[Sammelthread] Gigabyte (GA-) Z77X-D3H / UD3H / UDH3-WB WIFI / UD5H / UD5H-WB WIFI / (Z77)
Willkommen im
Gigabyte (GA-) Z77X-D3H / UD3H / UDH3-WB WIFI / UD5H / UD5H-WB WIFI (Z77) - Sammelthread​
xxxInhaltsverzeichnis:
xxxGigabyte GA-Z77X - D3H
Layout:
weitere Bilder:
Spezifikationen:
CPU
1.Support for Intel® Core™ i7 processors/Intel® Core™ i5 processors/ Intel® Core™ i3 processors/Intel® Pentium® processors/Intel® Celeron® processors in the LGA1155 package
2.L3 cache varies with CPU
(Please refer "CPU Support List" for more information.)
Chipset
1.Intel® Z77 Express Chipset
Memory
1.4 x 1.5V DDR3 DIMM sockets supporting up to 32 GB of system memory
* Due to Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than 4 GB.
2.Dual channel memory architecture
3.Support for DDR3 1600/1333/1066 MHz memory modules
4.Support for non-ECC memory modules
5.Support for Extreme Memory Profile (XMP) memory modules
(Please refer "Memory Support List" for more information.)
Onboard Graphics
Chipset: 1.1 x D-Sub port
2.1 x DVI-D port, supporting a maximum resolution of 1920x1200
* The DVI-D port does not support D-Sub connection by adapter.
3.1 x HDMI port, supporting a maximum resolution of 1920x1200
Audio
1.VIA VT2021 codec
2.High Definition Audio
3.2/4/5.1/7.1-channel
4.Support for S/PDIF Out
LAN
1.1 x Atheros GbE LAN chip (10/100/1000 Mbit)
Expansion Slots
1.1 x PCI Express x16 slot, running at x16 (PCIEX16)
(The PCIEX16 slot conforms to PCI Express 3.0 standard.)
* For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
* The PCI Express x16 slot supports up to PCI Express 2.0 standard when an Intel 32nm (Sandy Bridge) CPU is installed.
2.1 x PCI Express x16 slot, running at x8 (PCIEX8)
* The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated, the PCIEX16 slot will operate at up to x8 mode.
3.1 x PCI Express x16 slot, running at x4 (PCIEX4)
* The PCIEX4 slot shares bandwidth with the PCIEX1_1/2/3 slots. The PCIEX1_1/2/3 slots slots will become unavailable when a PCIe x4 expansion card is installed.
4.3 x PCI Express x1 slots
(PCIEX8, PCIEX4 and PCIEX1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slots
Multi-Graphics Technology
1.Support for 2-Way AMD CrossFireX™/NVIDIA SLI technology (PCIEX16 and PCIEX8)
* The PCIEX16 slot operates at up to x8 mode when AMD CrossFireX™/NVIDIA SLI is enabled.
Storage Interface
Chipset: 1.2 x SATA 6Gb/s connectors (SATA3 0/SATA3 1) supporting up to 2 SATA 6Gb/s devices
2.4 x SATA 3Gb/s connectors (SATA2 2~SATA2 5) supporting up to 4 SATA 3Gb/s devices
3.1 x mSATA connector
* The SATA2 5 connector will become unavailable when the mSATA connector is installed with a solid state drive.
4.Support for RAID 0, RAID 1, RAID 5, and RAID 10
* When a RAID set is built across the SATA 6Gb/s and SATA 3Gb/s channels, the system performance of the RAID set may vary depending on the devices being connected.
1 x Marvell 88SE9172 chip: 1.2 x SATA 6Gb/s connectors (GSATA3 6/GSATA3 7) supporting up to 2 SATA 6Gb/s devices
2.Support for RAID 0 and RAID 1
USB
Chipset: 1.Up to 4 USB 3.0/2.0 ports (2 ports on the back panel, 2 ports available through the internal USB headers)
* In Windows XP, the Intel USB 3.0 ports can support up to USB 2.0 transfer speed.
2.Up to 6 USB 2.0/1.1 ports (2 ports on the back panel, 4 ports available through the internal USB headers)
VIA VL800 chip: 1.Up to 4 USB 3.0/2.0 ports on the back panel
* Due to a Windows 7 limitation, please connect your USB device(s) to the USB 2.0/1.1 port(s) before the VIA USB 3.0 controller driver is installed.
Internal I/O Connectors
1.1 x 24-pin ATX main power connector
2.1 x 4-pin ATX 12V power connector
3.4 x SATA 6Gb/s connectors
4.4 x SATA 3Gb/s connectors
5.1 x mSATA connector
6.1 x CPU fan header
7.3 x system fan headers
8.1 x front panel header
9.1 x front panel audio header
10.1 x S/PDIF Out header
11.1 x USB 3.0/2.0 header
12.2 x USB 2.0/1.1 headers
13.1 x serial port header
14.1 x Clear CMOS jumper
15.1 x Trusted Platform Module (TPM) header
Back Panel Connectors
1.1 x PS/2 keyboard/mouse port
2.1 x D-Sub port
3.1 x DVI-D port
4.1 x HDMI port
5.6 x USB 3.0/2.0 ports
6.2 x USB 2.0/1.1 ports
7.1 x RJ-45 port
8.1 x optical S/PDIF Out connector
9.5 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
1.iTE I/O Controller Chip
H/W Monitoring
1.System voltage detection
2.CPU/System temperature detection
3.CPU/System fan speed detection
4.CPU overheating warning
5.CPU/System fan fail warning
6.CPU/System fan speed control
* Whether the CPU/system fan speed control function is supported will depend on the CPU/system cooler you install.
BIOS
1.2 x 64 Mbit flash
2.Use of licensed AMI EFI BIOS
3.Support for DualBIOS™
4.PnP 1.0a, DMI 2.0, SM BIOS 2.6, ACPI 2.0a
Unique Features
1.Support for @BIOS
2.Support for Q-Flash
3.Support for Xpress Install
4.Support for Xpress Recovery2
5.Support for eXtreme Hard Drive (X.H.D)
6.Support for Auto Green
7.Support for ON/OFF Charge
8.Support for Q-Share
9.Support for 3D Power
10.Support for LAN Optimizer (Intelligent optimization network management tool)
Bundle Software
1.Norton Internet Security (OEM version)
2.Intel® Smart Response Technology
3.Intel® Rapid Start Technology
4.LucidLogix Virtu MVP
* Make sure the monitor cable has been connected to the integrated graphics port on the back panel.
Operating System
1.Support for Microsoft® Windows 7/XP
Form Factor
1.ATX Form Factor; 30.5cm x 24.4cm
Remark
1.Due to different Linux support condition provided by chipset vendors, please download Linux driver from chipset vendors' website or 3rd party website.
2.Most hardware/software vendors may no longer offer drivers to support Win9X/ME/2000/XP SP1/SP2. If drivers are available from the vendors, we will update them on the GIGABYTE website.
Links:
- Preisvergleich
- Produktseite / Info beim Hersteller
- Downloads: Bios, Treiber, Handbuch,...
xxxGigabyte GA-Z77X - UD3H
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
4.1 x DisplayPort, supporting a maximum resolution of 2560x1600
Audio
1.VIA VT2021 codec
LAN
1.Atheros GbE LAN chip (10/100/1000 Mbit)
Expansion Slots
(The PCIEX16 and PCIEX8 slots conform to PCI Express 3.0 standard.)
* The PCI Express x16 slots support up to PCI Express 2.0 standard when an Intel 32nm (Sandy Bridge) CPU is installed.
* The PCIEX4 slot shares bandwidth with all PCI Express x1 slots. All PCI Express x1 slots will become unavailable when a PCIe x4 expansion card is installed.
(The PCIEX4 and PCI Express x1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slot
Storage Interface
2.4 x SATA 3Gb/s connectors (SATA2 2~5) supporting up to 4 SATA 3Gb/s devices
Marvell 88SE9172 chip: 1.2 x eSATA 6Gb/s connectors on the back panel supporting up to 2 SATA 6Gb/s devices
USB
Chipset: 1.Up to 4 USB 3.0/2.0 ports (2 ports on the back panel, 2 ports available through the internal USB header)
2.Up to 6 USB 2.0/1.1 ports (available through the internal USB headers)
* Due to a Windows 7 limitation, please connect your USB device(s) to the Intel controlled USB port(s) (located below the RJ-45 LAN port) before the VIA USB 3.0 controller driver is installed.
2.1 x 8-pin ATX 12V power connector
3.1 x PCIe power connector
4.2 x SATA 6Gb/s connectors
5.4 x SATA 3Gb/s connectors
6.1 x mSATA connector
7.1 x CPU fan header
8.4 x fan headers
9.1 x front panel header
10.1 x front panel audio header
11.1 x S/PDIF Out header
12.3 x USB 2.0/1.1 headers
13.1 x USB 3.0/2.0 header
16.1 x power button
17.1 x reset button
18.1 x Clear CMOS button
19.1 x Voltage Measurement Points
20.1 x BIOS Switch
2.1 x D-Sub port
3.1 x DVI-D port
4.1 x optical S/PDIF Out connector
5.1 x HDMI port
6.1 x DisplayPort
7.2 x eSATA 6Gb/s connectors
8.6 x USB 3.0/2.0 ports
9.1 x RJ-45 port
10.6 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
5.Support for EasyTune
* Available functions in EasyTune may differ by motherboard model.
6.Support for eXtreme Hard Drive (X.H.D)
7.Support for Auto Green
8.Support for ON/OFF Charge
9.Support for Q-Share
10.Support for 3D Power
11.Support for LAN Optimizer (Intelligent optimization network management tool)
Bundle Software
2.Intel® Rapid Start Technology
3.Intel® Smart Connect Technology
4.Intel® Smart Response Technology
5.LucidLogix Virtu MVP
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD3H - WB WIFI
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
Audio
1.VIA VT2021 codec
LAN
Expansion Slots
5.1 x PCI slot
Storage Interface
USB
8.4 x fan headers
16.1 x power button
17.1 x reset button
20.1 x BIOS Switch
2.1 x D-Sub port
3.1 x DVI-D port
5.1 x HDMI port
6.1 x DisplayPort
9.1 x RJ-45 port
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD5H
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
4.1 x DisplayPort, supporting a maximum resolution of 2560x1600p
Audio
1.Realtek ALC898 codec
2.Support for X-Fi Xtreme Fidelity® and EAX® Advanced HD™ 5.0 technologies
3.High Definition Audio
4.2/4/5.1/7.1-channel
5.Support for S/PDIF Out
LAN
1.1 x Atheros GbE LAN chip (10/100/1000 Mbit) (LAN1)
2.1 x Intel GbE LAN chip (10/100/1000 Mbit) (LAN2)
Expansion Slots
* The PCIEX4 slot is available only when an Intel 22nm CPU is installed.
* The PCIEX4 slot shares bandwidth with the PCIEX8 and PCIEX16 slots. When the PCIEX4 slot is populated, the PCIEX16 slot will operate at up to x8 mode and the PCIEX8 will operate at up to x4 mode.
(The PCIEX16, PCIEX8 and PCIEX4 slots conform to PCI Express 3.0 standard.)
(All PCI Express x1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slot
1.Support for AMD CrossFireX™ / NVIDIA SLI technology
Storage Interface
2 x Marvell 88SE9172 chips: 1.3 x SATA 6Gb/s connectors (GSATA3 6/7/8) supporting up to 3 SATA 6Gb/s devices
2.1 x eSATA 6Gb/s connector on the back panel supporting up to 1 SATA 6Gb/s device
3.Support for RAID 0 and RAID 1
USB
Chipset: 1.Up to 2 USB 3.0/2.0 ports (available through the internal USB headers)
Chipset + 2 VIA VL810 Hubs: 1.Up to 8 USB 3.0/2.0 ports (4 ports on the back panel, 4 ports available through the internal USB headers)
* In Windows XP, the Intel USB 3.0 ports and VIA VL810 HUB can support up to USB 2.0 transfer speed.
* Due to a Windows 7 limitation, please connect your USB device(s) to the USB 2.0/1.1 port(s) before the Intel USB 3.0 controller driver is installed.
IEEE 1394
VIA VT6308 chip: 1.Up to 2 IEEE 1394a ports (1 port on the back panel, 1 port available through the internal IEEE 1394a header)
4.5 x SATA 6Gb/s connectors
8.4 x system fan headers
12.3 x USB 3.0/2.0 headers
13.2 x USB 2.0/1.1 headers
16.1 x power button
17.1 x reset button
19.1 x heatsink LED power connector
20.1 x BIOS Switch
21.Voltage Measurement Points
1.1 x D-Sub port
2.1 x DVI-D port
3.1 x optical S/PDIF Out connector
4.1 x HDMI port
5.1 x DisplayPort
6.1 x eSATA 6Gb/s connector
7.4 x USB 3.0/2.0 ports
8.2 x USB 2.0/1.0 ports
9.1 x IEEE 1394a port
10.2 x RJ-45 ports
11.6 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD5H - WB WIFI
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
Audio
LAN
Expansion Slots
5.1 x PCI slot
Storage Interface
USB
IEEE 1394
16.1 x power button
17.1 x reset button
20.1 x BIOS Switch
1.1 x D-Sub port
2.1 x DVI-D port
4.1 x HDMI port
5.1 x DisplayPort
10.2 x RJ-45 ports
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxWeitere Infos und nützliche Links:
Infos:
Per Software (Speedfan) regelbare Lüfteranschlüsse: (über ITE IT8728)
Sys_Fan1: Ja
Sys_Fan2: Nein
Sys_Fan3: Nein
Sys_Fan4: Nein
CPU_Fan: Ja
Links:
- Gigabyte Z77 motherboards shown off at CES
- Die offiziellen Z77 Pressenews aus dem Gigabyte Forum
- GIGABYTE CeBIT 2012 Highlight
xxxKompatibilität Arbeitsspeicher:
xxxKompatibilität CPU Kühler:
Liste mit passenden Lüftkühler:
- Noctua NH-D14 (Sockel 775/1155/1156/1366/AMD/AM2/AM2+/AM3/AM3+/FM1)
- Phanteks PH-TC14PE (Sockel 1155/1156/1366/AM2/AM3) alle Richtungen montierbar
- Prolimatech Genesis Kühlkörper (Sockel 775/1155/1156/1366/AM2/AM2+/AM3/AM3+/FM1) / überdeckt den 1 PCIe Slot / RAM-Höhe beachten!
- Thermalright True Spirit 140 (Sockel AM2/AM2+/AM3/775/1155/1156/1366) verdeckt nicht den 1.Slot
Liste mit passenden Wasserkühler:
- So wie ich das bei meinem UD5H sehe, kann man den Heatkiller 3.0 wieder in allen Richtungen beim Z77X montieren. Beim Gigabyte Z68X waren ja Kondensatoren im Weg!
xxxReviews / Unboxing:
xxxSupport JZ electronic:
Infos:
- Einstellung Lüftersteuerung:
Links:
- BIOSe und News von JZ electronic
Gruß -Elle-
Ich hab auch nur die Vcore geändert und alle anderen Werte so gelassen - 4.6Ghz @ 1.248 waren so locker drin.
Vom Farbthema finde ich die cool ... aber diese Totenköpfe, Patronen und Magazine sehen doch lächerlich aus. Bei einem der Boards ist auch eine Pistole als Kühler. :fresse: Sieht völlig Banane aus.
Hi Leute,
ich durchlebe gerade viel Leiden mit meinem P8Z77-V und bin kurz davor, es zurückzuschicken, weil sonst die 14 Tage seit der Lieferung abgelaufen sind. In aller Kürze: Win 7 Install im AHCI Modus geht nur im UEFI Boot, nicht per Legacy. Der LAN Anschluss geht mal und mal nicht, es ist gerade zu lottowürdig, ob ich ins Netzwerk darf oder nicht. Mehr Infos hier: http://www.hardwareluxx.de/communit...t-treiber-geht-nicht-891775.html#post18910044
Kannst du das bitte näher ausführen?
Habe die selben Probleme mit meinem UD5h - allerdings nur beim Intel LAN ANschluss. 1 Monat lang lief alles super, dannach hatte man nur noch ne 50/50 Chance, dass der Lan Anschluss funktioniert (wird im Intel Treiber und in der Systemsteuerung als "disabled" angezeigt - obwohl er im UEFI enabled ist). Ein Reboot fixt das Problem in 40-50% aller Fälle (wenn man Pech hat kann man aber auch 4-5 mal booten, ohne dass es geht). Extrem nervig, ich ging bisher daher von einem "Teildefekt" aus, insbesondere da es ja 1 Monat problemlos lief.
Die besagte Fritzbox Einstellung "Immer an" brachte bei mir keinerlei Besserung, das Problem besteht nach wie vor.
Leider war das mit der FritzBox bei mir genau die Lösung.
Zusätzlich wird im unten verlinkten Thread noch empfohlen den "den intel MEI treiber und den neuesten intel 17.1 lan treiber" zu installieren. Das habe ich vorher auch gemacht, brachte aber keine Abhilfe. Erst das FritzBox Settings löste mein Problem.
http://www.hardwareluxx.de/communit...82579v-gigabit-treiber-geht-nicht-891775.html
Z77X-UDH3 - erster Eindruck
Bin neu hier, Grüße ins Forum !
Ersteindruck vom Gigabyte Z77X-UDH3, gekauft weil günstiges Z77-Board mit DisplayPort, ein Asus wollte ich diesmal nicht nehmen, deren Modelle in der untersten Preisklasse empfand ich nicht als echte Alternative.
Ausgeliefert mit F5 Bios, aktualisiert auf F9, CPU ist ein i7-3770K. Anwendungsgebiet ist bei mir v.a. BOINC, ich rechne für diverse Projekte zur Krankheitsforschung und Medikamentensuche und wollte mir einen sparsamen Rechner für Vollast-Betrieb zusammenstellen. Mit der Option sehr sparsamen Idle-Stromverbrauch zu haben, falls der Rechner mal Urlaub braucht. Oder einfach mal leise sein soll ohne Lüfterlärm.
- Board Z77X-UDH3 (ATX)
- CPU i7-3770K, einfacher 3x Heatpipe Kühler
- RAM Kingston LoVo 2x4 GB DDR3
- Festplatte 750 GB SATA
- Netzteil 625 Watt 80 plus
- Gehäuse mit 1x 80mm (Festplatte) und 1x 120 mm (Höhe CPU-Kühler)
Also nichts Besonderes, minimale Bestückung, der Rechner läuft nicht 24/7, aber doch einige Stunden am Tag, wird aus Ruhezustand aufgeweckt, weil manche BOINC-Projekte keine Checkpoints durchführen. Die CPU ist aktuell auf Multi 44 bei 1.225 Volt getaktet, Turbo ist deaktiviert, HT aktiv, Intel Energiezustände sind aktiv, RAM @1600MHz, der Stabilität wegen auf 1.5 statt 1.35 Volt, Idle-Verbrauch 28 Watt, Vollast z.Zt. auf 85-90 Watt (gesamtes System, ohne Monitor), Temperaturen ~70 Grad, fallen beim Anhalten von BOINC in 10 Sekunden auf ~40 Grad, die Verbrauchsanzeige schwankt jedoch zwischen den diversen BOINC-Projekten. Prime95 oder POVRay nehmen z.B. exakt 100 bzw. 102 Watt für Torture Test/Blend bzw. Benchmark/All CPUs.
Die iGPU (HD4000) soll nach Eintragung in BOINC Hardwareerkennung für OpenCL-Rechenprojekte verwendet werden, sie unterstützt OpenCL 1.1 und hat genügend Leistung für Albert@home u.ä. Übertaktbarkeit der iGPU habe ich getestet, das funktioniert, unter erhöhtem Stromverbrauch, plus 400Mhz nehmen 20 Watt mehr bringen 20 Prozent mehr 3DMark-Punkte (P1020), die Relation ist meiner Meinung nach i.O.
Zum Gigabyte UDH3: die Lüfterkontrolle funktioniert hervorragend, Montage von CPU-Kühler war kein Problem, die inneren RAM-Steckplätze liegen jedoch etwas nah dran am CPU-Socket, bei Vollbestückung müsste ich niedrige Module wählen, die Software "EasyTune6" ist optisch ein Graus, der CPU-Reiter zeigt die Feldeinträge verzerrt und unlesbar an, "Tuner" bietet drei Profile (die ich getestet habe) und ein "AutoTuning", das ich ebenfalls waghalsig ausprobiert habe. Es funktioniert ohne Blessuren. :fresse2:
- 4,18 Ghz ergaben 7,37 Cinebench-Punkte (108 Watt max. Verbrauch)
- 4,43 Ghz ergaben 7,67 Cinebench-Punkte (dito, 108 Watt max. Verbrauch)
- 4,68 Ghz resultierte im Absturz im Cinebench (125 Watt max. Verbrauch, soweit zeigte das Messgerät noch)
Das Autotuning in ET6 prüfte zunächst die Multiplikatoren 43, 44, 45, 46, Absturz bei 47. Danach Fortsetzung mit Multiplikator 46 und BCLK 104, dann 43/103,5, dann 46/104,6, zuletzt gestartet hat der Rechner demzufolge mit 4,812 GHz, jedoch unter hoher Spannung, über 1,32 Volt. Kam natürlich nicht in Frage. Habe mit von unten herangetastet, Undervolting und Underclocking mit 0.800/0.900 Vcore für Multi 30 begonnen, so ein System läuft stabil mit 42 Watt im Cinebench (3.01 Punkte). Die Zwischenwerte für diverse Multi-Einstellungen und VCore erspare ich euch, die hängen natürlich von der jeweiligen CPU ab. Für eine "gute" Übertaktung habe ich Multi 40 gefunden bei 0.850/1.10 Vcore, das bringt 6,24 Cinebench-Punkte bei 60 Watt Gesamtverbrauch., entspricht in etwa der Standard-Taktung mit Turbo. Turbo war in allen meinen Settings abgeschaltet.
Mit dem Gigabyte Board bin ich soweit zufrieden, ohne in die Tiefe aller Parameter gehen zu müssen, ist ein schnelles Optimieren auf gewünschte Zielwerte machbar. Toleranzen für stabilen Betrieb der sensiblen Berechnungen unter BOINC benötige ich zwingender als 1-3 Watt Stromeinsparung an der Stabilitätsgrenze. Hyperthreading ist unter BOINC eine interessante Möglichkeit, die Effizienz zu steigern, zwar verlangsamt es die Berechnung der Workunits, hebt aber in Summe die Rechenleistung pro eingesetztem Watt an. Leider auch die erforderliche VCore, so meine Beobachtung. Bei der Projektwahl muss ich etwas aufpassen, weil 8 GB etwas wenig sind bei anspruchsvollen Workunits, siehe bspw. WCG Systemanforderungen, da kommen bei 8 Threads leicht über 8 GB zusammen.
Mein Fazit für das Z77X-UDH3:
++ DisplayPort
+ BIOS-Optionen für Undervolting/Overcocking
+ Lüfter-Ansteuerung PWM/Voltage - 4Pin und/oder 3Pin (Mischbetrieb möglich)
+ Board Layout (insgesamt, Position der SYS Fan, Features für Power-ON, CMOS Clear, BIOS Switch, Messpunkte Spannung :))
+ flache Kühlkörper - keine fingermordende Gebirgslandschaften
+ Details wie mSATA, SLI und Crossfire (für spätere Nutzung in meinem Fall)
+/- Preis-Leistung (ein gewöhnliches Z77-Board mit DisplayPort, das hätte günstiger angeboten werden können)
+/- Debug LED Codes, sicherlich hilfreich für die Fehleranalyse, wer´s richtig macht, braucht sowas nicht: nice to have
- Software ET6, nicht mal die Grundversorgung mit Daten zur CPU und der Eckwerte ist brauchbar
- USB-Versorgung nicht zuverlässig (Beispiel Tastatur beim Booten) - liegt´s an der USB 3.0 Spezifikation ?
- UEFI-BIOS nicht hunderprozentig verlässlich, geladene Profil-Werte werden nicht sofort angezeigt, Neustart erforderlich
() Autotuning wie zu erwarten nicht zu empfehlen, kein Punktabzug
Manchmal geht im BIOS die Umschaltung auf Deutsch nicht, bei instabilem Betrieb, ausgerechnet Undervolting, hat man wenige Sekunden, um Änderungen zu machen, sonst Freezes. Klar, per Switch kann man jederzeit auf ein funktionierendes BIOS zurückgreifen. Oder per CLEAR-Taster auf dem Board zurücksetzen, die notwendigen Eingaben sind schnell gemacht und die Struktur ist logisch aufgebaut. Einzig - von anderen Herstellern kenne ich das anders, superstabil im BIOS. Entweder es geht alles oder es bootet erst gar nicht. UEFI ist irgendwie nicht mein Ding, brauche auch keine Maus, Direkteingabe der Werte mit OK genügt, das macht das Gigabyte. Steht man zu lange auf "-" oder "+" Taste, springen die Werte auf den Ersteintrag und dieser Vorgang verursachte (bei mir) Freezes. Das ist meiner Meinung Schlamperei. Wohlgemerkt nicht bei OC-Einstellungen, sondern bereits bei den ersten Versuchen unter Standard-Werten. Eine kuriose Konstellation hatte ich bei Tests mit Turbo-Werten, waren Turbo-Übertaktungen aktiv, sprang die Taktanzeige in der Systemübersicht auf den Turbo-Wert, zeigt nicht den CPU-Grundwert, das ist irreführend, man muss in den Frequenz-Einstellungen stets kontrollieren, was nun eingestellt ist. Mit Turbo musste ich die Spannungswerte höher stellen als den Grundwert per Multiplikator zu setzen. O.k., da fehlt mir die Erfahrung.
Vielleicht kann ich die gebotene Leistung nicht hoch genug schätzen, weil mir die "Extras" derzeit kaum nutzen. Overclocking ist in meinem Falle Pflicht, um die Effizienz für DC-Leistung zu erhöhen, der Aufpreis für den K-Prozessor ist schon hoch genug. :rolleyes: Sehr störend, dass ich meine USB-Stromversorgung vom Monitor nicht mehr nutzen kann, dort waren bisher Tastatur und Maus eingesteckt und ein USB-Kabel ans Mainboard reichte, um diese zwei Abnehmer (1) zu versorgen und (2) beim Bootvorgang zu erkennen, d.h. zeitnah nutzen zu können. Beim Gigabyte hatte ich Komplettausfälle, Tastatur musste ich neu stecken, sogar nach Standby/Ruhezustand. Da sollte unbedingt nachgebessert werden, meine Cherry-Tastatur funktioniert sonst immer. :(
Für Spieler ist das UDH3 bestimmt interessanter, sowohl was OC als auch SLI/Crossfire angeht. Für mich zählt mehr das Layout für optimale Lüfteranbindung und ein "schlankes" Design ohne störende Kühlrippen. Was mir bei Installation positiv auffiel, war die sehr leise Lüfteransteuerung von Haus aus. So muss das sein.
Problemloses Übertakten auf +900 Mhz ist für hardcore Overclocker wahrscheinlich ein Witz, die kaufen aber eher höherwertige Boards, das Ganze über 3-4 Änderungen zu realisieren ist traumhaft komfortabel, +1000 auf 4,5 Ghz sind mit etwas mehr Spannung machbar, noch mehr mit viel Feintuning, doch da stimmen (für mich) nicht die Relation Zeitaufwand zu Ergebnis. Zumindest bei meiner CPU, die wohl nicht zur besten Selektion gehört. Obwohl ich einen 20-Euro Kühler verwende, der jedoch in Prozentschritten anpassbare Lüftersteuerung hat, kann das System den "hitzigen" IB-Prozessor problemlos kühlen. Mein Temp-Niveau wird vermutlich die OCer erschrecken, aber TJMax ist ein weiter Ferne, nur für ein paar Grad weniger kaufe ich mir kein Kilo Kupfer, bei mir darf die CPU einfach heißer werden. Semi-passiv lag ich übrigens über 100 Grad, hüstel. Die Vorteile beim Stromverbrauch sind mir die Mehrkosten für IB statt SB (z.B. 2500K) wert, die hole ich über die laufenden Kosten wieder heraus. Die Mehrkosten für 3770K zu 3570K für Hyperthreading hole ich evtl. nicht so schnell heraus. Egal, das Gefühl alles für Effizienz getan zu haben, befriedigt. So rational darf man Komponentenkauf nicht angehen. :coolblue:
Mit einem Z77-Board, CPU inklusive taktbarer iGPU und insgesamt bezüglich Stromverbrauch sehr variabel konfigurierbaren System fehlt mir kaum etwas zum Glück. Das Gigabyte UDH3 passt da gut hinein, preislich am unteren Ende mit DisplayPort, stabiler Betrieb mit etwas Spannungserhöhung, der Sommer kann kommen, die o.g. Settings mit 60 Watt Vollast-Betrieb unter Multiplikator 40 sind notiert und werden ggf. bei Sommertemperaturen genutzt. Intel hat mit Ivy Bridge für meine Anforderungen ein hervorragendes Produkt auf dem Markt, die K-Modelle bieten Leistung ohne Ende & ohne Schmerzen beim Stromverbrauch oder erforderliche Nachrüstungen für Kühler.
Hoffe, ihr konntet etwas mit meinen Erfahrungswerten zum Gigabyte anfangen. Solange es ohne Probleme läuft, können mir Problemchen des BIOS gestohlen bleiben und dieser Ärger ist dann schnell vergessen.
Kommentare sind willkommen. :wink:
Herzlich willkommen und was für ein Einstandsbeitrag, alter Schwede.
Bzgl. der Uefi Probleme: Gb hat ein Jahr Rückstand auf Asus und Asrock. Die müssen offenbar noch etwas üben. JZ ist aber dran...
trader2,
kannst du das vielleicht etwas erklären? Würde mich interessieren warum das so ist.
Warum Gb die in diesem Thread aufgeführten Uefi-Probleme hat, können Dir nur die verantwortlichen Progger sagen.
Bei Neuerungen bedarf es traditionell eines Lernprozesses, wobei dieser bei der hier ebenfalls häufiger angesprochenen USB-Problematik wohl dauerhafter Natur zu sein scheint.
Deswegen warte ich mit dem Kauf einer neuen Serie auch immer min. 2-3 Monate ab.
Hab jetzt ne USB-Fehlermeldung bekommen:
hab meinen Drucker ( USB 2.0 Drucker ) am USB 3.0 Anschluß angeschlossen. Als die Meldung erschien, war er allerdings ausgeschaltet und vorher hatte ich diese Meldung noch nie.
Könnt Ihr damit was anfangen und mir weiterhelfen ?
Vielleicht sollte ich doch mal den USB 3.0 Treiber installieren? :) Wo finde ich den aktuellsten Treiber, bei GB ?
@ ivybonic - schöner Bericht. Hab ähnliche Erfahrung gemacht, bin schwer zufrieden mit dem Board. Das einzige Problem was ich hatte das meine Samsung F3 1TB nicht richtig erkannt wurde bzw. Probleme bereitet - hab eine neue Firmware auf die Platte installiert jetzt läuft alles. Trotz Neuland UEFI hab ich mich recht schnell zurechtgefunden - Klasse Board.
...habe biose besorgt für Logitech & Corsair USB Fix :-)
GA-Z77X-UD3H - BetaBIOS F11a
G1.Sniper M3 - BetaBIOS F7a
download bei mir auf der page :-)
Sehr gute Arbeit JZ_
Weißt Du evtl. wann es ein neues empfehlenswertes BIOS für das UD5H geben könnte ?
ist das board so problematisch wie es hier aussieht???
ich wollts mir eigentlich holen, dann bin ich auf den thread hier gestoßen.
Hab´s mir heruntergeladen, wenn der USB-Fix auch mir hilft, wär das klasse, testen kann ich erst in ein paar Tagen, es läuft eine 55h-Workunit. Bin aber gespannt, was andere BIOS-Tester zu berichten haben.
Das UEFI ist derzeit eine ziemlich Baustelle, wenn du es genau wissen willst.
Hinzu kommt noch das GB immer mal wieder den USB Keyb/Maus Support (sehr gerne Logitech Keyb.) wegpatched (warum auch immer).
Die Boards laufen sonst perfekt stabil, es sind nur winzige Dinge die einfach extrem nerven.
Du kannst beruhigt zum UD3H z.b. greifen, nur halte einfach ne PS2 Tasta bereit für den Fall der Fälle ^^
also ich habe nur probleme mit c3 c6 ,aber es ist mit dem neuen bios aufjedenfall besser geworden obs weg ist ,das bringt die zeit mit sich
Finde, es liest sich toll, dass der Hersteller etwas anzubieten hat für die Problemlösung. Die 77er Boards sind allesamt nur wenige Wochen alt, die CPUs eher seit kürzerer Zeit im Handel, d.h. die festgestellten Fehler kommen jetzt erst richtig auf. Weil die Käufer jetzt die Hardware behalten und nicht stante pede zurückschicken. O.k. manche Käufer wollen nicht für Gebrauch kaufen, sondern austesten. :rolleyes:
Bei einem "guten" Hersteller und Preisniveau des Modells erwarte ich entsprechenden Support. Die in großer Menge abverkauften Mainboards der Mittelklasse genießen m.E. den besten/schnellsten Support, was die Bereitstellung von Treibern oder Updates angeht. Abseits von den Massen-Modellen zu kaufen birgt das größere Risiko.
Mir hätte ein günstiges Z75/H77-Board gereicht, im mATX-Format, wenn die Multiplikatorsperre für K-Modelle deaktivierbar wäre, bei den Z77ern steigen die Chancen Stabilität unter fortgeschrittenen OC-Bedingungen zu erhalten mit dem Preis und der Fertigungsqualität in dieser Zielgruppe von Käufern. Aber je mehr Features auf dem Board, umso größer die Zahl der Baustellen und etwaige Fehler/Probleme.
Ich denke nicht, dass Oberklasse-Boards aus diesen Gründen unproblematischer sind, sind die Stückzahlen zu gering fehlt es an Ressourcen in kürzester Zeit Problemlösungen parat zu haben, weil der Gewinn meiner Meinung nach nicht in den Premium-Modellen gemacht wird. Tauchen aber Fehler bei den Massen-Modellen auf, wird schneller reagiert, weil sonst zu schnell Marktanteile wegbrechen.
Boards für Ivy Bridge werden jetzt gekauft. Wer abwarten kann, kann sich die Rosinen rauspicken (höhere Revisionsnummern). Aber darüber lamentieren, dass die aktuellen Boards (noch) Fehler haben, ich weiß nicht.
Ich gebe dir recht ,nur wenn du das haben möchtest ,dann kaufe dir ein Auto und keine Hardware ,ist leider so ,ich hatte noch nie Hardware als sie aufn Markt gekommen ist ,das sie auch komplett fehlerfrei war
Hackslash, schon Gelegenheit gehabt das F11a zu testen?
