6x2GB OCZ3RPR1866-LVG6K und Gigabyte U-X58-A-UD7
warumich
Hallo, ich bräuchte bitte dringend Hilfe
Meine Komponenten:
Mainboard Gigabyte U-X58-A-UD7
CPU 980 XE
OCZ3RPR1866-LVG6K
CPUZ wirft diesed Log aus. Ich habe erst mal mur die bestimmten Auszüge kopiert:
Code:
DIMM #                1
    SMBus address        0x50
    Memory type        DDR3
    Module format        UDIMM
    Manufacturer (ID)    OCZ (7F7F7F7FB0000000)
    Size            2048 MBytes
    Max bandwidth        PC3-8500F (533 MHz)
    Part number        OCZ3RPR1866LV2G
    Number of banks        8
    Nominal Voltage        1.50 Volts
    EPP            no
    XMP            no
JEDEC timings table        CL-tRCD-tRP-tRAS-tRC @ frequency
    JEDEC #1        5.0-5-5-12-19 @ 380 MHz
    JEDEC #2        6.0-6-6-14-23 @ 457 MHz
    JEDEC #3        7.0-7-7-16-27 @ 533 MHz
    JEDEC #4        8.0-8-8-19-31 @ 609 MHz
DIMM #                2
    SMBus address        0x51
    Memory type        DDR3
    Module format        UDIMM
    Size            2048 MBytes
    Number of banks        8
    EPP            no
    XMP            no
DIMM #                3
    SMBus address        0x52
    Memory type        DDR3
    Module format        UDIMM
    Size            2048 MBytes
    Number of banks        8
    EPP            no
    XMP            no
DIMM #                4
    SMBus address        0x53
    Memory type        DDR3
    Module format        UDIMM
    Size            2048 MBytes
    Number of banks        8
    EPP            no
    XMP            no
DIMM #                5
    SMBus address        0x54
    Memory type        DDR3
    Module format        UDIMM
    Size            2048 MBytes
    Number of banks        8
    EPP            no
    XMP            no
DIMM #                6
    SMBus address        0x55
    Memory type        DDR3
    Module format        UDIMM
    Size            2048 MBytes
    Number of banks        8
    EPP            no
    XMP            no
DIMM #                1
SPD registers
        00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
    00    93 10 0B 02 02 11 00 09 03 52 01 08 0F 00 1E 00
    10    69 78 69 3C 69 10 F0 8C 70 03 3C 3C 00 F0 03 04
    20    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    30    00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01
    40    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    50    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    60    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    70    00 00 00 00 00 84 B0 02 00 00 00 00 00 00 3F 58
    80    4F 43 5A 33 52 50 52 31 38 36 36 4C 56 32 47 20
    90    20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    A0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    B0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    C0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    D0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    E0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    F0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DIMM #                2
SPD registers
DIMM #                3
SPD registers
DIMM #                4
SPD registers
DIMM #                5
SPD registers
DIMM #                6
SPD registers
Sandras Sisoft Log-Asuszug
Code:
DIMM #                1
    SMBus address        0x50
    Memory type        DDR3
    Module format        UDIMM
    Size            2048 MBytes
    Number of banks        8
    EPP            no
    XMP            no
DIMM #                2
    SMBus address        0x51
    Memory type        DDR3
    Module format        UDIMM
    Size            2048 MBytes
    Number of banks        8
    EPP            no
    XMP            no
DIMM #                3
    SMBus address        0x52
    Memory type        DDR3
    Module format        UDIMM
    Size            2048 MBytes
    Number of banks        8
    EPP            no
    XMP            no
DIMM #                4
    SMBus address        0x53
    Memory type        DDR3
    Module format        UDIMM
    Size            2048 MBytes
    Number of banks        8
    EPP            no
    XMP            no
DIMM #                5
    SMBus address        0x54
    Memory type        DDR3
    Module format        UDIMM
    Size            2048 MBytes
    Number of banks        8
    EPP            no
    XMP            no
DIMM #                6
    SMBus address        0x55
    Memory type        DDR3
    Module format        UDIMM
    Size            2048 MBytes
    Number of banks        8
    EPP            no
    XMP            no
DIMM #                1
SPD registers
DIMM #                2
SPD registers
DIMM #                3
SPD registers
DIMM #                4
SPD registers
DIMM #                5
SPD registers
DIMM #                6
SPD registers
Also ich bin ins Bios und habe unter MB Intelligent tweaker (M.I.T.)
Dort stand dann bei:
System Memory Multiplier [SPD] [Auto]
Memory Frequency (Mhz) 1066 1066
Profile Voltage 1.5
ich Naivling habe mal dran rumgeschraubt und dachte: einfach so mal den Multipier auf 12 hoch dann habe ich zumindest mal 1600MHz
Neustart gemacht Booted nicht. Hard-reset dann ins Bios dann kam diese Meldung:
The system has experienced boot failures because of overclocking or change of voltages.
Last settings in this page may not coincide with current H/W States.
Jedes mal wemm ich nun ins bios komme kommt diese Meldung (obwohl ich den Multiplier wieder auf [Auto] gesetzt hatte) die ich dann einfach wegklicken kann
Kann mir hier bitte jemand sagen was ich machen muss um wenigstens die in den technischen Daten des RAMs erwähnten 1866 MHZ erreichen kann? Mein Gott 1600Mhz reichen auch erst mal. Ich schätze mal da muss was an den timings oder Voltage gedreht werden und da bitte ich um Hilfe.
  • Processors u. Monitoring CPU-Z TXT Report.txt
  • Memory SPD CPU-Z TXT Report.txt
  • DMI BIOS CPU-Z TXT Report.txt
Hat denn niemand Lust mir eine etwas ausführliche Anleitung zu geben.
Zu meiner speziellen Konfig habe ich leider nichts gefunden
mann, das jeder immer soviel mhz beim ram haben muss. das ist mir völlig unverständlich. selbst schuld wenn das nicht einwandfrei läuft, da der speicher ja übertaktet werden muss und die i7 offiziell nur maximal 1066mhz mögen.
mach mal nen bios reset und lade dann die setup defaults im bios. die ramtimings musst du wahrscheinlich per hand eingeben, ich kenn mich leider nur nicht mit gigabyte aus. probier jedes JEDEC mal aus, angefangen mit dem dem niedrigsten ramteiler. ach ja, bei vollbestückung musst du wahrscheinlich die vdimm spannung auf 1,6-1,65v anheben und auch die qpi spannung.
