Adobe Flash Player 10.2.161.22 Preview 1 samt 64-bit Support
Herby
Die Highlights sind:
  • 64-bit support — Native support for 64-bit operating systems and 64-bit web browsers on Linux, Mac OS, and Windows.
  • Internet Explorer 9 hardware accelerated rendering support — Enhanced support for Internet Explorer 9 Beta. It takes advantage of hardware accelerated graphics in Internet Explorer 9 Beta, utilizing hardware rendering surfaces to improve graphics performance and enable seamless composition.
Download
Important: Please note that if you install the Flash Player "Square" preview, you will need to keep this version up to date by manually installing updates from the Flash Player "Square" download page on Adobe Labs. You will not receive automatic update notifications for future final releases of Flash Player, and you will need to manually uninstall Flash Player "Square" before installing a final shipping version of Flash Player.
