[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
Übertaktet habe ich nicht. Das finale Bios ist ja A80. Davor war ich bei der A82 Beta. Ich bin jetzt nur auf die A7 zurück wegen dieser Voltage Problematik im Idle, um zu sehen, obs am Bios lag. Bin dann wieder auf das A82 zurück nachdem ich bei A7 Instabilität beim zocken hatte. A82 war eigentlich stabil, nachdem ich anstatt XMP die Timings manuell eingegeben hatte +VRAM Voltage und SoC Voltage. Jetzt irgendwie nicht mehr. Und mit der A80 Final verliere ich knapp 200mhz durch die Bank. Davor sah ich boosts auf 5075mhz. Jetzt bestenfalls 4900mhz sporadisch. Hat sonst jemand mit dem finalen Bios Leistung verloren?
Weiß einer was der BSOD IRQL_Not_less_or_equal bedeutet? Irgendwie raucht mein Rechner beim zocken alle 30min ab. Erst waren der Ton zu hören aber Bild eingefroren, dann von A7 wieder auf A82 wo ich keine Probleme hatte bis auf hohe Temperaturen. Aber da hat sich das Spiel wieder ausgehängt. Hab dann die RAM Spannung angehoben und SoC wie ich es schon in der Vergangenheit hatte, aber jetzt wieder mit diesem Fehler ein Absturz. Auf was könnte das hindeuten? Habs gefühl meine cpu ist echt bereits degraded.
Gehe jetzt wieder auf die finale A80 Version und hoffe dass der PC dann läuft. Das Bios hat zwar weniger Performance, aber hoffentlich mehr Stabilität
Bitte wechsel deinen RAM, ich habe auch so lange rumgehampelt und alles mögliche verdächtigt, dachte erst defekte CPU, dann defekten RAM, defektes Brett, inkompatibles Bios etc...
Am Ende waren das die Samsung ICs, die auch bei dir drauf sitzen. Ich hab die Microns eingebaut und seitdem läuft das System Butterweich mit XMP. Nehme das Kit welches ich auch habe, statt 4 Dimms hast du dann 2, hast deine 64GB und da definitiv die gewissheit das es nicht am RAM liegt.
Du ersparst dir damit viel Ärger.
Ja, ich denk schon drüber nach. Aber is halt nur Micron B-Die der sich nicht wirklich übertakten lässt. Samsung wurde bei Ryzen 1000 noch so gelobt. Ich hatte mir damals den 1800x geholt mit dem Ram Kit, weil es immer hieß Samsung B-Die läuft. Schon damals nur Probleme gehabt mit dem Ram. Mit dem 9900k lief er super. Ich hab im Zweitrechner noch Corsair Vengance 3200 CL16. Les ich später mal die Chipgüte aus und teste ihn mit dem Ryzen. Dann schau ich mal weiter. Das System war eigentlich stabil mit der A82 und manuellen Timings. Der Performanceverlust mit dem neuen Bios ist leider auch unabhängig vom RAM. Muss heute noch etwas Stresstesten 😁
Spannung bestimmt nicht hoch genug :-D
Den Regler finde ich bei mir bei Windows gar nicht.
Wer traut sich?^^
Was ist am L3 Cache kaputt? Und wie äußert sich das Problem?
Eben geflasht und L3 Cache läuft wieder normal. ENDLICH gefixt.
Klingt gut, ich warte dennoch auf die finale Version.
Quelle oben hinzugefügt.
Auch das Ace hat das Update bekommen als Beta siehe Beitrag oben.
Zumindest bei denn 5000er CPUs war dieser halbiert, jetzt mit der neuen Beta ist diese wieder normal.
Merkst du im Alltag einen Unterschied oder nur anhand des AIDA64-Cache-Benchmarks?^^
Hier hat sich am L3 nichts geändert mit dem 5950 aber das muss ja nicht bei jedem sein.
Außer vielleicht das er nicht auf 5GHz hochtaktet.
auch wenn die Frage nicht an mich adressiert ist. Hab den Superposition Benchmark auf 720p durchlaufen lassen. Da ist die 3080 zu max 89% ausgelastet und der Benchmark somit im CPU Limit.
Wenn mein Gedankengang richtig ist, müsste durch schnelleren RAM der Score steigen. Bei mir ist er von 48500 auf 48100 gefallen.
Können auch Messtoleranzen oder eine falsche Herangehensweise sein.
Ich glaube das kann man vernachlässigen bzw unter Messtoleranz abhacken.
Hatte schon mal in der Vergangenheit erwähnt das es dort eventuell ein bug gibt, weil diverse Leute komplett unterschiedliche Werte haben und das diese auch Schwanken nur wenn man das System Rebootet.
Danke das ich mal wieder recht hatte :hail::hail::hail:
Das Beta-BIOS ist jetzt auch auf der Produktseite gelistet.
Merkt ihr generell eine Mehrleistung mit dem neuen Beta-BIOS? Sei es bei Programmen oder in Games?
Meine letzten Runden bei Escape from Tarkov waren auf jeden Fall extrem erfolgreich im Vergleich zu vorher. Aber ich bezweifle, dass es am Beta Bios liegt ;)
Aber selbst wenn es mit dem Beta BIOS Mehrleistung gibt, würde ich darauf wetten, dass es keiner in einem Blindtest bemerken würde.
Es wird immer besser und stabiler das ist das Wichtigste.
Servus,
ich bin von Strix Boards ein wenig verwöhnt, dass der Rear und Front Audio Ausgang als zwei Audio Geräte in Windows angezeigt wurden. Sprich ich konnte einfach das Ausgabegerät per Software festlegen und x-beliebig hin und her switchen. Beim Unify kann ich entweder nur simultane Ausgabe über beide Ausgänge oder per manuellen Kopfhörer vorne ab- und anstecken das Ganze lösen. Die Realtek Audio Console von MSI gibt nicht mehr her. Gibt es da ein Trick17 oder muss ich mich damit abfinden?
Ist ein BIOS-Flash auf eine vorige Version immer möglich oder spielt die Version dabei eine Rolle ?
Will aus Stabilitätsgründen das neue Beta-Bios testen, aber evtl. dann auch wieder zurück A70
Warum nimmst du nicht erst mal die final A.80? Abgesehen davon sollte es zumindest via Flash-BIOS jederzeit möglich sein, eine ältere BIOS-Version zu flashen, falls das Board sich mit M-Flash weigern sollte.
Mein Fehler, meinte auch die A80. Ich meine ich hätte irgendwo mal aufgeschnappt, dass ein Flachback bei bestimmten Versionssprüngen nicht geht.
Moin, wie haltet ihr das mit den chipsatz treibern bei am4. Neueste von AMD oder die vom Hersteller?
Ich selbst nutze den Treiber von der AMD-Seite. Dies gilt aber auch für die Treiber der restlichen Komponenten, sprich Direkt-Hersteller bezogen.
Ähnliche Themen
