immerhin ist der Screen ebay-sicher
Wie bekommt ihr die Schrift da so schön auf den Screen? Mit paint?
free
Wie lassen sich die 6600er eigentlich nun übertakten? gehen die immernoch so schlecht und brauchen sau viel V-core oder hat sich das gebessert??
Bild machen
z.B. Paint öffnen
Textwerkzeug
fertig:
schon 3,2 GHz bei 1,29V und wird nicht wärmer wie 45 Grad auf den Cores. Gibts das?
ist ja kein Problem. Aber testen tust Du den trotzdem?
Nicht schlecht. Heizt ganz gut ein:
OCCT Perestroïka 1.0.0 Hi Tech and Most Powerful Stability Tester.
zip: http://www.ocbase.com/download/OCCTPT1.0.0.zip
installer: http://www.ocbase.com/download/OCCTPT1.0.0.exe
Da bleibt sogar manchmal die Maus stehen![]()
Feel free to send me any comments you may have, on this thread or by mail ( iench at ocbase dot com ).
And once you're happy, you just send me a mail with a small file (3KB), and that's it, done
Es gibt einen E6400 mit 4 MB Cache?
Wo? Hab ich noch nicht gesehen.
Hey guys,
Sorry for writing this message in english, but i don't speak German. Well, i used to, but it's all gone now... amazing how fast you forget things.
I'm OCCT's programmer, and i'm happy to see it spreading this farFeel free to send me any comments you may have, on this thread or by mail ( iench at ocbase dot com ).
I don't know if it's against the forum rules or not ( as i can't understand them ! ) but i'm looking for help in translating OCCT. As you have noticed, OCCT perestroika can be translated in any language... but for that, i need somebody with an hour or so to do the actual translation
I'm currently missing the German language. So if any of you could afford to loose an hour or so to translate OCCT, it would be great
All you need is to download a small opensource software to translate OCCT. You can test your translation right on the spot, without any help from me or anybody elseAnd once you're happy, you just send me a mail with a small file (3KB), and that's it, done
There are about 50 strings to translate, most of them being single words - i'm sure any of you can translate it
Thanks alot for your interest and future help !
Jo, wenn wir schon dabei sind, gibts hier gute Grafiker unter uns?
you here wrong, write you question here. But create a own thread:
http://www.forumdeluxx.de/forum/forumdisplay.php?f=20
i am sure that you get some help.
Frag mal BADRAY![]()
