Big Problem with Nero ;( !!!
Ultimate
hi,
jedes mal wenn ich ne .bin DVD brenne kommt diese Meldung :
5C80001080100000000961597031
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Programme\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02.11.2004 12:54:32
NT-SPTI used
Nero Version: 7.0.1.4
Internal Version: 7, 0, 1, 4
(Nero Express)
Recorder: <TSSTcorp CD/DVDW SH-W162C>Version: TS10 - HA 1 TA 0 - 7.0.1.4
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <TSSTcorp CD/DVDW SH-W162C>Version: TS10 - HA 1 TA 0 - 7.0.1.4
=== Scsi-Device-Map ===
CdRomPeripheral : TSSTcorp CD/DVDW SH-W162C atapi Port 0 ID 0 DMA: On
DiskPeripheral : SAMSUNG SP2004C atapi Port 3 ID 0 DMA: On
CdRomPeripheral : TY5504O VAY843B 1.0 dtscsi Port 6 ID 0 DMA: Off
CdRomPeripheral : TY5504O VAY843B 1.0 dtscsi Port 6 ID 1 DMA: Off
CdRomPeripheral : TY5504O VAY843B 1.0 dtscsi Port 6 ID 2 DMA: Off
CdRomPeripheral : TY5504O VAY843B 1.0 dtscsi Port 6 ID 3 DMA: Off
=== CDRom-Device-Map ===
TY5504O VAY843B E: CDRom1
TY5504O VAY843B F: CDRom2
TY5504O VAY843B G: CDRom3
TY5504O VAY843B H: CDRom4
TSSTcorp CD/DVDW SH-W162C Z: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 2046MB (2095536kB)
Free physical memory: 1341MB (1373644kB)
Memory in use : 34 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
3.1.2006
UDF Zusammenstellung
13:15:27 #1 Text 0 File Isodoc.cpp, Line 6411
UDF document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : pure
UDF Revision : 1.02
UDF Partition Type : physical
13:15:27 #2 Text 0 File ThreadedTransfer.cpp, Line 525
ReadBuffer-Pipe got 262144KB of Memory
13:15:27 #3 Text 0 File Reader.cpp, Line 124
Reader running
13:15:27 #4 Text 0 File Writer.cpp, Line 113
Writer Z: TSSTcorp CD/DVDW SH-W162C running
13:15:27 #5 Text 0 File Burncd.cpp, Line 3342
Turn on Disc-At-Once, using DVD media
13:15:27 #6 Text 0 File DlgWaitCD.cpp, Line 279
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2281455 (506:59.30, 4455MB)
13:15:27 #7 Text 0 File DlgWaitCD.cpp, Line 291
Write in overburning mode: NO (enabled: CD)
13:15:27 #8 Text 0 File DlgWaitCD.cpp, Line 2578
Recorder: TSSTcorp CD/DVDW SH-W162C, Media type: DVD-R
Disc Manufacturer: TYG02 -
Disc Application Code: 64, Disc Physical Code: 193
13:15:27 #9 Text 0 File DlgWaitCD.cpp, Line 458
>>> Protocol of DlgWaitCD activities: <<<
13:15:27 #10 Text 0 File ThreadedTransferInterface.cpp, Line 847
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2281456 (2281456) = #2281456/506:59.31
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2281456 blocks [Z: TSSTcorp CD/DVDW SH-W162C]
13:15:27 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [Z: TSSTcorp CD/DVDW SH-W162C] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4672421888, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2281456 | lead-out | 1 | 0x41 | 0x00
13:15:27 #12 Text 0 File SCSIPassThrough.cpp, Line 36
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
13:15:27 #13 Phase 24 File dlgbrnst.cpp, Line 1725
Caching of files started
13:15:27 #14 Text 0 File Burncd.cpp, Line 4176
Cache writing successful.
13:15:27 #15 Phase 25 File dlgbrnst.cpp, Line 1725
Caching of files completed
13:15:27 #16 Phase 36 File dlgbrnst.cpp, Line 1725
Burn process started at 8x (11.080 KB/s)
13:15:27 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
13:15:27 #18 Text 0 File DVDR.cpp, Line 2580
Recording mode: Sequential Recording Mode
13:15:27 #19 Text 0 File MMC.cpp, Line 21611
Set BUFE: Super Link -> ON
13:15:27 #20 Text 0 File DVDR.cpp, Line 2735
Start write address at LBA 0
DVD high compatibility mode: Yes
13:15:27 #21 Text 0 File Cdrdrv.cpp, Line 8411
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
13:25:33 #22 SPTI -1114 File SCSIPassThrough.cpp, Line 323
Z: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1114)
Sense Key: 0x06 (KEY_UNIT_ATTENTION)
Sense Code: 0x29
Sense Qual: 0x00
CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x70 00 06 00 00 00 00 0A 00 00 00 00 29
Buffer x06aa0000: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
13:25:33 #23 CDR -1114 File Writer.cpp, Line 302
Reset occurred
13:25:33 #24 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
13:25:33 #25 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
13:25:33 #26 Text 0 File DVDR.cpp, Line 2978
EndDAO: Last written address was -1
13:25:33 #27 Phase 38 File dlgbrnst.cpp, Line 1725
Burn process failed at 8x (11.080 KB/s)
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 14.09.2005 20:17:44 (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Wie kann ich das Prob lösen ?
Mfg Ultimate
Und hier noch ein Auszug von Alcohol !
Wenns mit Alc funktioniert denke ich mal liegts an Nero 7. Versuchs mal mit der 6er Version....
