Mito
bei 310FSB und 310DRAM bleib mir nix über, aber ich habe wieder neuen bios gebastelt und ich sehr 312/312
PCI-E 108MHz
Memclock (DRAM Frequency) ...................... 200
1T/2T Timing (Command Per Clock)............... 1T (enabled)
CAS Latency (Tcl)..................................... 2.5T
RAS# to CAS# delay (Trcd)...................... .. 4T
Min RAS# active time (Tras)....................... 10T
Row precharge time (Trp).......................... 4T
Row Cycle time (Trc).......................... ..... 14T
Row refresh cyc time (Trfc)....................... 18T
Row to Row delay (Trrd)....................... .... 2T
Write recovery time (Twr)......................... 2T
Write to Read delay (Twtr)........................ 2T
Read to Write delay (Trwt)....................... 2T
Refresh Period (Tref).............................. 3120
DRAM Bank Interleave.......................... Enabled
DQS Skew Control.............................. Increase
DQS Skew Value................................ 255
DRAM Drive Strength........................... Level 7
DRAM Data Drive Strength...................... Level 1
Max Async Latency............................. 8ns
DRAM Response Time............................ Normal
Read Preamble Time............................ 5ns
IdleCycle Limit............................... 16
Dynamic Counter............................... Enable
R/W Queue Bypass.............................. 16x
Bypass Max.................................... 7x
32 Byte Granularity........................... Disable (4 Bursts)
