[Sammelthread] Gigabyte GA-EP45[T]-UD3P / UD3R / UD3 (Intel P45) [8]
Ja,nur hab ich keine Geduld mehr für Small^^:shot:
Aber die Idee hatte ich grade auch schon,und werde es auch noch umsetzten!!
Hier mal mein Finale Template für 500 FSB wen es interessiert.
500 FSB Prime Custom Stable
Robust Graphics Booster ...............: Auto
CPU Clock Ratio ..........................: 8
CPU Frequency ...........................: 500
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................:
CPU Host Frequency (Mhz) ............: 4Ghz
PCI Express Frequency (Mhz) .........: 100
C.I.A. 2.......................................: Disabled
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................: 800
PCI Express Clock Drive.................: 900
CPU Clock Skew (ps)....................: 50
MCH Clock Skew (ps)...................: 100
DRAM Performance Control
Performance Enhance...................: Standard
Extreme Memory Profile (X.M.P.).....: Disabled
(G)MCH Frequency Latch...............: 333
System Memory Multiplier ..............: 2.00b
Memory Frequency (Mhz) ..............: 1000Mhz
DRAM Timing Selectable ................: Auf manuell halt^^
Standard Timing Control
CAS Latency Time........................: 5
tRCD .........................................: 5
tRP'...........................................: 5
tRAS..........................................: 15
Motherboard Voltage Control:
Loadline Calibration.………................ Disabled
CPU Vcore….……….........................: 1.26875v
CPU Termination…..... 1.200V*.......: 1.3v
CPU PLL…………………....1.500V*.......: 1.500v
CPU Referen.…………....0.760V*.......: 0,823v
MCH/ICH
MCH Core…………….....1.100V...........: 1.32
MCH Reference….…….0.760V...........: 0,863
MCH/DRAM Ref.…......0.900V...........: Auto
ICH I/O……………….....1.550V............: 1.500v
ICH Core…………...……1.100V............: 1.100v
DRAM
DRAM Voltage ……....1.800V............: 2.02v
DRAM Termination .…0.900V............: Auto
Channel A Reference 0.900V............: Auto
Channel B Reference 0.900V............: Auto
So,dieses Settings ist natürlich nicht auf jedes System zu übertragen sprich es klappt nicht bei jedem.
Mit hohe Wahrscheinlichkeit muss man die vNB und vFSB anpassen und die Skews wie die GTL`s.
Heya ich bin auch seit kurzem Besitzer eines UD3P :) hatte davor nen Asus P5E @ rampage, was mir auch treue Dienste geleistet hat, mit nem Q 9550 aber nur bis 424 mit akzeptablen Spannungen geschafft hat - aber ich wollte mehr aus meinem Q rausholen, wie sinnvoll das ist sei mal dahingestellt :fresse:
naja hatte zunächst aber doch probs mit den 500 FSB costom stabil - dank deinem Post hier klappts nun :banana:, mit genau den selben Werten ( bis auf Vcore ) - dafür wollt ich mich nur kurz bedanken ;)
So und jetzt schau ich mal wieviel Vcore meine CPU für den Spaß haben will. Ich hab aber die bittere Vermutung das es etwas mehr wird wie bei dir :(
greetz
Genau die Settings laufen bei dir also auch vNB wie vFSB?
V-Core ist ja kla CPU abhängig wie normal alles andere auch.
Ich hab auch ganß klein angefangen mit einem GB-DS3 oder so,und ich biin damals sehr zufrieden gewesen,nur ist das halt für Quad nicht so zu gebrauchen;)
Achja,Sinnvoll ist alles was das EGO aufpuliert^^:shot::xmas::bigok:
Ansonsten Glückwunsch,und bitte ein Screen wenn du prime Custom hast viellecht kommst du ja auch mit weniger vFSB,vNB aus.....:eek:
Jop vNB wie vFSB, skews etc. alles exakt dasselbe :) ( mit multi x 6 ;) )
mir stellt sich grad die Frage ob ein bisle rumspielen an den skews evt. mehr bringt als die Vcore in die Höhe zu jagen? wahrscheinlich eher nicht eh?
Ja aber für mich hat es sogar einen gewissen Sinn, für mein Lieblingszock HOI 3 bringt jedes verkackte kleine Mhz einen gewissen Bonus für einen flüssigen Spielverlauf (aussschließlich CPU lastig das game )
- und abgesehen davon, wenn mein Q 9550 @ 4 k o0der gar mehr ? costom stabil läuft, kann mir nen i7 ( vlt. sogar auch SandyBridge? ) mal Dick den Buckel runterrutschen :shot:
jo screen kommt dann wenns stable ist ;)
Die V-Core kann man nur mit etwas Glück durch die richtige vFSB,vNB Kombi senken,aber da hab ich bisher weniger positive Erfahtung mit gemacht.
Wenn die CPU für 4 Ghz 1.23v braucht,braucht sie das halt kann man nischt machen^^
hmm ok. Vcore bin ich gard bei 1,318 ( bios ) angelangt - ( ~ 1,28 idle - ~ 1,248 prime ) @ 500 x 8 = 4 k
immer noch mit den selben sonstigen settings wie bei dir.
prime costom läuft und nach 3 min. Fehler :(
jetzt nicht mehr :) 1,325 im bios - selbe spannungen in CPU z wie oben und das Ding scheint stabil zu sein, bis jetzt zumindest.........
Ach anbei wie weit übervoltet das brett eigentlich die sonstigen spannungen ( vdimm, Pll, etc. ) habs wie gesagt erst seit gestern in Betrieb ;)
Sieht doch gut aus die CPU solange es nich auf die 1.3*v kommt wärs mir Latte wenn die Temps passen.
Zum V-Drop keine Ahnung...
1,3 prime oda idle?
musste mittlerweile die Bios vcore wieder hoch setzen, hatte nach ~ 17 min. nen error. :(
ich denke jetzt sollte es aber passen.
Jo die temps, sind prima - atm 47° max. core bei ner wassertemp von 29,1 ° -> sofern da kein Auslesefehler da ist ;)
haste du schon 4,25 k bei dir versucht?
^1.3v Prime,was du im Bios einstellst finde ich persönlich (Meine Meinung) ist egal.
Ein Tipp starte am besten direkt den Prime Custom Test weil man fast immer mehr braucht als Prime Small vollständig,small mache ich eigentlich nie,wenn dann large um die GTL`s etc. auszuloten.
Die Temps sind krass,dazu sage ich nur Wakü halt:bigok: Wenn ich in real einen kennen würde der mir das macht sofort!!! aber selber traue ich mir das nicht zu ud nein versuche es erst garnicht^^:xmas:
Die 4.25Ghz hatte ich mal angestete aber die Temps sind da bei mir schon im Prime Custom sehr hoch,aber ich denke es wird auf die 1.32-1.34v hinauslaufen.
@ Whitecker007, ich bin nun auch am neuen Bios vom UD3P zu Testen (11Cer) mir kommt es vor als ob es besser als das F10 läuft obwohl das F10 mir schon sehr gut vor kam besser noch als das F7er
Im Moment schaut es so aus als ob ich MCH mässig auch auf 1,32V@FSB500 kommen könnte, muss mal länger Primmeln ob es passt.
Hast Du auch Unterschiede zu älteren Biosen gemerkt?
1,3 prime max hört sich gut an dann hab ich ja noch ein bisle Spiel bis dato :d
musste jetzt aber wieder Vcore hochsetzten, war vorher nach 25 min. error :(
jetzt läufts aba schon seit ner ganzen Weile sauber, und bin bei 1,264 @ prime.
Das sollte jetzt auich passen. prime lasse ich immer norm. Weise @ custom laufen, es sei denn ich will RAM checken, das werd ich auch noch im Anschluss machen, mal guge was der Flexx II so alles mitmacht :d
Ne Wakü ist eigentlich nicht so das hexenwerk, einmal damit auseinander gesetzt und selbst eingebaut, und du wirst sehen, das es da nicht viel gibt worüber man sich Sorgen machen kann. Das einzigste was einem Sorgen machen kann, sind die Kosten des ganzen Spaßes, und der Suchtfaktor :d
( ich werd demnächst meinen 4 ten Wakü rechner aufsetzten :fresse:- aus übriggebliebenen Teilen die hier seit jahren rumfahren )
1,32 - 4 ... für 4,25 k ...puhhh mal schauen ob ich das wagen werde....
Hatte bis vor kurzem auch noch Luftkühlung, ich wollte Anfangs auch nur die CPU mit Wasser kühlen, da meine neue CPU eine sehr kleine Vid hat.
Aber wenn schon Wasser dann auch bitte die Grafikkarte, da hatte ich schon mehr Angst sie zu schrotten beim Umbau, aber es war eine Super Umbauanleitung dabei und hat dann auch Spass gemacht und hat Super geklappt.
Der Suchtfakor ist wirklich enorm und der kostet auch richtig Geld, aber was macht man nicht alles für sein liebstes Hobby.
Also zu der Bios Geschichte so genau hab ich es bisher noch nich getestet,und ich denke auch nicht das ich das machen werde;)
Das F11c läuft topp wozu soll ich da noch groß was testen?
Zu der Wakü Geschichte,mir gehts nicht um die Kosten solldern einfach das ich keine Ahnung hab wie man sowas macht,und bevor ich mir meine HW schrotte und ich 300-400 Euro in den Rechner investiere,belasse ich es lieber bei Lükü womit man auch topp Ergebnisse erreichen kann:)
mfg Sascha
Da muss ich Dir Recht geben... Hatte jahrelang eine Wakü und nun die gleiche Hardware mit Lukü - mit dem gleichen OC. Leiser ist der Rechner jetzt auch... Einzige Herausforderung ist die Festplatten wirklich leise zu bekommen. Heutzutage macht Wakü (für mich) keinen Sinn mehr. Aber es war eine nette Spielerei (wenn auch teuer ;))
irgendwie ist das ''neue'' Prime merkwürdig , meine 500Mhz settings @4Ghz laufen Small nicht durch. Die 500 @ 4.25 hingegen schon ..bekomm echt nen hals
Hey seppelchen,
wie hast du das den gemacht das Lükü nun leiser ist als Wakü??? steht der Pc in einem anderen Raum.
Habe die Erfahrung gemacht das Wakü süchtig macht und alles andere um einen herum lauter wird.Ich könnte manchmal meine Funkuhr von der Wand reißen weil sie speziell am Abend laut wie eine Turmuhr ist.
Nachdem ich mich eingefummelt habe möchte ich keine andere Kühlung mehr.
Gruß herm
Egge
Scheiß auf den Prime,"Angeblich würde ich durch das Prime Statt 1.23v,1-26v brauchen um es stable zu bekommen:lol:.
Aber im Alltag hatte ich nie Probleme mit 1.23v die im Allten Prime gereicht haben also scheiß drauf,ich werde die alte Version weiterhin benutzten.!
W1nter
Keine Ahnung,ich denke nicht,hab das F11c nur drauf gemacht weil ich das recht alte F7 zuletzt drauf hatte.
Egge
Wenn man sich überlegt das Wakü das 3-4x Kostet was Lükü kostet;) nein,das seh ich nicht ein,Lükü bekommt man,wie du selbst sagst,auch sehr sehr leise.
Wenn ich immer an meine Kollegen in real denke dir mir nen Vogel zeigen wenn ich sage mein Rechner wäre laut,da merkt man mal viel verwöhnt wir sind^^:hmm::xmas:
mfg Sascha
Ich würde der "neuen" Prime Version nicht trauen, sondern bei der alten bewährten Version bleiben.
Changelog:
From the included whatsnew.txt file:
1) Faster FFTs for most SSE2-capable CPU architectures.
2) More FFT lengths supported.
3) Some of the new, faster FFTs don't let us do as much error checking on each iteration.
If you don't want to lose this error checking, choose "SUM(INPUTS) error checking" from
the Options menu. This will slow down your tests by about 2-5%.
4) When a possible hardware error occurs during a test, the error message would
likely scroll off the screen unnoticed. Now, all future progress updates to
the screen will be followed by a message containing a count of the errors that
have occurred during the test.
5) Worker Windows now stagger their starts. This improves timings for some
CPUs and operating systems. See undoc.txt to control this feature.
Sie ist schneller beim Berechnen und Hardware Fehler werden schlechter bzw nicht korrekt dargestellt.
Für unsere Zwecke ist das keine Verbesserung.
@OT Wakü Diskussion
Wenn man sich die Mühe macht und sich richtig einliesst, dann macht man kaum beim Kauf noch beim Einbau Fehler. Hier im Forum wird einem dabei exzellent geholfen.
Mit einem gut ausgerüstetem System (ordentlicher Radiator/Durchmesser/Überwachung ala Aquaero) werden am Ende nur noch die Kühlkörper der Komponenten getauscht. Somit hat mit einer guten Basis nur ein wenig höhere Mehrkosten als ein alternativ LüKü beim Wechsel einer Komponente.
Und eine richtige Wakü ist auf jeden Fall leiser als Lukü. Meine 4x180mm Lüfter auf dem Radi drehen sich mit 600 U/Min und die sind quasi unhörbar. Kein Vergleich zu einer Lukü. Wer jedoch unbedingt seine komplette Wakü in einen Midi-Tower quetschen will, der wird sich über hohe Temperaturen und schnell drehende Lüfter kaum beschweren können. Ganz zu schweigen von jeglichem Verständnis für meinen Aufbau, aber jedem das seine. Für mich hat es sich absolut gelohnt.
Bin von insgesamt 9xSlipstream 1900@Tempgesteuert(800 - 1900 U/Min) auf 4x180mm@600U/Min und 5 Slipstreams @750 U/Min gewechselt. Das ist wie einen startenden Jet gegen das Geräusch von wachsendem Gras zu tauschen. und die Temperaturen sind tiefer als Lukü idle Temps.
Und was hatt deine Wakü gekostet?
Meine Lükü Maximal 100 Euro,und die ist auch schon sehr leise;)
Zumal 9 x Slip Stream im Normalfall gar nicht nötig ist, schon gar nicht bei 1900 rpm.
Wenn du die aufdrehst, ist das natürlich kein luftgekühlter Silent-PC.
@Whitecker
Wenns um die Kosten geht gewinnt Lukü logischerweise, darüber müssen wir uns erst gar nicht unterhalten.
Für jemanden wie mich der gerne am PC schraubt und genügend Geld sein eigen nennt ist das aber kein Ausschlusskriterium.
Ich hole gerne das Maximum aus meiner Hardware (auch wenn ich momentan ein wenig faul bin: 500FSB noch nicht erledigt+ einige Komponenten noch nicht verbaut usw) und geniesse es ein gutes Gesamtprodukt zu besitzen.
Mit 100 euro komme ich selbst bei Lukü nicht hin. Selbst da habe schon bedeutend mehr investiert. Wakü müssen wir erst gar nicht drüber reden. Es wurde irgendwann immer mehr Ideen, mehr Möglichkeiten und mehr Kosten und am Ende kam das hier dabei raus: Link(Mora2 fehlt, weil nicht mehr verfügbar)
Es wird dir hier fast jeder sagen, das dass völlig übertrieben und geisteskrank ist, aber im Endeffekt bin ich sehr glücklich damit und würde es jederzeit wieder machen. Ich konnte einfach meine Bedürfnisse mit LuKü nicht mehr stillen und wollte mehr und jetzt habe ich es.
Du kannst dir auch für wesentlich weniger eine gute Wakü zusammenstellen(klick), jedoch neige ich zu massloser Übertreibung und konnte es nicht lassen meine Ideen umzusetzen(Bilder). Jetzt brauche ich meinen Rechner nicht mehr zu tragen sondern nur noch schieben und muss mich auch nicht mehr bücken um eine DVD einzulegen. Netter Nebeneffekt :haha:
@Philibili
Die Fans liefen meist bei 800 -1200 U/Min und wenn die Temps von CPU über 55 Grad/GPU über 80 Grad gingen die platzierten Lüfter jedoch auf 100%.(Speedfan+mehrere Lüftersteuerung und Tempdioden waren damit beauftragt)
Ich glaube nur Menschen die einen Scythe Ultra Kaze 24/7 gewöhnt sind würden einen Slipstream bei 1900 als Silent bezeichnen. Leider ist der Ultra Kaze ein wenig dick und taugt nix als Casefan, sonst hätte ich mir den damals geholt anstelle der Slipstreams ;) Die Slipstreams haben jedoch auch einen wunderbaren Luftdurchsatz
Ich habe auch nicht wegen der Lautstärke sondern wegen den Temperaturen gewechselt. Lautstärke ist bei mir ebenfalls kein Kriterium, sondern ist ebenfalls ein netter Nebeneffekt bei der Wakü.
So jetzt lange genug gequatscht :btt:
So eine Reaktion lobe ich mir:bigok:hatte jetzt ganß was anderes erwartet (Quasi wie ich immer auf sowas reagiere^^:xmas:).
So genug OT sry forum
Ja nene, du kannst ja nicht erst was von einem startenden Jet erzählen, wenn man 9 x 120er mit bis zu 1900 Umdrehungen laufen lässt und dann plötzlich die Lautstärke aus dem Spiel nehmen wollen. Diese Darstellung verzerrt einfach die Situation, weil kein normaler Mensch 9 x 1900 Umdrehungen benutzt. Da kannst du auch gleich 20 x 80mm-Lüfter bei 3000 rpm mit deiner WaKü vergleichen in Bezug auf die Lautstärke.
Fakt ist, man braucht keine 9 120er Lüfter, um sehr gut zu kühlen und man braucht niemals 1900 Umdrehungen, um sehr gut zu kühlen.
Die Frage, ob man sich die meist besseren Temperaturen mit einer WaKü nicht mit einem lauteren System erkauft, scheint mir nicht eindeutig zu beantworten. Das kommt offensichtlich auf das konkrete System an.
Wenn ich meinen PC mit 3 Slip Streams bei 1000 rpm @ Belastung luftkühle, dann wird der nicht so viel lauter sein, als mein Radiator mit 8 Slip Streams bei 800 rpm.
Ich will also nicht abstreiten, dass man mit Geld und einigem Know-How sehr leise und gut gekühlte Systeme per Wasser-Kühlung erstellen kann, aber man kann auch keine völlig unrealistischen Luftkühlsysteme, die mit Silence nichts zu tun haben, einer WaKü gegenüberstellen. Dann ist klar, dass die leiser ist.
Ich zitiere mich gerne selber:
Somit kann nicht die Rede sein von ständiger Beschallung von allen Lüftern.
Anyway: Was du brauchst und was du für richtig hältst, das mag ich dir gerne gönnen und ich werde es dir auch nicht madig machen.
Was jedoch mich betrifft, kann und werde auch nur ich wissen was ich brauche und was nicht.
Ich wollte bestmöglich Luftkühlung und die bringt nunmal eine gewisse Lautstärke mit sich.
Soweit sind wir uns wohl einig, oder?
Ich war und bin einfach nicht bereit grössere Kompromisse einzugehen (zB weniger Spannung und somit weniger Takt, aber auch niedrigere Temperaturen) wenn ich die Möglichkeit habe mit anderen Mitteln mehr Leistung 24/7 zu benutzen.
Das ist meine Entscheidung und dafür trage ich die Verantwortung und Kosten.
Mit der LuKü bin ich einfach an ein Maximum gestossen bei dem es nichts mehr in Richtung Leistungsfähigkeit der Kühlleistung (wie gesagt Silence war nie die Prämisse) zu verbessern gab, aber Leistungsreserven der Hardware ungenutzt brach lagen. Folgerichtig musste ich zu besseren Mitteln greifen und das habe ich.
Da alle Lüfter über die Temperatur gesteuert wurden und ich beim Zocken ein Headset aufhabe ist Lautstärke kein Kriterium für mich.
Ich denke damit sollte mein Standpunkt klar sein, oder?
Ich wollte lediglich einen nützlichen Beitrag leisten. Ich bekomme keine Provision von WaKü Händlern oder habe sonstige negative Hintergedanken um jemand seine geliebte LuKü zu entreissen.
Ich denke jeder hier hat Individuelle Anforderungen an seinen PC und die sollte er/sie sich auch erfüllen. Sonst könnten wir auch alle zum MediaMarkt gehen und den 08/15 von der Stange kaufen. Damit würden wir uns viel Zeit und Geld sparen.
Ich werde auf das Thema nicht weiter eingehen. Rest per PM, sonst kommt ein Mod und die letzten Beiträge verschwinden zurecht im Nirvana.
:btt:
Ich zitiere dich auch gerne noch mal:
Wenn du sowas schreibst, dann beschwere dich auch nicht, wenn dir andere sagen, dass es keine 9 Lüfter mit bis zu 1900 rpm braucht, um einen leisen LuKü-PC zu haben. Das ist alles, was ich gesagt habe, nicht mehr und nicht weniger.
Dass du das später relativiert hast, von wegen du hast die ja nie auf 1900 betrieben, ist noch mal was ganz anderes. Fakt ist, was oben steht.
Von mir aus darfst du gerne selbst entscheiden, wie du deinen PC mit wie vielen Lüftern kühlst. Ich darf aber klarstellen, dass ein PC, wie du ihn im ersten Post beschriebst, logischerweise laut ist und nichts mit einem Silence-LuKü-PC zu tun hat. Da kann eine WaKü ja nur leiser werden.
Du gibst mir ansonsten ja auch recht, dass eine WaKü nur dann Sinn hat, wenn man sie ausreichend dimensioniert und weiß, was man tut. Sonst hat man am Ende ein System, das lauter ist, als wenn man sich 4 120er rein hängt.
Kommt ihr freiwillig wieder zum Thema zurück?;)
Trotz Prime Custom stable hab ich hier hin und wieder freezes,wohin gehen eure Erfarhungen?
GPU hab ich schon ausgeschlossen,also runtergetaktet und es kommt noch daher schließe ich das aus.
Hab mal mim F11C Bios für mein GA EP45 UD3P was rumgespielt...
Ich muss sagen, das scheint echt gut zu laufen. Bin grad was am rumtesten.
Bin an 500 MHz FSB mit Ramvollbestückung dran... das ganze bei 1,20 vMCH.
Bin selbst überrascht wie gut es damit läuft. Hier nen etwas über 2 Std Prime Blend Run.
Die FSB Termination Voltage wird von ET6 komischerweise mit 1,3v ausgelesen.
Ist im Bios allerdings auf 1,28v eingestellt.
Oh man krass für 500 FSB 1.2v vMCH bei 8 GB das wird wohl das beste hier sei was es gibt.
Ähnliche Themen
