[Sammelthread] Asus P6X58D Premium (Intel X58)
P6X58D Premium
Best Choice for Extreme Overclocking and Future Transfer Technology!
•Intel® LGA1366 Platform & Intel® X58/CH10R chipset
•Next Gen 32nm 6-Core Processor Ready!
•True USB3.0 and SATA 6Gb/s Support!
•ASUS True 16+2 Phase Power Design
•3-Way SLI & Quad-GPU CrossFireX Support!
•MemOK!
CPU, Chipset and Graphics features
LGA1366 Intel® Bloomfield Processor Ready
This motherboard supports the latest Intel® Core™ i7 processors in LGA1366 package with integrated memory controller to support 3-channel (6 DIMMs) DDR3 memory. Supports Intel® QuickPath Interconnect (QPI) with a system bus of up to 6.4 GT/s and a max bandwidth of up to 25.6 GB/s. Intel® Core™ i7 processor is one of the most powerful and energy efficient CPUs in the world.
3-Way SLI and Quad-GPU CrossFireX Support!
Flexible Multi-GPU solutions, Your Weapon of Choice!
The P6X58D Premium breaks the boundaries to bring you the multi-GPU choice of either SLI™ or CrossFireX. The motherboard features a dedicated graphics engine on the most powerful Intel X58 platform to optimize PCIe allocation in multiple GPU configurations. Expect a brand-new gaming style you’ve never experienced before!
Intel X58
The Intel® X58 Express Chipset is one of the most powerful chipset designed to support the Intel® Core™ i7 Processors with LGA1366 package and Intel® next generation system interconnect interface, Intel® QuickPath Interconnect (QPI), providing improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. It also supports up to 36 PCI Express 2.0 lanes providing better graphics performance.
PCIe 2.0
Double Speed; Double Bandwidth
This motherboard supports the latest PCIe 2.0 devices for double speed and bandwidth which enhances system performance.
.Future Transfer Technology
True SATA 6Gb/s Support
Experience the Future of Storage!
Supporting next-generation Serial ATA (SATA) storage interface, this motherboard delivers up to 6.0Gb/s data transfer rates. Additionally, get enhanced scalability, faster data retrieval, double the bandwidth of current bus systems.
True USB 3.0 Support
10X Faster Date Rates!
Experience ultra-fast data transfers at 4.8Gbps with USB 3.0—the latest connectivity standard. Built to connect easily with next generation components and peripherals, USB 3.0 transfers data 10X faster and is also backward compatible with USB 2.0 components.
Memory Feature
Triple-Channel DDR3 2000(O.C.) / 1333 / 1066 support
The motherboard supports DDR3 memory that features data transfer rates of 2000(O.C.) / 1333 / 1066 MHz to meet the higher bandwidth requirements of the latest 3D graphics, multimedia, and Internet applications. The triple-channel DDR3 architecture enlarges the bandwidth of your system memory to boost system performance.
ASUS Xtreme Phase
True ASUS 16+2 Phase Power Design
Unprecedented Innovation with the Best Quality Component for Best Performance
The groundbreaking 16+2 phase VRM design is brrought to the ASUS motherboards. 16+2 phase power design, 16-phase for vCore and extra 2-phase for QPI/Memory controller inside CPU, can provide the highest power efficiency, and hence generates less heat to effectively enhance the overclocking capability. With the high quality power components such as low RDS (on) MOSFETs, Ferrite core chokes with lower hysteresis loss and 100% Japan-made high quality conductive polymer capacitors, ASUS 16+2 phase VRM design also ensure longer component life and minimum power loss.
ASUS Exclusive Overclocking Feature
ASUS TurboV
New OC Records with Real-Time Super-precise Tunings
Feel the adrenaline rush of real-time OC - now a reality with the ASUS TurboV. This extreme OC tool lets you set new ambitions on the OC stage with an advanced and easy-to-use interface - allowing you to overclock without exiting or rebooting the OS. With micro adjustments of the CPU PLL, NB, NB-PCIe, and DRAM voltages in 0.02v intervals, there are no limits - only extreme results to break new OC records!
ASUS Exclusive Features
ASUS EPU
System Level Energy Saving
The new ASUS EPU - the world´s first power saving engine, has been upgraded to a new six engine version, which provides total system power savings by detecting current PC loadings and intelligently moderating power in real-time. With auto phase switching for components (which includes the CPU, VGA card, memory, chipset, drives and system fan), the EPU automatically provides the most appropriate power usage via intelligent acceleration and overclocking - helping save power and money.
ASUS Express Gate SSD
0 to Internet in Seconds!
Express Gate™ is an ASUS exclusive OS that provides you with quick access to the Internet and key applications before entering Windows®.
MemOK!
Any Memory is A-OK!
MemOK! quickly ensures memory boot compatibility. This remarkable memory rescue tool requires a mere push of a button to patch memory issues. MemOK! determines failsafe settings and dramatically improves your system boot success. Get your system up and running in no time!
.ASUS Quiet Thermal Solution
ASUS Fanless Design - Heat-pipe solution
The Heat Pipe design effectively directs the heat generated by the chipsets to the heatsink near the back IO ports, where it can be carried away by existing airflow from CPU fan or bundled optional fan. The purpose of the innovative heat pipe design on this motherboard is that the groundbreaking fanless design does not have lifetime problems as a chipset fan does. Furthermore, it provides options for users to install side-flow fan or passive cooler. The Heat Pipe design is the most reliable fanless thermal solution to date.
Fan Xpert
Active Quiet & Cool
ASUS Fan Xpert intelligently allows users to adjust both the CPU and chassis fan speed according to different ambient temperature , which is caused by different climate conditions in different geographic regions and system loading.Built-in variety of useful profiles offer flexible controls of fan speed to achieve a quiet and cool environment.
Up to 20°C(36°F) Cooler - Stack Cool 3+
Effective Fanless Heat Dissipation at 0dB
Stack Cool 3+ is a fanless cooling solution offered exclusively by ASUS. It effectively and noiselessly transfers heat generated by the critical components to the other side of the specially designed PCB (printed circuit board) for effective heat dissipation - making temperatures cooler by up to 20°C.
.ASUS Crystal Sound
DTS Surround Sensation UltraPC
DTS Surround Sensation UltraPC delivers exceptional 5.1 surround experience through the most common PC audio setups - your existing stereo speakers or headphones. In addition to virtual surround, “Bass enhancement” provides stronger low frequency bass sound, and “Voice clarification” provides clear human dialogue even with loud background sound. With these technologies, you may experience a better home-theater audio with ease.
Noise Filter
Eliminate background noise while recording
This feature detects repetitive and stationary noises like computer fans, air conditioners, and other background noises then eliminates it in the incoming audio stream while recording.
.ASUS EZ DIY
ASUS Onboard Switch
With an easy press during overclock, this exclusive onboard switch allows gamer to effortless fine-tune the performance without having to short the pins!
Q- Shield
Easy and Comfortable Installations
The specially designed ASUS Q-Shield does without the usual "fingers" - making it convenient and easy to install. With better electric conductivity, it ideally protects your motherboard against static electricity and shields it against Electronic Magnetic Interference (EMI).
EZ-Flash 2
Simply update BIOS from a USB flash disk before entering the OS
EZ Flash 2 is a user-friendly BIOS update utility. Simply launch this tool and update BIOS from a USB flash disk before entering the OS. You can update your BIOS only in a few clicks without preparing an additional floppy diskette or using an OS-based flash utility.
ASUS Q-Design
DIY quickly, DIY easily!
ASUS Q-Design enhances your DIY experience. All of Q-LED, Q-Slot and Q-DIMM design speed up and simplify the DIY process!
Q-Connector
Make connection quick and accurate!
The ASUS Q-Connector allows you to connect or disconnect chassis front panel cables in one easy step with one complete module. This unique adapter eliminates the trouble of plugging in one cable at a time, making connection quick and accurate.
O.C. Profile
Conveniently store or load multiple BIOS settings
Freely share and distribute favorite overclocking settings The motherboard features the ASUS O.C. Profile that allows users to conveniently store or load multiple BIOS settings. The BIOS settings can be stored in the CMOS or a separate file, giving users freedom to share and distribute their favorite overclocking settings.
.Industry Standard
IEEE 1394a interface
IEEE 1394a interface provides high speed digital interface for audio/video appliances such as digital television, digital video camcorders, storage peripherals & other PC portable devices.
S/PDIF-out on Back I/O Port
This motherboard provides convenient connectivity to external home theater audio systems via coaxial and optical S/PDIF-out (SONY-PHILIPS Digital Interface) jacks. It allows to transfer digital audio without converting to analog format and keeps the best signal quality.
.RoHS
GreenASUS
The motherboard and its packaging comply with the European Union´s Restriction on the use of Hazardous Substances (RoHS). This is in line with the ASUS vision of creating environment-friendly and recyclable products and packaging to safeguard consumers´ health while minimizing the impact on the environment.
Geizhals Link
http://preisvergleich.hardwareluxx.de/a495774.html
Treiber&Tools
http://support.asus.de/download/download.aspx?SLanguage=de-de
Bios Downloadlink
ftp://ftp.asus.com.tw/pub/asus/mb/lga1366/P6X58D_Premium/
Bios History
[ 0703 ]
1. Improve system stability
2. Support new CPUs. Please refer to our website at: http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
[ 0702 ]
Support new CPUs. Please refer to our website at:http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
[ 0604 ]
Fix DRAM Voltage is abnormal in TurboV
[ 0506 ]
[ 0402 ]
1.Enhance OC Profile storage space from 2 to 8 slots.
2.Enable instant display of Target CPU & DRAM Frequency under Ai Tweaker
[ 0301 ]
First release Bios
CPU Support Liste
Core i7 920(2.66G,L2:4x256KB,L3:8M, rev.C0,130W) ALL 0301
Core i7 920(2.66G,L2:4x256KB,L3:8M, rev.D0,130W) ALL 0301
Core i7 940(2.93G,L2:4x256KB,L3:8M, rev.C0,130W) ALL 0301
Core i7 950(3.06G,L2:4x256KB,L3:8M, rev.D0,130W) ALL 0301
Core i7 960(3.2G,L2:4x256KB,L3:8M, rev.D0,130W) ALL 0301
Core i7 Extreme Edition 965(3.20G,L2:4x256KB,L3:8M, rev.C0,130W) ALL 0301
Core i7 Extreme Edition 975(3.33G,L2:4x256KB,L3:8M, rev.D0,130W) ALL 0301
Bilder des Boards
Ja, ASUS bekämpft das Problem, dass aufgrund des gleichen Chipsatzes die meistens Board auch die gleichen Funktionen haben und sich wenig unterscheiden. ASUS versucht mit kreativen Funktionen Kunden zu gewinnen. Aber die meisten davon sind auch völlig unnötig. Das einzig wirklich nützliche ist der Q-Connector. So was wie eien G-Connector ollte Gigabyte auch einführen.
Ich persönlich finde es wichtiger, dass die Funktionen des Chipsatzes perfekt umgesetzt werden. Und das macht Gigabyte nahezu optimal.
Und sie eingedeutschten BIOS-Optionen finde ich eher verwirrend als hilfreich. Auf English macht das alles viel mehr Sinn für jemanden der sich auskennt :cool:
Das ist ja alles schön und gut. In der Praxis unterscheiden sich die beiden Boards aber nur minimal.
Habe gerade gelesen, dass das P6X58D doch eSata hat - aber nicht auf dem Board selbst, sondern über eine beiliegende extension-bracket.
Hey man, exakt diese Diskussion habe ich gestern mit meiner Frau geführt! :fresse:
Mag sein, dass gerade Euch das Thema Hardware brennend interessiert, aber dieses Thema ist auch eine Sache für sich. Manche interessiert das überhaupt nicht, wie auch meine Frau. Gestern allerdings - man kommuniziert ja auch mal - erzählte ich ihr davon, dass bereits Pins auf 1156er Sockeln verschmort sind und plötzlich war das Interesse geweckt. Es gäbe da evtl. Probleme mit dem LGA1156 und mehrere Leute in einem großen Forum (luxx) wären auch schon geschädigt. Es gäbe auch Probleme mit dem Support der Hersteller. Dann zeigte ich ihr das Board, welches ich eigentlich kaufen wollte. Dazu suchte ich über www.google.de nach großen Bildern unter dem Suchbegriff "P7P55D-E" und zeigte ihr dieses Bild: zum board
Auf dem Bild kann man deutlich erkennen, dass Pins verbogen oder abgeknickt sind. Der Sockel sieht nicht makellos aus. Wahrscheinlich ist alles am Sockel zu filigran verarbeitet.
Jetzt soll ich - ihrer Meinung nach - ein Board mit dem größeren, 4-fach verschraubten Sockel 1366 kaufen.
Was soll ich jetzt tun / bzw. davon halten?
Was sagt ihr dazu? Gute Idee?
Um diese Boards geht es:
Sie sagt, dass ich wenn dann das erste nehmen soll (zumal das noch nicht verfügbar ist), denn das gefällt ihr optisch besser.
So ist das Asus auch mein Favourit. Beim Ram bin ich noch am überlegen, ob ich 1x oder 2x den 1600 Corsair Dominator 3x2GB CL8 nehme (den schwarzen) oder lieber das 6x2GB Kit mit den blauen Kühlern. Optisch passt ersteres wohl besser.:hmm:
Das Du gerade mit dem Ram ein Problem hast ist natürlich schlecht. Vielleicht ist ein Ram-Slot defekt - hab das bei Asus schon öfters gelesen.
Hast Du die Ram-Werte im Bios mal manuell eingegeben/entschärft und gespeichert? Behält das Bord die Daten?
Hast Du zwei Grakas? Wie eng sind die bei SLI/CF zusammen, wenn Du sie in die ersten beiden Slots steckst?
Ich hab (noch) eine HD2400 :fresse: drin.
Das mit dem Ram ist nicht das Problem. Wenn der PC erst mal durch das Cmos reset läuft, dann läuft er super! :bigok:
...allerdings nervt das, immer bei jedem Kaltstart die Werte neu ins Bios einzugeben, wenn man denn übertaktet. :fresse:
Wenn es denn mal funktioniert, behält das Board nur so lange die Daten, bis du einen Neustart durchführst. Dann KANN es anders eingestellt sein. Ich hatte auch schon alles manuell eingegeben, aber das hat er auch verändert. Vorhin konnte ich mal einen richtigen Kaltstart machen, dann führte er aber das MemOK! aus. :stupid:
Hoffentlich bringt Asus noch ein Biosupdate raus, sonst :kotz:
Wenn die Uhrzeit gespeichert wird, ist dann die Batterie vom Board in Ordnung? :hmm:
Vielleicht hat das Board doch ne Macke. Hab jetzt schon sehr viel in englischen Foren und z.B. Kundenrezessionen bei Newegg.com gelesen - da hatte noch niemand das Problem.
Ich frage mich allerdings, warum noch keine einzige seriöse HW-Seite das Brett getestet hat. Sonst wird ja jeder Lüfter und jede Festplattenhalterung getestet, aber eines der Gulftown-Boards schlechthin lässt man aus.
Naja vielleicht warten sie noch auf den Gulftown. Garantiert haben die den Gulftown schon mit dem Board getestet...
@grilleluxx: Kann es sein, dass die Batterie hin ist?
Ich werde mal das UD7 testen und danach das P6X58D Premium...
Tach Jungs. Ich besitze das P6X58D Premium board. Es ist ein wirklich schönes board, ich kann es aber im Moment nicht uneingeschränkt empfehlen.
Mehr zu meinem Problem könnt ihr im Sammelthread bei den Effizienzgurus lesen.
ich habe das board auch von alternate und habe seid einbau NULL probleme mit dem Board weder mit dem bios 0402 noch mit dem 0506
Keines deiner probleme kann ich bei mir bestätigen noch nachvollziehen
Wann hast du es denn bestellt? auch am 11.01.? Hast du Rev 1.02?
Ich hab jetzt erst einmal eine Nachricht an Alternate geschickt. Mal sehen, wie das weitere Vorgehen ist.
ich habe es am 08-01-2010 bestellt
ich habe REV 1.04G
Ich hab Rev 1.04G aufgedruckt. Und was hast du für Komponenten?
Ich selber hab Corsair HX750, i7-920, Noiseblocker TwinTec, Corsair 3x1GB Dominator 1600 (TR3X3G1600C8D), Club HD2400 Pro, SB Audigy 4, LG CH08LS10 BD-Laufwerk, Seagate Barracuda (ST3500418AS) 7200.12 500GB.
Komischerweise läuft in Windows alles fehlerfrei, stabil und schnell.
Es scheint ein reines Boot-Problem zu sein.
REV 1.02 ist aber ne alte
sieh in meine system info da ist mein system aufgelistet
Tschuldigung, ich hatte mich verguckt. Ich hab doch 1.04G.
Aber interessant. Du hast den i7 950. Hab irgendwo gelesen, dass jemandem von einem Asus Mitarbeiter gesagt bekommen hat, dass das ein Intel Problem sein soll. Hm... vielleicht liegt es am i7 920? :fresse:
Sicher. Das Board ist ja auch für den Gulftown erschaffen worden, nicht für zwei Jahre alte 45nm-Opas.:shot:
@RiMaBo: Derjenigewelcher (aus Amerika) hat geschrieben, dass er mit dem Asus Support telefoniert hätte und die hätten ihm das gesagt, dass es am Intel Prozessor liegt und nicht an ihrem Board, dass das Ding nicht richtig läuft. :fresse:
Jane, is klar. Wenn so eine i7 Plattform hergestellt wird, dann sollte Asus tunlichst dafür sorgen, dass die Dinger fehlerfrei laufen. (auch mit i7 920 Omas :xmas:) Immerhin waren die schon über einen Monat eher in Amerika zu haben, als bei uns. :hmm:
kann ich mir nicht vorstellen
schreib doch mal einen asus mann hier im forum an und erzähle ihm davon mal schauen was dieser dann sagt
Frage: Das Board hat ja einen 4-Pin und noch einen abgedeckten 4-Pin EPS-Anschluss. Braucht man beide und wenn ja, wofür?
Na ja, das ist ja schon lange so!
Stromversorgung CPU - oder?
lg
---------- Beitrag hinzugefügt um 15:36 ---------- Vorheriger Beitrag war um 15:36 ----------
BOARD ist bestellt - bin schon gespannt!
Also bisher habe ich nur einen 4-Pin gebraucht. War auch grad dabei das Board zu bestellen - ist aber in CH noch nicht lieferbar - hier ist echt alles immer etwas langsam...
Ist bei mir derzeit auch nicht lieferbar - vermutlich in schwach 2 Wochen!
Das mit den 2 Anschlüssen ist aber schon "lange" so.
War, wenn ich mich nicht täusche, beim P35-Chipsatz auch schon so.
lg
Der Preis - € 279 - ist aber auch nicht ohne!
Bekomms bei meinem Freund um € 250 - da warte ich gerne schwache 2 Wochen - hab ja keinen Stress!
lg
ich habe es für 269€ von alternate bekommen,scheiß drauf ich wollte es
ist alles eingebaut habe leider keine anderen bilder
marineblau sind die pipes
Das board war definitiv defekt, ich hab jetzt ein neues.
Allerdings hat das einen ganz anderen Fehler. Zeit und Sprache werden vergessen. :mad:
Ziemlich unausgereift, das P6X58D Premium!
Ich rate zum jetzigen Zeitpunkt jedem von einem Kauf ab!
Wenn ihr nicht dringend auf ein S1366 Board angewiesen seid, wie ich, dann wartet mit dem Kauf ab!
ich kann KEINES deiner Probleme hier bei mir nachstellen,von daher bitte nicht voreilig anderen den Kauf verderben wenn du solche Probleme hast
wie man an mir sieht habe ich z.b NULL probleme mit dem board
