Vielleicht erscheint er in jedem 25.000 Match für 3 Sekunden zufällig auf der Map.Bin mir sicher, dass da wieder eine fiese Sache dahinter steckt![]()
Du fliegst nicht!Dann wird halt wieder geboosted wie bei den 20 Zerstörungen hahaha
"Winter 2010"...Nein, einen Release-Termin gibt es leider nicht. Wird aber hoffentlich noch vor Xmas erscheinen.
Da issa ja.Okokok...wenns denn sein muss, flieg ich wieder![]()
http://blogs.battlefield.ea.com/battlefield_bad_company/archive/2010/11/23/update-for-battlefield-bad-company-2-ps3.aspxHere is a complete list of all the fixes in this update:
- Acog and Red dot scope now equippable on MK-14 and G3.
- Fixed a bug on PC where the G3 would do less damage than intended.
- Reduced VADS push back and damage to balance it with the ZU23.
- Fixed a bug where Vehicle Countermeasures would fail to remove tracer darts at high speed.
- Reduced the reload time for Vehicle Countermeasures.
- Slightly increased the AT4's damage vs armor to emphasize its anti vehicle role while keeping it balanced vs armor.
- Increased the AT4’s top speed and acceleration so users spend less time exposed when firing.
- Increased the AT4's splash damage so it competes with other AT weapons vs infantry. The AT4 still has the least splash damage of all AT weapons.
- Reduced the splash damage of the Carl Gustav to bring it in line with other explosive weapons. The Carl Gustav still has the most splash damage of all AT weapons.
- Increased the 1 shot kill range of the M95 body shot to counter its lower rate of fire.
- Fixed a bug with the SVU that gave it better close range damage than other semi auto weapons.
- Reduced all weapon damage to the MCOM by 50%.
- Fixed a C4 vs MCOM exploit on Atacama Desert.
- Fixed a bug with FOV when aiming the M1911.
- Lowered the close range damage of the AN94 to highlight its long range role.
- Increased the accuracy of the F2000 on the move to highlight its role as a mobile AR.
- Increased the close range damage of the shotguns to give them a greater advantage vs slugs.
- Slightly lowered the damage of the M60 to balance its accuracy advantage vs other LMGs.
- Slightly lowered the damage of the MG3 at close range to balance it with other high rate of fire weapons.
- Slightly increased the damage of the UH6
m14 udn g3 mit visier DAS MACHT MICH HEISS
M14 ist doch die wumme ganz unten die so beschissen zum zielen war. Geil mit Rotlicht
