Hey kann mir einer helfen? Ich habe mir aus Post 1 diese max. performance runtergeladen und das bringt wirklich was, allerdings habe ich jetzt nur Grafikfehler was soll ich verändern?
Sys:
AMD X2 3800+ @ 2900MHz
4GB Ram (3,5GB nutzbar, da XP 32bit)
X1950Pro 256MB
//Optimal Performance .cfg for Crysis Beta #3 by .maSk//
!!!Please note that this cfg is optimized for Nvidia 8800 Series - some ATI users have Graphical Glitches with this cfg!!!
r_displayinfo = 0 (Ingame FPS, Mem usage and other info)
//Standard System Settings//
g_useProfile = 1
r_ShadersAsyncCompiling = 1
r_driver = "DX9"
r_VSync = 0
r_Texture_Anisotropic_Level = 0
r_TexMaxAnisotropy = 16
r_fsaa = 0
r_FSAA_samples = 0
r_FSAA_quality = 1
r_width = 1280
r_height = 1024
sys_budget_videomem = 256
sys_budget_sysmem = 3036 (use a lower value then your real memory size, so if you have 2Gig RAM let it stay)
//Option "Very High" unlock//
//(1=low, 2=medium, 3=high, 4= veryhigh)//
sys_spec_Full = 1
sys_spec_GameEffects = 2
sys_spec_ObjectDetail = 2
sys_spec_Particles = 2
sys_spec_Physics = 2
sys_spec_PostProcessing = 1
sys_spec_Shading = 2
sys_spec_Shadows = 2
sys_spec_Sound = 2
sys_spec_Texture = 2
sys_spec_VolumetricEffects = 2
sys_spec_Water = 2
//DX10 Effects for DX9 Rigs//
e_terrain_normal_map = 0
r_UseNormals = 0
r_shownormals = 0
r_sunshafts = 0
r_Beams = 0
r_BeamsDistFactor = 0.75
r_BeamsMaxSlices = 64
r_UsePom = 0
r_WaterGodRays = 0
//neat stuff//
r_ShadersStaticBranching = 0
r_ShadersDynamicBranching = 1
q_ShaderGlass = 2
r_UseEdgeAA = 0
sys_LowSpecPak = 0
r_VegetationSpritesAlphaBlend = 1
r_PostProcessEffectsFilters = 1
r_OceanRendType = 1
//Dual Graphiccard Settings//
r_MultiGPU = 0
sys_physics_GPU = (<- use one Card to do all the Physic related jobs (set "0" or"1"))
sys_physics_GPU =
//misc stuff//
net_wmi_check_interval = 0 (fix for people with 2 network cards or double Network onboard)
r_TexturesFilteringQuality = 3
r_TextureCompressor = 0
r_TexQuality = 3
r_VegetationSpritesTexRes = 64
r_GeomInstancing = 1
r_HDRRendering = 0
r_Coronas = 0
r_Glow = 0
e_decals = 0
r_Flares = 0
r_checkSunVis = 0
e_ram_maps = 0
e_fog = 0
e_clouds = 0
e_max_entity_lights=4
e_particles_lights = 0
r_Blur = 0
r_SSAO = 0
e_dissolve = 0
e_vegetation_bending = 0
r_WaterRefractions = 0
r_WaterReflections = 0
e_clouds = 0
r_PostProcessEffects = 0
/test/
sys_physics_CPU 0
r_MotionBlur=0
Sys:
X1950Pro 256MB
OMFG nehme es nicht ernst aber ich finde sowas ist absolut geisteskrank
