Zitat:
- CPU
- LGA 775 socket for:
- Intel® Core2 Quad and Intel® Core2 Duo- Supports Intel Enhanced Memory 64 Technology (EMT64T)
- Supports Enhanced Intel SpeedStep Technology (EIST)
- Supports Intel Hyper-Threading Technology
- Supports 1333/1066/800MHz FSB
- Intel® chipset
- Intel® chipset
- Northbridge:
Intel® P45 Express chipset
Intel® Fast Memory Access technology
- Southbridge: Intel® ICH10R- Memory
- Four 240-pin DDR2 DIMM sockets
- Supports DDR2 1200(O.C.)/1066/800/667 MHz
- Delivers up to 12.8Gb/s bandwidth
- Supports dual channel (128-bit wide) memory interface
- Supports non-ECC unbuffered DIMMs
- Supports up to 16GB system memory
- Expansion Slots
- 2 PCI Express (Gen 2) x16 slots - 2-way CrossFire: One slot operating at x16 (16-lane port) or two slots each operating at x8 (8-lane ports) bandwidth
- 2 PCI Express x1 slots
- 2 PCI slots
- BIOS
- Award BIOS
- 8Mbit SPI flash BIOS
- CMOS Reloaded
- Audio
- Realtek ALC885 High Definition audio CODEC
- 8-channel audio output
- DAC SNR/ADC SNR of 106dB/101dB
- Full-rate lossless content protection technology
- Optical S/PDIF-out and coaxial RCA S/PDIF-out interfaces
- LAN
- Marvell 88E8053 PCIE Gigabit LAN controller
- Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
- IDE
- JMicron JMB363 PCI Express to PATA host controller
- Supports up to 2 UltraDMA 33/66/100Mbps IDE devices
- Serial ATA with RAID
- Intel Matrix Storage technology
- Supports up to 6 SATA devices
- SATA speed up to 3Gb/s
- RAID 0, RAID 1, RAID 0+1 and RAID 5
- Rear Panel I/O Ports
- 1 mini-DIN-6 PS/2 mouse port
- 1 mini-DIN-6 PS/2 keyboard port
- 1 optical S/PDIF-out port
- 1 coaxial RCA S/PDIF-out port
- 6 USB 2.0/1.1 ports
- 1 RJ45 LAN port
- Center/subwoofer, rear R/L and side R/L jacks
- Line-in, line-out (front R/L) and mic-in jacks
- Power Management
- ACPI and OS Directed Power Management
- ACPI STR (Suspend to RAM) function
- Wake-On-PS/2 Keyboard/Mouse
- Wake-On-USB Keyboard/Mouse
- Wake-On-LAN
- Wake-On-Ring
- RTC timer to power-on the system
- AC power failure recovery
- Hardware Monitor
- Monitors CPU/system/Northbridge temperature and overheat alarm
- Monitors Vcore/Vdimm/Vnb/VCC5/12V/V5sb/Vbat voltages
- Monitors the speed of the cooling fans
- CPU Overheat Protection function monitors CPU temperature and fan during system boot-up - automatic shutdown upon system overheat
- PCB
- 4 layers, ATX form factor
- 24.5cm (9.64") x 30.5cm (12")
Wasserkühlung NB-SB-Mosfets:
EK-Mosfet DFI DK - Acetal
Watercool Kühler
NB/SB von Anfitec - Bilder: Klick
Spawa von Anfitec
(Künftig auch bei pc-icebox.de zu haben)
EnzoTech
Watercool Kühler
Spawa von Anfitec
EnzoTech
Wasserkühlung Zusammenstellungen vom "riverdief":
Einsteiger Wasserkühlung (Komplett, inkl. Spawas,NB,SB & CPU) 280,- € !
Highend Wasserkühlung (inkl. Durchflussmesser, Spawas, NB, SB und CPU) 460,- €
Luftkühlung:
Cooler Master Hyper Z600
EKL Alpenföhn Nordwand Rev.B
Noctua NH-C12P
Noctua NH-U12P
Noctua NH-D14
Prolimatech Megahalems Kühlkörper
Scythe Mine
Scythe Mugen (Infinity)
Thermalright IFX-14
TR Ultra 120 True Black / Extreme
Xigmatek HDT-S1283
Xigmatek Achilles S1284C
Xigmatek Dark Knight
Xigmatek Thor's Hammer
Noctua NH-C12P
Noctua NH-U12P
Noctua NH-D14
Scythe Mine
Thermalright IFX-14
Xigmatek HDT-S1283
Passt mit Problemen:
EKL Alpföhn Groß Clockner ( passt nur mit Modifikationen ...entweder am Kühler oder Chipsatzkühler )
Scythe Andi Samurai (gedreht)
Scythe Mugen 2 (der Lüfter muss 5mm verschoben werden)
Thermalright HR-01 Plus (gedreht)
Kompatibler Arbeitsspeicher:
A-DATA Vitesta Extreme Edition 2 GB PC2 9600
Cellshock DIMM Kit 2GB PC2-8500U CL5-5-5-15 (DDR2-1066) (CS2221550)
Chaintech Apogee GT DIMM Kit 4GB PC2-8500U CL5-5-5-15
Chaintech Apogee GT DIMM Kit 4GB PC2-9200U CL5-5-5-15 (DDR2-1150)R2-1150-4GDHS
Corsair DIMM 4 GB DDR2-800 DHX Kit (TWIN2X4096-6400C4DHX)
Corsair XMS2 Dominator 2GB PC2-8500U CL5-5-5-15 TWIN2X2048-8500C5D
Crucial Ballistix Tracer PC8500 1066MHz BL12864AL1065.8FE5
GeiL Value DIMM Kit 2GB PC2-6400U CL5-5-5-15 (DDR2-800) (GX22GB6400DC)
GeIL Ultra DIMM Kit 2GB PC2-8500U CL5-5-5-12 (DDR2-1066) (GX22GB8500UDC)
G.Skill Kit 4GB PC2-6400U CL5-5-5-15 (DDR2-800) (F2-6400CL5D-4GBPQ)
G.Skill Kit 4GB PC2-8000U CL5-5-5-15 (DDR2-1000) (F2-8000CL5D-4GBPQ)
G.Skill Kit 4GB PC2-8500U CL5-5-5-15 (DDR2-1066) (F2-8500CL5D-4GBPI-B)
G.Skill Kit 4GB PC2-8800U CL5-5-5-15 (DDR2-1100) (F2-8800CL5D-4GBPI)
G.Skill Kit 4GB PC2-9600U CL5-5-5-15 (DDR2-1200) (F2-9600CL5D-4GBPI)
G.Skill Trident Kit 4GB PC2-9600U CL5-5-5-15 (DDR2-1200) (F2-9600CL5D-4GBTD)
G.Skill DIMM Kit 4GB PC2-9600U CL5-5-5-15 (DDR2-1200) (F2-9600CL5D-4GBPI)
Kingston HyperX DIMM Kit 4GB PC2-6400U CL5-5-5-15 (DDR2-800) (KHX6400D2K2/4G)
OCZ Flex II 4GB Kit PC2-9200 CL5-5-5-18 (OCZ2FXT11504GK)
OCZ Reaper HPC Edition Kit 2GB PC2-9200U CL5-5-5-18 (OCZ2RPR11502GK)
OCZ Flex XLC Edition 4 x 1024 MB PC2-9600U @ 1200 Mhz
OCZ Reaper HPC Edition 2GB Kit PC2-9600 CL5-5-5-18 (OCZ2RPR12002GK)
OCZ Blade Low Voltage DIMM Kit 4GB PC2-9600U CL5-5-5-18 (DDR2-1200) (OCZ2B1200LV4GK)
Patriot Viper DDR2-800 4 GB
takeMS Mach2 2GB PC2-8500U CL5-5-5-18 TMS1GB264C082-105EP
TeamGroup Xtreem Dark 4GB Kit PC2-8500U CL5-5-5-15 TXDD4096M1066HC5DC-D
Kompatibler Netzteile:
Arctic Cooling Fusion 550R 500W ATX 2.2
Be Quiet Dark Power Pro P7 850W ATX 2.2 (BN075)
Cooler Master Silent Pro 500W ATX 2.3 (RS-500-AMBA)
Coba Nitrox IT-7750SG 750W ATX 2.2 (88882003)
Corsair HX 520W ATX 2.2 (CMPSU-520HX)
Corsair TX650W (CMPSU-650TX)
Corsair HX 1000W ATX 2.2 (CMPSU-1000HX)
Cougar CM 700W ATX 2.3
Enermax MODU82+ 625W ATX 2.3 (EMD625AWT)
LC Power 550W Green Power ATX2.2(LC6550GP2)
OCZ StealthXStream 500W ATX 2.2 (OCZ500SXS)
OCZ Fatal1ty 550W ATX 2.2 (OCZ550FTY)
Tagan PipeRock 700W ATX 2.2 (TG700-BZ)
Thermaltake ToughPower 750W ATX 2.2(W0116)
Biosupdate mit USB Stick
Anleitung vom Fresh_Thing
1. Programm runterladen und installieren.
2. Dos files und Bios runterladen - Bios findest du hier -> http://img.lanparty.tw/Upload/BIOS/CM/D45PD320.zip
Dann den pfad für die Dos files im programm angeben und den USB-Stick formatieren
3. Die 3 datein die beim Bios dabei sind auf den Stick kopieren.
4. Im Bios die setup defaults laden und direkt den USB-Stick als erstes Bootgerät einstellen.
Dann einfach nur neustarten und der Flash nimmt seinen Lauf
USB-Stick Bootfähig machen !!!
Downloads
Wichtige Links
DFI LANparty DK P45-T2RS @ DFI Homepage
( Probleme mit Opera Explorer bei dem Seitenaufbau ....Internet Explorer verwenden )
DFI LANparty DK P45-T2RS PLUS@ geizhals.at
DFI LANparty DK P45-T3RS @ geizhals.at
DFI LANparty DK P45-T2RS Plus @ HPM
Weitere nützliche Infos zum DFI LANparty DK P45-T2RS Plus
Kurzreview zum DFI LANparty DK P45-T2RS Plus
DFI LANparty DK P45-T2RS @ Geizhals.at
Quickreview von Clunk
Bios erklärt, wofür ist was?
How to Make a USB Pen Drive Bootable
Real Volt - Messung im Windows @ IDLE
mit einem Q9550 E0 @ FSB 500 @ 4255 Mhz
Gemessen vom mahaudi
CPU PLL ( Bios 1.55v.) ......Real : 1.578v...........Droop : + ~ 0.03v.
NB Core ( Bios 1.420v.) .....Real : 1.420v...........Droop : nichts
VDIMM ( Bios 2.218v. ) .....Real : 2.245v. .........Droop : + ~ 0.03v.
VTT ( Bios 1.280v. ) .......Real : 1.298v. ..........Droop : + ~ 0.02v.
Messpunkte DFI LP DK P45-T2RS Plus
Wie bekommt man den C1-Fehler weg?
Hier die Lösung vom Fresh_Thing
ohne Rams booten
dann PC am AN Schalter ausschalten (lange gedrückt halten) aber nicht am NT
einen Ram reinstecken und PC starten
.....wenn das nicht geht :
ohne Rams booten
noch mal ohne Rams booten und am AN Schalter ausschalten (lange gedrückt halten) aber nicht am NT
einen ( Wichtig ) Ram reinstecken und PC starten
ohne Rams booten
VID-Bug Behebung!
Computer neu starten und ab ins BIOS
Load optimal Defaults
Computer herunterfahren
Netzteilstecker abziehen
Jumper umstecken und Batterie für ein paar Min. raus
Computer starten
Unter Hardware Monitoring nachschauen, ob die anliegende Spannung stimmt (C1E und EIST an!)
Mit F10 raus und wieder rein, dabei ist zu beachten, dass beim ersten Mal, niemals mehreren Einstellungen gleichzeitig getätigt werden dürfen
Sollte die anliegende Spannung stimmen, speichern und starten
Wenn das der Fall ist, seid Ihr den Bug für immer los!
Ansonsten, die CPU a+e!
Computer starten
Smartguardian Design`s ( inkl.SG.exe vom UT P35 )
: http://rapidshare.com/files/18075196...DK_Edition.rar
Achtung!
Die mitgelieferten SATA-Kabeln können unter Umständen zum einem instabilen Betrieb führen, dies ist allerdings nicht immer der Fall.
Fazit:
Das Board kann echt eine Zicke sein und bestrafft auch den kleinsten Fehler mit einem Bluescreen/Reboot oder startet erst gar nicht, deshalb sollte man die Finger davon lassen, wenn man nicht genügend oder gar keine Erfahrung mitbringt, ansonsten bietet das Board mehr als genug Einstellungen und eine sehr gute Performance!
An dieser Stelle, möchte ich mich für die zur Verfügung gestellten Daten und wirklich gute Vorarbeit bei mahaudi bedanken!
Bildquellen:
Alter Thread:
DFI LANparty DK P45-T2RS / T3RS / Plus (Intel P45) [10]
ansonsten kommts in den schrott
liegts daran das ich mit winflash flashe ? ich mach jetzt mal usb bootable und probiere es noch einmal so langsam gehen mir die ideen aus.
