ZIL131
Hat sich eigentlich seit den Patches auch die Performance von ARMA gebessert? Würde dann nochmal mit der Demo testen ob mein Sys reicht.
bei mir isse schlechter geworden, kann aber auch daran liegen das mein pc vermüllt ist.
Wird sich nächste woche rausstellen.
Suma (ArmA Lead Programmer) im BI-Forum:
"We would like to notify you we have identified a bug in the ATI drivers, which can cause gradual performance degradation while playing ArmA. The bug is confirmed by the ATI team and they are working on a fix. The bug can be seen both in Catalyst 7.1 and 7.2, we did not test with older versions yet.
While uploading geometry data to the card, driver sometimes opens a process handle without closing it later, resulting in a leaked handle. If you are an advanced user, you can verify if you are affected by the issue by checking the handle count in the Task manager while running ArmA in a window. If you see handle count raising gradually,
As a temporary workaround, you can set both the Texture Detail and the Object Detail to Low Very Low to reduce the effect of the leak, and restart the game after playing a few missions.
You could also choose to install somewhat older Catalyst 6.7 drivers available at ATI Web Site, which do not have this problem. Note: installing older driver may degrade performance or cause visual artifacts in in other games, especially in those which were released recently.
We are sorry for the inconvenience and we will notify you once we know more about the fix availability from ATI.
It seems the Catalyst 6.7 does not have this problem, while 6.9 seems to have it. Not sure about 6.8 yet."
Ohne Cheats oder Mods, aber komplett weis, tja, wie geht das?![]()
noch ne Ladung ARMA. Sorry falls es bereits nervt
Aber ich werde trotzdem demnächst noch mehr posten^^
man geht in den tuningshop und lässt ihn lackieren, das schweinchenrosa gefällt mir da besonders.
mfg deep
Dann ist immernoch dreck unten am Wagen
Ist ein Bug:
Der Wagen war lackeirt, mit son butem zeugs.
Wenn man jetzt ein paar mal die Garage immerwieder öffnet und schließt, kann es passieren, dass der Wagen aufeinmal weiß ist.
Hatte ich bis jetzt 3 mal in unzähligen Stunden GTA, also ein sehr sehr seltener Bug, aber es gibt ihn.
mit dem patch auf vers. 1.1 geht dann alles wieder ohne bugs und fehler.
Macht eine heiden Spaß, so rum zu Cruisen, fliegen, bootfahren oder schön rumballern
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
