MSI Big Bang XPower II (MS-7737)
LGA2011 / Intel X79
Produktlink: MSI Big Bang Xpower II | MSI Microsite
Preisvergleich: MSI Big Bang XPower II (gelistet ab 360,- Euro, Stand 12.01.2012)
Spezifikationen & Ausstattung
- Processor Support
- LGA 2011 Socket
- Second Generation Core i7 Models
- Chipset
- Intel X79, PLX PEX8608, ASMedia ASM1480
- Memory Support
- 8x DDR3 DIMM, bis zu 128GB
- DDR3-1066 / 1333 / 1600 / 1866 (OC) / 2133 (OC) / 2400 (OC)
- XMP Profiles
- Quad Channel
- Networking
- Intel 82579V GbE LAN (10/100/1000)
- Intel 82574L GbE LAN (10/100/1000)
- IEEE 1394 (Firewire)
- VIA VT6315N
- 1x IEEE 1394 extern (Backpanel)
- 1x IEEE 1394 intern
- Audio
- Creative Soundblaster X-Fi MB2 (Realtek
ALC892ALC898) - 8 Channel HD Audio & Jack Sensing
- EAX Advanced HD 5.0
- THX TruStudio Pro
- SATA
- 4x SATA-II (SATA3~6, Intel X79)
- 2x SATA-III (SATA1~2, Intel X79)
- 4x SATA-III (SATA7~10, ASMedia 1061)
- RAID
- Intel Matrix Storage Technology (SATA1~6)
- Modes: AHCI, RAID 0 / 1 / 5 / 10 (Intel X79)
- USB 3.0
- 1x USB 3.0 intern (NEC D720200)
- 4x USB 3.0 extern (NEC D720200)
- Multi-BIOS II
- 2+1 Chips (1x socketed), graphical UEFI (Click BIOS II)
- Windows Interface
- Form Factor
- XL-ATX
- 345mm x 264mm ( L x W )
Connectors & Buttons
- Back panel
- 1x PS/2 Keyboard / Mouse
- Clear CMOS Button
- 1x Coaxial S/PDIF-Out
- 1x Optical S/PDIF-Out
- 1x IEEE 1394
- 4x USB 3.0
- 6x USB 2.0
- 2x RJ45
- 6x Audio
- On-Board
- 3x USB 2.0 Pin Header
- USB 3.0 Pin Header
- IEEE 1394 Pin Header
- Chassis Intrusion
- S/PDIF-Out (3pin)
- Front Panel Audio
- Debug LED
- Voice Genie connector (optional)
- MultiConnect Panel connector (optional)
- Power button
- Reset button
- OC Genie button
- Multi BIOS button
- Base clock buttons
- Over-Voltage Switch
- Voltage Check Point Set
- 4x PCI-E CeaseFire Switches
- 1x Multi-BIOS Button
- 1x OC Genie Button
- 1x Reset Button
- 1x Power Button
Mainboard - schematisch
Backpanel
Features (Links werden nachgetragen)
- Nvidia 4-Way SLI (Anbindung: 16+8+8+8 PCIe 3.0 Lanes, Quelle: Preisvergleich)
- AMD Quad CrossfireX (Anbindung: 16+8+8+8 PCIe 3.0 Lanes, Quelle: Preisvergleich)
- MSI APS (Active Phase Switching)
- MSI Winki 3 (Quick Boot OS, feat. Browser, Messenger, Office, Backup...)
- MSI OC Dashboard
- MSI OC Genie II (CPU & Memory)
- MSI V-Switch (Overvoltage Switch)
- MSI PCIe CeaseFire Switch (PEG Control, Disable/Enable)
- MSI Super Charger (bis zu 1.5A, iPhone, iPad, Smartphones, auch in S1/3/4/5)
- MSI Superpipe (8mm Heatpipe)
- MSI Control Center II (feat. Instant OC)
- MSI Military Class II (Microsite)
- getestet nach MIL-STD-810G
1) Temperature Shock Test – MIL-STD-810G Method 503.5
2) Humidity Test - MIL-STD-810G Method 507.5
3) Vibration Test - MIL-STD-810G Method 514.6
4) Low Pressure test - MIL-STD-810G Method 500.5
5) High Temperature Test - MIL-STD-810G Method 501.5
6) Low Temperature Test - MIL-STD-810G Method 502.5
7) Shock Test - MIL-STD-810G Method 516.6 - Next-Gen DrMOS
- Renesas 20655 Driver Mosfets
- 22x Phasen für CPU
- maximale Belastbarkeit ~ 770 Watt
- Super Ferrite Chokes (SFC)
- Tantalum Hi-C Caps (CPU, Memory, PCH)
- Aluminium Solid Caps (restliches Board)
- Phase LED (for CPU, Memory, PCH, VTT, SA)
Lieferumfang & Zubehör
- Datenträger Treiber & Utilities
- Handbuch (PDF-Download)
- Software Application Users Guide
- Quick Installation Guide
- Quick Reference Guide
- 6x SATA cables
- I/O Shield
- V-Check Probes
- USB3 Slotblende, Front-USB3 Adapter
- eSATA Dual Slotblende (mit 2x eSATA Stromkabel)
- 3x SLI-Bridges (ein mal extra lang)
- CrossFireX Brücke
- M-Connector
- MSI X79 Overclocking Guide
Click BIOS / UEFI (Updates, Einstellungen, Bilder)
Updates: MSI Downloads
BETA Thread @ MSI-Forum: BETA-UEFI/BIOS-Versionen [E7737IMS.1xx-Releases]
Verfügbare Spannungseinstellungen:
Optik
- Live Update: Setup
- BIOS 1.0 - 2011-12-29 (Download)
- BIOS 1.1 - 2012-02-01 (Download)
- BIOS 1.2 - 2012-02-14 (Download)
- BIOS 1.3 - 2012-04-13 (Download)
- BIOS 1.4 - 2012-08-21 (Download)
- BIOS 1.5 - 2012-10-16 (Download)
- BIOS 2.1 - 2013-02-21 (Download)
- BIOS 2.2 - 2013-04-02 (Download)
- BIOS 2.3 - 2013-08-02 (Download)
- BIOS 2.4 - 2013-09-18 (Download)
- BIOS 2.6 - 2013-12-23 (Download)
- BIOS 2.7 - 2014-02-17 (Download)
- BIOS 2.8 - 2014-12-16 (Download)
- CPU Core Voltage
- System Agent Voltage (SA)
- CPU I/O Voltage
- CPU PLL Voltage
- DDR CH_A/B Voltage
- DDR CH_C/D Voltage
- DDR CH_A CA Vref Voltage
- DDR CH_B CA Vref Voltage
- DDR CH_C CA Vref Voltage
- DDR CH_D CA Vref Voltage
- DDR CH_A DQ Vref Voltage
- DDR CH_B DQ Vref Voltage
- DDR CH_C DQ Vref Voltage
- DDR CH_D DQ Vref Voltage
- PCH 1.1 Voltage
- PCH 1.5 Voltage
Optik
Reviews, News, Links
WWW Reviews
1) Hardware Heaven
2) Guru3d
3) Vortez
4) Overclockers
5) tbreak
6) Anandtech
7) Legit Reviews
8) Xbit Labs
9) Hardware.Info (Vergleichstest)
Hardwareluxx News: MSI veröffentlicht X79-Mainboard "Big Bang Xpower II"
Wichtige Links ( HardwareLUXX )
- http://www.hardwareluxx.de/communit...rds-news-reviews-specs-bilder-x79-811617.html
- http://www.hardwareluxx.de/communit...-bridge-e-sockel-2011-laberthread-851887.html
- http://www.hardwareluxx.de/communit...ead-kein-frage-oder-quatschthread-852122.html
- http://www.hardwareluxx.de/communit...ckel-2011-faq-infos-auf-seite-1-a-846301.html
Kompatibilitätslisten
1) CPU-Kühler
2) Arbeitsspeicher
3) Gehäuse (weitere Vorschläge willkommen!)
Update: 08/2011 (aus dem Sammelthread / User-Review vom Big Bang Marshal)
Achtung: Alle Angaben ohne Gewähr.
- Corsair H100 (Review: Vortez)
- Noctua NH-D14 SE2011 (User: Dragon667)
- Phanteks PH-TC14PE (User: DragonClaVV)
- Wakühler: MSI XpowerII XSPC WaterBlock Set (14541) @ Aquatuning
- INKOMPATIBEL Prolimatech Armageddon (User: Dragon667 - kolidiert mit Kühlkörpern)
- INKOMPATIBEL Zalman CNPS 12X (User: Mac78 - kolidiert mit Kühlkörpern)
2) Arbeitsspeicher
- 16GB G.Skill RipJawsZ DDR3-2133 CL9 Quad Kit (F3-17000CL9Q-16GBZH) (Review: Guru3d)
- 16GB Corsair Vengeance Black DDR3-1866 CL9 Quad Kit (CMZ16GX3M4X1866C9) (Review: Hardware Heaven)
- 16GB Corsair Vengeance Red DDR3-1866 CL9 Quad Kit (CMZ16GX3M4X1866C9R) (Review: Vortez)
- 16GB G.Skill Sniper DDR3-1866 CL9 Quad Kit (F3-14900CL9Q-16GBSR) (Review: Overclockers)
- 16GB G.Skill RipJaws-X DDR3-1866 CL9 Quad Kit (F3-14900CL9Q-16GBXL) (User: J1nX3rS)
- 16GB G.Skill Ares DDR3-1600 CL9 Quad Kit (F3-1600C9Q-16GAO) (User: ElitePilot)
- 8GB Corsair Vengeance LP weiß DDR3L-1600 CL9 Dual Kit (CML8GX3M2A1600C9W) (User: J1nX3rS)
- AeroCool Strike-X ST
- Aerocool XPredator (User: Dragon667)
- Antec Eleven Hundred
- Antec P280
- Akasa VenomToxic (AK-TOX-01BK)
- BitFenix Shinobi XL
- Cooler Master Cosmos II (RC-1200-KKN1)
- Coolermaster HAF X (RC-942-KKN1)
- Cooler Master CM Storm Trooper (SGC-5000-KKN1-GP)
- Cubitek HPTX-Tank
- Cubitek XL-Tank
- HEC 98 R9BB
- Mountain Mods Ascension*7
- Nox Hummer USB 3.0
- NZXT Switch 810
- Lian Li PC-A77F
- Lian Li PC-P80(R/N)
- Lian Li PC-V2120
- Lian Li PC-X500FX TYR
- Lian Li PC-X1000 TYR
- Lian Li PC-X2000F TYR
- Lian Li PC-Z70
- Silverstone Temjin SST-TJ07 (User: J1nX3rS)
- Silverstone Temjin SST-TJ11B-W
- Xilence Interceptor
- Xilence Interceptor Pro
- Xigmatek Elysium
Anhang A) Die möglichen Konfigurationen der PCIe Lanes
Aus dem Handbuch:
Nach Verwendung (Anbindung von oben nach unten):
Dieser Thread ist noch in Bearbeitung. Berichtigungen sowie Ergänzungen (jeweils unter Angabe der Quelle) und eure Unterstützung bei der Pflege dieses Threads ist ausdrücklich erwünscht. Danke & Gruß, emi
... Wird eh nächsten Monat son 1200W BeQuiet herkommen, da ich ja noch ein wenig was vorhabe (4 Grakas)... Aber danke dir Dozer3000!!!
zugelegt.
