Aura Sync erkennt keine Grafikkarte
viniebenet3
I have an aura graphics card and a motherboard. The motherboard works fine, but when I install aura sync, the graphics card is never shown in my device list. I do two things.
When I got the card, it "breathed" red and I let it work for some time. (A type of factory reset may be required. I wonder if the card uses non-volatile memory that may have been corrupted.)
I'm not sure where I found the file below, but it does work to color the card change (limited to 3 effects). This would be fine, except that the use of two programs does not allow synchronization.
"AURA RGB lighting control for graphics card & XG-STATION_Version 0.0.6.1.exe" (signed by asus, but I can't find it on their website)
Has anyone ever gone through this?
If so, let me know if you have a solution.
What GraphicsCard do you have? Not all cards are compatible with Aura-Sync.
