Guter Punkt, ich muss erst mal schauen wie ich die Version auslesen kannFirmware beider Karten gleich?
versuche mal sowas wie "ethtool -i eth0"Guter Punkt, ich muss erst mal schauen wie ich die Version auslesen kann![]()
driver: cxgb3
version: 1.1.5-ko
firmware-version: T 7.12.0 TP 1.1.0
expansion-rom-version:
bus-info: 0000:82:00.0
driver: cxgb3
version: 1.1.5-ko
bus-info: 0000:02:00.0
root@hp03:/home/bodo# iperf3 -c 10.8.20.102
Connecting to host 10.8.20.102, port 5201
[ 5] local 10.8.20.108 port 38820 connected to 10.8.20.102 port 5201
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 1.10 GBytes 9.43 Gbits/sec 0 3.02 MBytes
[ 5] 1.00-2.00 sec 1.09 GBytes 9.39 Gbits/sec 0 3.02 MBytes
[ 5] 2.00-3.00 sec 1.10 GBytes 9.42 Gbits/sec 0 3.02 MBytes
[ 5] 3.00-4.00 sec 1.09 GBytes 9.41 Gbits/sec 0 3.02 MBytes
[ 5] 4.00-5.00 sec 1.10 GBytes 9.42 Gbits/sec 131 2.45 MBytes
[ 5] 5.00-6.00 sec 1.10 GBytes 9.42 Gbits/sec 0 2.75 MBytes
[ 5] 6.00-7.00 sec 1.10 GBytes 9.41 Gbits/sec 0 2.98 MBytes
[ 5] 7.00-8.00 sec 1.10 GBytes 9.42 Gbits/sec 7 1.16 MBytes
[ 5] 8.00-9.00 sec 1.10 GBytes 9.42 Gbits/sec 0 1.73 MBytes
[ 5] 9.00-10.00 sec 1.10 GBytes 9.41 Gbits/sec 3 1.29 MBytes
[ 5] 0.00-10.00 sec 11.0 GBytes 9.41 Gbits/sec 141 sender
[ 5] 0.00-10.00 sec 11.0 GBytes 9.41 Gbits/sec receiver
iperf Done.
root@hp03:/home/bodo# iperf3 -c 10.8.20.102 -R
Reverse mode, remote host 10.8.20.102 is sending
[ 5] local 10.8.20.108 port 38824 connected to 10.8.20.102 port 5201
[ 5] 0.00-1.00 sec 1.09 GBytes 9.40 Gbits/sec
[ 5] 1.00-2.00 sec 1.10 GBytes 9.41 Gbits/sec
[ 5] 2.00-3.00 sec 1.10 GBytes 9.41 Gbits/sec
[ 5] 3.00-4.00 sec 1.10 GBytes 9.41 Gbits/sec
[ 5] 4.00-5.00 sec 1.10 GBytes 9.41 Gbits/sec
[ 5] 5.00-6.00 sec 1.10 GBytes 9.41 Gbits/sec
[ 5] 7.00-8.00 sec 1.10 GBytes 9.41 Gbits/sec
[ 5] 8.00-9.00 sec 1.10 GBytes 9.41 Gbits/sec
[ 5] 0.00-10.00 sec 11.0 GBytes 9.42 Gbits/sec 296 sender
iperf Done.
root@hp03:/home/bodo# iperf3 -c 172.16.2.6
Connecting to host 172.16.2.6, port 5201
[ 5] local 172.16.2.5 port 52718 connected to 172.16.2.6 port 5201
[ 5] 0.00-1.00 sec 778 MBytes 6.52 Gbits/sec 0 3.06 MBytes
[ 5] 1.00-2.00 sec 778 MBytes 6.52 Gbits/sec 0 3.06 MBytes
[ 5] 2.00-3.00 sec 778 MBytes 6.52 Gbits/sec 0 3.06 MBytes
[ 5] 3.00-4.00 sec 778 MBytes 6.52 Gbits/sec 0 3.06 MBytes
[ 5] 4.00-5.00 sec 778 MBytes 6.52 Gbits/sec 0 3.06 MBytes
[ 5] 5.00-6.00 sec 776 MBytes 6.51 Gbits/sec 0 3.06 MBytes
[ 5] 6.00-7.00 sec 778 MBytes 6.52 Gbits/sec 0 3.06 MBytes
[ 5] 7.00-8.00 sec 778 MBytes 6.52 Gbits/sec 0 3.06 MBytes
[ 5] 8.00-9.00 sec 778 MBytes 6.52 Gbits/sec 0 3.06 MBytes
[ 5] 9.00-10.00 sec 778 MBytes 6.52 Gbits/sec 0 3.06 MBytes
[ 5] 0.00-10.00 sec 7.59 GBytes 6.52 Gbits/sec 0 sender
[ 5] 0.00-10.00 sec 7.59 GBytes 6.52 Gbits/sec receiver
iperf Done.
root@hp03:/home/bodo# iperf3 -c 172.16.2.6 -R
Reverse mode, remote host 172.16.2.6 is sending
[ 5] local 172.16.2.5 port 52722 connected to 172.16.2.6 port 5201
[ 5] 0.00-1.00 sec 845 MBytes 7.08 Gbits/sec
[ 5] 1.00-2.00 sec 847 MBytes 7.10 Gbits/sec
[ 5] 2.00-3.00 sec 847 MBytes 7.10 Gbits/sec
[ 5] 3.00-4.00 sec 847 MBytes 7.10 Gbits/sec
[ 5] 4.00-5.00 sec 847 MBytes 7.10 Gbits/sec
[ 5] 5.00-6.00 sec 847 MBytes 7.10 Gbits/sec
[ 5] 6.00-7.00 sec 846 MBytes 7.09 Gbits/sec
[ 5] 7.00-8.00 sec 847 MBytes 7.11 Gbits/sec
[ 5] 8.00-9.00 sec 847 MBytes 7.10 Gbits/sec
[ 5] 9.00-10.00 sec 848 MBytes 7.11 Gbits/sec
[ 5] 0.00-10.00 sec 8.27 GBytes 7.10 Gbits/sec 0 sender
[ 5] 0.00-10.00 sec 8.27 GBytes 7.10 Gbits/sec receiver
iperf Done.
root@hp03:/home/bodo# iperf3 -c 10.8.20.100 -R
Connecting to host 10.8.20.100, port 5201
Reverse mode, remote host 10.8.20.100 is sending
[ 5] local 10.8.20.108 port 47396 connected to 10.8.20.100 port 5201
[ 5] 0.00-1.00 sec 846 MBytes 7.10 Gbits/sec
[ 5] 1.00-2.00 sec 847 MBytes 7.11 Gbits/sec
[ 5] 2.00-3.00 sec 848 MBytes 7.11 Gbits/sec
[ 5] 3.00-4.00 sec 845 MBytes 7.09 Gbits/sec
[ 5] 4.00-5.00 sec 845 MBytes 7.09 Gbits/sec
[ 5] 5.00-6.00 sec 846 MBytes 7.10 Gbits/sec
[ 5] 6.00-7.00 sec 845 MBytes 7.09 Gbits/sec
[ 5] 7.00-8.00 sec 836 MBytes 7.01 Gbits/sec
[ 5] 8.00-9.00 sec 845 MBytes 7.09 Gbits/sec
[ 5] 9.00-10.00 sec 845 MBytes 7.09 Gbits/sec
[ 5] 0.00-10.00 sec 8.25 GBytes 7.09 Gbits/sec 0 sender
[ 5] 0.00-10.00 sec 8.25 GBytes 7.09 Gbits/sec receiver
iperf Done.
[ 5] local 10.8.20.108 port 47400 connected to 10.8.20.100 port 5201
[ 5] 0.00-1.00 sec 737 MBytes 6.18 Gbits/sec 2801 139 KBytes
[ 5] 1.00-2.00 sec 735 MBytes 6.17 Gbits/sec 3097 153 KBytes
[ 5] 2.00-3.00 sec 739 MBytes 6.20 Gbits/sec 2811 181 KBytes
[ 5] 3.00-4.00 sec 740 MBytes 6.20 Gbits/sec 2993 202 KBytes
[ 5] 4.00-5.00 sec 735 MBytes 6.16 Gbits/sec 2781 144 KBytes
[ 5] 5.00-6.00 sec 739 MBytes 6.20 Gbits/sec 2866 156 KBytes
[ 5] 6.00-7.00 sec 737 MBytes 6.19 Gbits/sec 2671 165 KBytes
[ 5] 7.00-8.00 sec 739 MBytes 6.20 Gbits/sec 2546 156 KBytes
[ 5] 8.00-9.00 sec 737 MBytes 6.18 Gbits/sec 2880 146 KBytes
[ 5] 9.00-10.00 sec 743 MBytes 6.23 Gbits/sec 2875 153 KBytes
[ 5] 0.00-10.00 sec 7.21 GBytes 6.19 Gbits/sec 28321 sender
[ 5] 0.00-10.00 sec 7.21 GBytes 6.19 Gbits/sec receiver
iperf Done.
Das Hauptproblem hast Du schon selbst angesprochen: das "Inter-VLAN Routing". Zwischen zwei Subnetzen ist immer der Router gefragt, per best-practice sollte ein VLAN mindestens einem (eigenen) Subnetz entsprechen (oder besser 1 Subnet = 1 VLAN) und spätestens damit hat sich diese "Inter-Vlan-Kommunikation" die Switches meist anbieten, eigentlich erledigt. Mir fällt auch nichts sinnvolles ein, um das einzusetzen. Eine Variante wäre, dass man (z.B.) ein großes (z.B.) /21 Netz aufspannt und dann alles nur noch über VLANs versucht zu regeln. Kommt man halt schnell an die Grenzen.Ich hätte dann auch mal ne Frage an die Netzwerk-Cracks bzgl. Inter-VLAN Routing:
Muss der Verkehr immer über die opnSense laufen oder kann ich das für bestimmte VLANs auf den Switch auslagern?
Ziel wäre die Erhöhung des iSCSI-Durchsatzes, da ich momentan nur eine Single-10GB-Melli in der opnSense drin hab.
Mit Rein-Raus hab ich nur noch 5 GBit...
Sprich statt: Rechner(V10)->SwitchOG(V10)->SwitchK(V10)->FW(V10)->FW(V30)->SwitchK(V30)->NAS(V30)
so: Rechner(V10)->SwitchOG(V10)->SwitchK(V10)->SwitchK(V30)->NAS(V30)
Geht das?
Was muss ich da wo im Switch eintragen?
Sind Probleme zu erwarten?
Ist das das berüchtigte "asymmetrische Routing"?
//Edith:
Switche sind 2x CRS328.
...selbst die uniFi 6 haben nur GBit....SFP+ wird wohl auch nicht so schnell kommen.Moin, wie sind denn die APs von Mikrotik so? Ich bräuchte 2 APs, am liebsten schon WiFi6, die wirklich nur AC spielen, Routing soll dann ein großer Mikrotik zusammen mit einer OPNsense machen. Da WiFi6 durchaus Gigabit an seine Grenzen bringen kann, wäre auch ein SFP+ Port ganz nett - gibt es da was von Mikrotik oder schaue ich da woanders?
Ubiquiti haben sich bei mir komplett durch ihren Cloud-"Zwang" auf die "Don't buy" Liste gesetzt.
Uff. Das ist mir dann für zu Hause dann doch etwas arg teuer.Dann ist sicher ruckus wireless interessant, die R320 / R510 etc. mit unleashed firmware
Huom, das ist mal ein guter Tip! Wäre dann aber der EAP660 HD nicht die bessere Wahl? Unterstützt schon WiFi 6E und kann auch 2,5GBoE. Funktioniert 2,5GBoE denn mit PoE oder ist das dann entweder oder, GB mit PoE oder 2,5GBoE mit Power Adapter? Würde damit (bei 2 APs) Seamless gehen und welcher Mikrotik wäre denn da dann der richtige "Zuspieler"?Schau Dir auch mal die TP-Link Omada Serie an....ich liebäugle gerade mit dem EAP245...interessanter P/L zwischen MT und Unifi.
Aber WiFi 6 gibt es da auch welche, zB https://geizhals.de/tp-link-omada-eap620-hd-a2420664.html?hloc=at&hloc=de
Ich kenne noch keinen PoE-Injektor, der NBase-T kann.Funktioniert 2,5GBoE denn mit PoE oder ist das dann entweder oder, GB mit PoE oder 2,5GBoE mit Power Adapter?
...die Omada Serie benötigt den Controller...Hardware oder Docker/VM....der regelt das Thema Seamless...wobei das immer auch eine Frage des Clients/Client-OS/-Treiber ist.Würde damit (bei 2 APs) Seamless gehen und welcher Mikrotik wäre denn da dann der richtige "Zuspieler"?
