
Windows XP Professional 5.1 Service Pack 2 (Build 2600)
Processor info: AMD Athlon(tm) 64 Processor 3400+ (2411MHz)
Memory Available to Windows: 1.047.856 KB
############################ Program Information ###########################
File Name: C:\Programme\Alcohol Soft\Alcohol 120\Alcohol.exe
Company Name: Alcohol Soft Development Team
Description: Alcohol 120%
Original: alcohol.exe
Product: Alcohol 120%
Trademarks: Alcohol Soft Development Team
Copyright: Copyright(C) 2002-2005 Alcohol Soft Development Team
Version: 1.9.5 ( Build 3105 )
Date: 2005/07/05
Hash: 7b483efea095f765ee87cc5b23643dcd
Hash(1): d1a6dcfed81ff332d01c55e3cbc5c0e68bc7c1025c3ae23577c953ca5d59955
Hash(2): 80965b475776dcff3fc125950300bc53e7fff35f2cb2cb2f83c727ad952c740
File Name: C:\Programme\Alcohol Soft\Alcohol 120\alcoholx.dll
Description: Alcohol virtual device control library
Original: alcoholx.dll
Copyright: Copyright (C) 2000-2004
Version: 3.47.0 ( Build 0 )
Date: 2004/08/12
Hash: 1b7083f2ca3a98bb3c14c3a08ad5c2d2
File Name: C:\Programme\Alcohol Soft\Alcohol 120\devsupp.dll
Description: Alcohol Software Device Capability Library
Original: devsupp.dll
Product: Alcohol Software Device Capability Library
Copyright: Copyright(C) 2002-2003 Alcohol Soft Development Team
Version: 2.4.0 ( Build 627 )
Date: 2005/06/27
Hash: 4e112134e74179bf3f0f69a93603131b
########################### User Information ###########################
Licensed to: Happy User
Registered User ID: 04EF
########################### Options Setting ###########################
Devices control interface: Default Driver Control Interface
CPU Priority Level: High
Memory Buffer Size (MB): 128
Examine the accuracy of data read from physical device: Yes
Turn off "Auto-Select best write speed" function if possible: No
Overburn disc(s): No
Fill memory buffer before recording discs: Yes
Ignore Media Type: Yes
RMPS (Recordable Media Physical Signature) Emulation: No
BAD Sectors Emulation: No
Sub-Channel Data Fixed & Emulation: No
Laserlock Emulation: No
Current Language: German
############################ Device(s) List ############################
(E
HL-DT-ST DVD-ROM GDR8163B (nvatabus, Port 0, Bus 0, Target 1, Lun 0)
(D
LITE-ON DVDRW SOHW-1633S (nvatabus, Port 0, Bus 0, Target 0, Lun 0)
(F
Generic DVD-ROM (d347prt, Port 2, Bus 0, Target 0, Lun 0)
(M
SCSIVAX DVD/CD-ROM (Vax347s, Port 3, Bus 0, Target 0, Lun 0)
##################### Installed Device Drivers List #####################
a347bus.sys ACPI.sys afd.sys ALCXWDM.SYS AmdK8.sys
aslm75.sys atapi.sys audstub.sys AVGNTDW.SYS Beep.SYS
BOOTVID.dll Cdfs.SYS cdrom.sys CLASSPNP.SYS d347bus.sys
d347prt.sys disk.sys dmio.sys dmload.sys drmk.sys
dump_nvatabus.sys dump_WMILIB.SYS Dxapi.sys dxg.sys dxgthk.sys
enodpl.sys fdc.sys Fips.SYS flpydisk.sys fltmgr.sys
Fs_Rec.SYS ftdisk.sys gameenum.sys hal.dll HIDCLASS.SYS
HIDPARSE.SYS hidusb.sys HTTP.sys imapi.sys ipnat.sys
ipsec.sys isapnp.sys kbdclass.sys kbdhid.sys KDCOM.DLL
kmixer.sys ks.sys KSecDD.sys mnmdd.SYS mouclass.sys
mouhid.sys MountMgr.sys mrxdav.sys mrxsmb.sys Msfs.SYS
msgpc.sys msmpu401.sys mssmbios.sys Mup.sys NDIS.sys
ndistapi.sys ndisuio.sys ndiswan.sys NDProxy.SYS netbios.sys
netbt.sys Npfs.SYS ntdll.dll Ntfs.sys ntkrnlpa.exe
Null.SYS nv_agp.sys nv4_disp.dll nv4_mini.sys nvatabus.sys
NVENETFD.sys nvnetbus.sys NVNRM.SYS NVSNPU.SYS parport.sys
PartMgr.sys ParVdm.SYS pci.sys pciide.sys PCIIDEX.SYS
portcls.sys PQNTDrv.SYS psched.sys ptilink.sys PxHelp20.sys
rasacd.sys rasl2tp.sys raspppoe.sys raspptp.sys raspti.sys
Razerlow.sys rdbss.sys RDPCDD.sys rdpdr.sys redbook.sys
SCSIPORT.SYS serenum.sys serial.sys sr.sys srv.sys
swenum.sys sysaudio.sys tandpl.sys tcpip.sys TDI.SYS
termdd.sys update.sys usbccgp.sys USBD.SYS usbhub.sys
usbohci.sys USBPORT.SYS USBSTOR.SYS Vax347b.sys Vax347s.sys
vga.sys VIDEOPRT.SYS VolSnap.sys wanarp.sys watchdog.sys
wdmaud.sys win32k.sys WMILIB.SYS
################## Detailed Information of Device(s) ##################
(E
HL-DT-ST DVD-ROM GDR8163B(0:1) detail information.
Vendor Identification: HL-DT-ST
Product Identification: DVD-ROM GDR8163B
Production Revision Level: 0L23
-* Note: This information below is provided by the unit, it might be inaccurate. *-
-* This software does not use this information! *-
Removable media: Yes
Version: ATAPI (INF-8090i/INF-8020i/INF-8028i)
Response Data Format: 02h
CD-R Read/Write: Yes/No
CD-RW Read/Write: Yes/No
Read CD-R Fixed Packet: Yes
Test Write: No
DVD-ROM Read: Yes
DVD-R Read/Write: Yes/No
DVD-RAM Read/Write: Yes/No
Audio Play: Yes
Composite Audio and Video Data Stream: No
Digital output (IEC958) on port 1 Supported: No
Digital output (IEC958) on port 2 Supported: No
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: No
CD-DA Commands supported: Yes
CD-DA Stream is Accurate: Yes
R-W Supported: No
R-W De-interleaved and Corrected: No
C2 Pointers Support: Yes
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Lock media into the drive: Yes
Currently drive Lock state: Unlocked
Prevent Jumper: No
Eject Command: Yes
Separate volume levels: Yes
Separate channel mute: Yes
Changer Supports Disc Present: No
Software slot selection: No
Side change capable: No
P through W in Lead-In: Yes
(D
LITE-ON DVDRW SOHW-1633S(0:0) detail information.
Vendor Identification: LITE-ON
Product Identification: DVDRW SOHW-1633S
Production Revision Level: BS0Y
Support recording method: DAO, RAW SAO, RAW SAO+SUB, RAW DAO(96), TAO, DVD DAO
BURN-Free Technology: SMART-BURN
Auto-Select best write speed: SMART-BURN
CD-R Read/Write: Yes/Yes
CD-RW Read/Write: Yes/Yes
Test Write: Yes
DVD-ROM Read: Yes
DVD-R Read/Write: Yes/Yes
DVD-RAM Read/Write: No/No
Audio Play: Yes
Digital output (IEC958) on port 1 Supported: Yes
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: Yes
R-W Supported: Yes
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Prevent Jumper: No
Eject Command: Yes
(F
Generic DVD-ROM(2:0) detail information.
Vendor Identification: Generic
Production Revision Level: 1.0
Version: ANSI X3.131:1994 (SCSI-2)
Test Write: No
DVD-ROM Read: Yes
Audio Play: Yes
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: No
R-W Supported: Yes
R-W De-interleaved and Corrected: Yes
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Prevent Jumper: No
Eject Command: Yes
Separate volume levels: No
Separate channel mute: No
P through W in Lead-In: No
###################### Source Disc/Image Information ######################
Typ: Media Descriptor Imagedatei
Pfad: J:\EXE\E\
Serious.Sam.II-*******.ShadowCast.mdf
Größe: 2584.53 MB
Session: 1
Track: 1
Session 01:
Track 01: DVD, Länge: 1323280(2.52 GB), Adresse: 000000
####################### Dumping/Recording Progress Log #######################
15:54:08 Prozessor Info: AMD Athlon(tm) 64 Processor 3400+ (2411MHz)
15:54:08 Verfügbarer Windows Speicher: 1.047.856 KB
15:54:08 Größe des Pufferspeichers: 128 MB
15:54:08 Laden der Imagedatei: J:\EXE\E\Serious.Sam.II-*******.ShadowCast.mds
15:54:08 DVD Quell-Info: Session: 1, Track: 1, Länge: 2.52 GB / 294:03:55
15:54:08 (D
LITE-ON DVDRW SOHW-1633S(0:0): Aufzeichnungsmethode/-geschwindigkeit
15:54:08 Aufzeichnung - DVD DAO - 3.2X (4432 KB/Sek)
(D
LITE-ON DVDRW SOHW-1633S(0:0) - Media format: DVD-R
15:56:56 (D
LITE-ON DVDRW SOHW-1633S(0:0) - [Write ERROR] LBA: 16, Length: 16
S:KEY - 03/0C/00 - "Write Error"
15:57:00 (D
LITE-ON DVDRW SOHW-1633S(0:0): Aufzeichnung fehlgeschlagen!
15:57:00 Fehlermeldung: [03/0C/00] - Write Error
15:57:00 (D
15:57:00 Laden der Imagedatei abgebrochen!
15:57:02 Es ist ein Aufzeichnungsproblem aufgetreten!
Bitte überprüfen Sie die Log Datei und melden etwaige Fehler an den Technischen Support.
S:KEY - 03/0C/00 - "Write Error" was kann ich da tun?
Hier ist der Log:
Date: 2005/07/05
Date: 2004/08/12
Date: 2005/06/27
(E
(D
(F
(M
(E
Test Write: No
DVD-ROM Read: Yes
Audio Play: Yes
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: No
R-W Supported: No
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Prevent Jumper: No
Eject Command: Yes
(D
Test Write: Yes
DVD-ROM Read: Yes
Audio Play: Yes
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: Yes
R-W Supported: Yes
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Prevent Jumper: No
Eject Command: Yes
(F
Test Write: No
DVD-ROM Read: Yes
Audio Play: Yes
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: No
R-W Supported: Yes
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Prevent Jumper: No
Eject Command: Yes
Pfad: J:\EXE\E\
Größe: 2584.53 MB
Session: 1
Track: 1
Session 01:
15:54:08 (D
(D
15:56:56 (D
15:57:00 (D
15:57:00 (D
